#1 | ||
I'm a little angel
Toy Fawk-U er FAQ
Alright... I have been thinking it would be cool to have a Toyota FAQ.
Anyway, I spent a couple hours searching the board and trying to put together some useful shit to get it started. I got most of this from the board with some additions from my own experience or what I think I know. As a result it is very possible some of the information is incorrect. I assumed from the get go that this would be a group effort. I didn't search for the FJ55 stuff for the Master Cylinder for instance. So if you think it is a piss poor idea I will delete it if someone else doesn't... otherwise I am open to suggestion and will edit false information for sure. Thermostat Problem Question: “Why does my engine temp go all the way up to the red before it comes back down to the middle of the gauge after I start it up in the morning. It only does this when the engine is cold and once it warms up it seems to operate normally. Could it be as simple as a stuck thermostat?” Answer: (From Roger Brown’s Web Site) “What happens on the 22R and 22RE engine, when the coolant goes through the heater core it gets cooled off enough that when it gets dumped back in on top of the t-stat it shuts it. Therefore the temperature in the engine continues to go up. The t-stat that I have mentioned has two valves in it, one at the regular temp. and one smaller on at a cooler temp. If the cool water shuts the big one, the smaller one stays open. All this happens because of the lack of a by-pass hose, which on other systems, keeps hot coolant running on the t-stat.” You can get the two-stage thermostat mentioned above from your local Toyota Dealer. Part Number: #90916-03070 Chevy Springs Everything you ever wanted to know about Chevy Springs… is in this thread: Chevy Spring FAQ If you actually have a question that is not answered there… that would be a great place to ask it so the answer is there for everyone else. 44044 Springs 44044s are Rancho Jeep Wagoneer Lift Springs. Length: 47” Center Pin split (front/rear) 22.5"/24.5" Bushing: 3” Lift: 5.25 - 5.5” Cost: $250 44044's do not (by themselves) move your axle forward. They are the same length on the front half as stock toys (22.5"). While they do move the axle forward because of the lift they provide, when they compress to the point that they are flat, it's the same." Estimated 1/2" of actual axle relocation forward. (Length is eye to eye) (Lift is approximate and uses 1.5” longer than stock shackles giving 3/4” of lift) (Cost is for both sides incl. shipping/give or take) Wagoneer Springs “Waggy Springs” These are stock Jeep Wagoneer Springs Length: 47” Bushing: 3” Lift: 3.5 - 3.75” Cost: $160 Cost is new from JcWhitney: $78 each Part No: 07RJ2047B 5 leaf Part No: 07RJ2047P 7 leaf Used should be cheap and come out of mid seventies to mid eighties waggies. 7 leaf is supposed to be the ones you look for. (Length is eye to eye) Cone Washers Cone washers are the washers that are behind the nuts holding on Toyota wheel hubs and steering arms. Cone washers are a pain in the ass. Anyone from the dry areas of the southwest will tell you that a good smack on the stud will loosen them up. If you are in or near the Midwest... forget that. Using one or all of the following (most likely all) you should be able to get them off.
Brake Rotor Swap Some folks like to swap out their solid rotors for vented rotors. This is a simple and somewhat inexpensive modification. I did this swap because my brakes were getting very hot and making some very annoying noises. If you can change your brakes you should not have any problem with this swap. All you need are rotors from an '81 and up Toyota LC FJ40 and calipers from an IFS Toyota (86+ P-up or 4Runner). The Land Cruiser rotors are wider because they are vented but otherwise fit right on with no other modification besides the caliper. The caliper comes in two flavors... one has two larger pistons and two smaller, and another has four pistons that are the same size. The ones with four large pistons would technically give you more braking force. I used the same pads because mine were still fairly new... so you don't need new pads unless yours are low. Larger Master Cylinder In addition to the Rotor swap, some people like to put bigger MCs in so that they have more fluid movement. In this case, you want to acquire a Master Cylinder for a V6 P-up. It should be the 1" Bore. This is pretty much a bolt in replacement. Requiring you to move some brake lines slightly at worst. Bleeding Brakes This is the proper way to bleed your brakes to avoid spongy brakes, etc... Quote:
Thanks to DRM for saving this, and Tim for giving the advice. Quote:
#2 |
Mellonhead
Member # 3236
The older Toyota fuel injection systems are analog systems based on Bosch L-jetronic.
Around the mid-80's the Toyota TCCS took over, it is a (8031/8051) microcontroller based digital system using in-chip ROM. That means there is no separate ROM chip which could easily be read and replaced for tuning purposes... Later versions use more powerful microcontrollers. The TCCS systems use L-jetronic, MAP, hot-wire and vortex type air flow meters depending on application. Toyota EFI trouble codes for 4K-E, 22R-E, 2S-E (probably also all others) 1 All OK 2 AFM Vc open Vc / Vc-VS, open Vb AFM Vc/Vs, wiring, ECU 3 AFM Vs open Vs, Vs-E2 short, open Vb AFM Vb/Vc/Vs, wiring, ECU 4 THW THW open Coolant sensor, wiring, ECU 5 O2 Ox stuck rich/lean Oxy sensor, wiring, ECU 6 IG no ignition signal ignition, wiring, ECU 7 TPS Idl/Psw short TPS, wiring, ECU 8 THA open/short intake temperature sensor 9 SPD speed sensor just leave it disconnected - it's for speed limiter only. 10 STA starter signal 11 A/C air conditioneer switch, TPS or neutral start switch How to read the codes? 1. turn ignition on, but don't start the engine 2. short the check engine connector (or between T and ground) 3. check engine light will now blink indicating the code. Count the number of successive blinks and that's the code. Be aware that there may be more than one trouble code stored, in which case the next displayed code is different. There is a 3 second pause between the codes. Codes will be repeated until you remove the short in check engine connector. 4. Clear the codes by removing the "stop" fuse, or disconnect the battery for at least 30 seconds. Pickup and 4Runner Transmissions with 1st gear ratios. L43 4 speed 79 - 80 3.67 L45 4 speed 81 - 82 3.93 L50 5 speed 81 - 82 3.93 L52 5 speed 83 3.93 G52 & G54 5 speed 84 - 88 (Carb) 3.93 W56 5 speed 85 - 95 (EFI) 3.95 Manual Hub Equipped Vehicles 89 and up Have W56, 89 and up ADD vehicles have G58. R151F 5 speed 86 - 87 (turbo only) 4.31 G58 5 speed 89 - 95 3.93 ADD Equipped Vehicles R150F (6 cyl) 5 speed 88+ 3.83 Years Engine Model Shift Style Spline Type 1979-1980 20R Carb Top Shift 21-spline 1981-1983 22R Carb Top Shift 21-spline 1984-1988 22R Carb Forward Shift 21-spline 1985-1988 22RE EFI Top Shift 21-spline 1986-1987 22RTE EFI/Turbo Top Shift 23-spline 1989-1995 22RE EFI Forward Shift 21-spline 89-95 22RE(G58) forward shift chain drive transfercase 26-spline will not accept adapters or gear sets. These are 22RE/4X4 Models with 5 spd and ADD. "It's an 85 xcab efi. When I hit the brakes my idle drops off 500 rps or so then recovers, over and over again. It dosen't happen when It's warming up, just when hot." "I would bet you that your idle is set to high. Sometimes the screw works loose with vibration. If your idle is at like 1100, it's too high. With the engine warm, try lowering the idle at the intake manifold to about 750 or so. That will probably solve your problem. Mine was doing the same thing last week after the new header. Adjusted the idle and it's fine. " "The EFI computer receives a signal from the brake circuit that tells it that the brakes are being applied. This causes the computer to shut off the injectors if the RPM's are over a certain level and the engine is in "closed loop" as engine power should not be needed if the brakes are being applied.I believe the set point for the injector cut out is 850 to 900 RPM. This is what causes the surging - your idle RPM is too high, when the brakes are applied the injectors are cut out until the RPM's drop below this level. The engine then run's again. This only happens when the engine goes into "closed loop" so this will not happen when the engine is at a higher idle speed warming up. I am willing to bet your idle speed is around 1000 RPM when this happens. To fix this problem, simply adjust your warm idle speed to 750 RPM as per the factory. "
Too many idiots, not enough dead people Last edited by jasonmt; 02-21-2002 at 04:19 PM. |
| Sponsored Links |
#3 |
Member # 3101
Your link to Rodger Brown's Web site goes to the 63" chevy spring page.
00 Dodge QuadCab CTD 97 TJ on 33's for now |
#4 | |
I'm a little angel
Everytime I thought of something to put five more things popped into my head. Definately could be a good thing if the group gave it a concerted effort. Besides... we could say "Read the FAQ" before "Do a Search" |
#5 | ||
I'm a little angel
Thanks... |
#6 | |
I'm a little angel
Obviously if it is the wheel bearings then you have other issues. I think what you are referring to is the Spindle Bushing. It is a brass bushing that helps center the shaft in the spindle. If it is worn it will let the shaft rattle around and damage the seals leading to premature failure. Part Number: 90999-70067 according to this thread |
#7 |
Member # 250
Stock toy rears move the axle forward because they are only 20.5" on the front half.
Making good decisions comes from experience ....... ...... experience comes from making bad decisions |
#8 |
Member # 305
also waggy's and 44044's need a 3/8? inch spacer on driver side to make the truck sit level. the waggs are built identical since they are on a dana. toys are built stupid and uneven. the spacer can be bought at all-pro fairly easily through chris geiger.
Pinion angle is an issue if you just bolt waggs to the stock location. If you have dropped hanger or dual cases the problem is lessend. Man toy FAQ eh... have you asked lance if he'd throw it up as at least a sticky? waste of time if it bleeds into the eternal BB never to be seen again.
I feel like a newbie all over again :D [email]Skyetone@msn.com[/email] |
#9 | ||
Cardboard Killer
Member # 5776
Re: Toy Fawk-U er FAQ
And this did no visible damage to the hub. Lay into that hammer, buddy!
#10 | ||
Cardboard Killer
Member # 5776
All the bearings I got were either Timken or SKF. The 82 FJ-40 rotors I got were OEM quality parts from Japan, too. Thier stuff is pricey, but it's top of the line. [EDIT:] Forgot... Super rebuild kit was $199 and their site is http://www.jtoutfitters.com
#11 |
Member # 305
The way i figure it is that if my sentences run into each other then I am just thinking. Thats how I think I guess. Great fabbers jump ideas untill it's time to dwell.
Oh and bob you did understand it so whats your issue What other FAQ's do we want to cover? Gearing..... with a 4 banger and single case stock 3.96 or 4.10= 31 or smaller tire 4.88=33 inch tire 5.29= 35to 38 inch tire. 5.71= 35 to 38 inch tire street truck.
#12 |
I'm a little angel
Another big one would be "What do I need to do to fit xx" tires?"
I think that is probably the biggest one. |
#13 |
Member # 2413
trail fix
if you don't have an axle seal when you break a birfield use about a 1/4" slice of (toyota) radiator hose ...it still leaks a little but it doesn't dump out..
http://www.tinbenders.org/ |
#14 |
Member # 6020
You don't have to use a spacer with 44044s. I don't, and you can't tell.
I also run 4.10s with 35s. It's a little slow off the line but it isn't to bad once you get used to it. If you don't have to run over 35 MPH just keep the front box in low If you put the end of the 44044 with 2 clamps forward it does move the axle forward by itself. I measured mine and it's 24" to the rear and 22" to front CE to center pin, mounted.
4Runner buggy 4.3 CPI/R151/2.28 duals/on tons |
#15 |
I'm a little angel
I PMed Camo about making this a sticky... but I haven't heard anything yet... I think Lance is out of town, so I am not sure who is the "right" person to ask...
#16 |
Member # 305
wheelbase needs to be covered.
can we please sticky this?
#17 |
Member # 10257
I'd also add somthing about dfferent types of lockers (Air, electric etc...)
#18 |
Member # 5315
And this did no visible damage to the hub. Lay into that hammer, buddy!No! I used all of those brass drift on stud/ hitting locking hub body methods for about 2 days and got nothing. All you need is 2 whacks as hard as you can hit with a 3lb. baby-sledge right on the red X in this pic. I tried every method I could think of to get them loose. This got them off in less than 2 minutes. Just make sure you have the nuts on the studs. 2 of them shot across the floor. Hit it hard twice, rotate the hub 1/3 turn and repeat. You'll have the hub off in no time. Anyone that's seen the axle I've got knows that it was as rusty as they come...
I remember reading that in a post a month or two ago, so when I was changing my rotors yesterday, that hammer came out of the toolbox early. A good whack and no problem with the cone washers, thanks to this BB.
86 22R Weber carbed Toy Truck |
#19 |
Member # 694
"If you're worried about bearings, got the rebuild kit from JToutfitters. Comes with everything the other kits do, plus the hard-to-find 54mm/2-1/8" socket, and timken wheel bearings. "
That's a 2 3/32" socket!
CA Highway Patrol = Governator's state revenue solution. |
#20 |
Cranky B.F.U.M. Mod
How to Install a 4.7 gearset
Brandon and Flashlightman wrote this killer step bt step how-to for installing a set of 4.7's. Heres the link to it. I used it yesterday to prep my case for a set. Made the proccess a breeze!
4.7 Gear Installl How-to
85 Toy Xtracab "I DON'T want to understand !!" Click here to donate to the Rubicon Trail Foundation Rubicon Trail Foundation Rubicon Trail Patrol Rock-N-Roll 4X4 Club "Wow this is unbelievable" |
#21 | ||
Cardboard Killer
Member # 5776
#22 | |
I'm a little angel
#23 |
Separating the birfield from the axle
Don't forget separating the birfield from the axle.
http://www.pirate4x4.com/forum/showt...839#post334839
'We've got to pause and ask ourselves: How much clean air do we need ?' --Lee Iacocca |
#24 | ||
Cardboard Killer
Member # 5776
Re: Wheelbase
Long Wheel Base Truck and Xtracab RN65: 112.20 inches
#25 |
Member # 305
are you sure? I thought that 1st gen longbeds matched first gen runners. I also thought that x-cabs were like 116" thought there were like 4-5 different lengths.
| Thread Tools | |
| Display Modes | |
