Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Ford
Old 11-13-2003, 09:14 PM   #1
RedNeckRea
Member # 16333
Send a message via AIM to RedNeckRea Send a message via MSN to RedNeckRea
72 bronco build up
Over the summer I got the chance to work with Tim Haight of Bronco Alley, and my heart got set on building a early bronco. I finally got some pics of it and figured I'd share. Still not completed but that is to be expected when you can't work on it full time due to school. The specs of the build are in my sig.
first pic of what I started out with...
~Chris
~NAVY Sailor, future nuke
~WE-ROC marshall/judge. "I judge cause I don't talk to good" :laughing:
~[URL=http://www.pirate4x4.com/forum/showthread.php?s=&threadid=194070]72 "Bronco Alley Bitch" build up[/URL]
[QUOTE][i]Originally posted by Paul Gagnon [/i]
[B] Trucks need to be trucks, not just tall cars. [/B][/QUOTE]
RedNeckRea is offline   Reply With Quote
Old 11-13-2003, 09:15 PM   #2
RedNeckRea
Member # 16333
here is how we extended the wheelbase...
~Chris
Old 11-13-2003, 09:16 PM   #3
RedNeckRea
Member # 16333
another shot of the springs relocated...
~Chris
Old 11-13-2003, 09:17 PM   #4
RedNeckRea
Member # 16333
with the tub on
~Chris
Old 11-13-2003, 09:18 PM   #5
RedNeckRea
Member # 16333
what we got the wheel base to.
~Chris
Old 11-13-2003, 09:20 PM   #6
FordCarnage
Member # 22955
Not bad, should have flipped them shackles. Trim the ass end of those wheel wells or the tires will eat em. I'm sure that will come in time.
FordCarnage is offline   Reply With Quote
Old 11-13-2003, 09:24 PM   #7
RedNeckRea
Member # 16333
windshield width..
~Chris
Old 11-13-2003, 09:28 PM   #8
RedNeckRea
Member # 16333
and that's all I got at the moment. I'd say it's about 50% complete, but seeing as I can only work on it every other weekend or so I have no iq when it will be done. I know it aint the best out there, but for a college boy I'm gonna be mighty happy .
~Chris
Old 11-13-2003, 09:36 PM   #9
FordCarnage
Member # 22955
Well its coming along man, what more can you ask for? drivetrain sounds pretty solid. it takes time to get these things together when your broke and strapped for time, i hear ya on that.
Old 11-13-2003, 11:15 PM   #10
braxton357
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
I know just what you mean with having little time to work on it cause of school and all. I just got mine to the point that I can drive it on the road, so I'm drivin it around and all of the sudden it dies, I walk to the gas station, get gas, put gas it, it still doesn't start. Turns out it was the ignition switch, ordered one from autozone, they ordered the wrong one..ordered another..still waiting...paid for the second one with quarters and dimes Too many other stories like that to type...if its not one thing its another. Just don't let it get to you
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
98 locked beater xj on N20.
braxton357 is offline   Reply With Quote
Old 11-14-2003, 01:37 AM   #11
RedNeckRea
Member # 16333
been done since this last set of pics cause I knew that was gonna happen
~Chris
Old 11-16-2003, 04:04 AM   #12
tonto
Member # 9872
I think your rig as a lot of potential on the trail, get it finished and lets drag Tim out to do some wheeling.
Later, Francois (Veteran Bronco Alley Biotch).
68 Bronco, 5.8 F.I., A.O.D., 3.8 Atlas II w/32 spline output, Detroits F/R, Full width 44/9" 31spline, 37"X17"BFG/KM's, 17"X8" Allied bead locks w/4.5 B.S., 4whl.disk.
tonto is offline   Reply With Quote
Old 11-17-2003, 03:32 PM   #13
NOTPRETTY
Captain Insano
NOTPRETTY's Avatar
Member # 13482
Send a message via Yahoo to NOTPRETTY
I like the rear stretched, but what about the gas tank? Are you going to move it...go fuel cell? Isn't clearance an issue?
Just go...
Passionately centerist. We're slowly being killed by the far left and far right.
NOTPRETTY is offline   Reply With Quote
Old 11-17-2003, 05:22 PM   #14
RedNeckRea
Member # 16333
got down and worked on the truck this weekend and man was I when I got there. the shop where my truck is located was right on the edge of the freaky storm in los angeles last week, so they got like 10" of rain. well, my truck was left outside and someone forgot that my engine needed to be covered so....I had to drain about 2" of water outta my oil pan . The good part is we got all the water out, hooked up the distrubtor, and the engine fired. Got the car under a tarp now and got all the holes leading to the block covered in plastic. other than that no progress .
~Chris
Old 11-17-2003, 05:26 PM   #15
RedNeckRea
Member # 16333
yes, clearence was a problem. planning on ordering a 20 gal cell from summit. In other projects Tim (the guy who owns the shop where my truck is) just builds custom tanks that work with the issue. But, with my lack of funds and the fact that I could give two shiets whether I have a back seat or not, fuel cell seems like the best option.
~Chris
Old 11-18-2003, 10:59 AM   #16
NOTPRETTY
Captain Insano
NOTPRETTY's Avatar
Member # 13482
Not that I can afford it either, but what would the custom tank cost?
And...It appears the springs will still be stock length...but I can't really tell. Did you change them or consider using a longer spring to reduce the need for the arch?
Just go...
Old 11-18-2003, 12:19 PM   #17
RedNeckRea
Member # 16333
I really couldn't tell you how much the tanks would cost. I just knew that I wasn't planning on having a back seat, so the fuel cell was the easiest way to go. if you are serious about getting a quote on one, pm me and I'll get you a number to call.
and about the rear springs. new ones were considered, but then the $$$ was thought of and hell, they'll work till I can link it .
~Chris
Old 12-05-2003, 09:11 PM   #18
RedNeckRea
Member # 16333
finally got a picture editor so I could re-size some of the pics. here is the hood. the outter slit toward the bottom has been filled so that there are only 2 slits. it has also been primered a dark grey.
~Chris
Old 12-05-2003, 09:13 PM   #19
RedNeckRea
Member # 16333
I think I need to find a way to get some custom flares made . already have plans for flaps.
~Chris
Old 12-05-2003, 09:16 PM   #20
RedNeckRea
Member # 16333
and the grill I get to fix/narrow.
~Chris
Old 12-05-2003, 09:17 PM   #21
RedNeckRea
Member # 16333
another of the grill pre-narrowing..
~Chris
Old 12-05-2003, 09:21 PM   #22
RedNeckRea
Member # 16333
out of order, but how much was taken out of the front of the hood...
~Chris
Old 12-05-2003, 09:22 PM   #23
RedNeckRea
Member # 16333
and the amount taken out of the top of the hood...
~Chris
Old 12-08-2003, 10:01 AM   #24
IronBenderII
Member # 6848
Looks similar to my build up...
Here's where the front was last week. I have since relocated the upper frame mounts to go through the frame/cross member bracket and made the upper axle side link mounts lower for better up travel.
http://www.broncofix.com/board/viewt...745&highlight=
Rear end movd back, tubs extended.
http://www.broncofix.com/board/viewt...639&highlight=
Custom rear gas tank.
http://www.broncofix.com/board/viewt...858&highlight=
Jack
71 1-ton EB
BITD 7200
IronBenderII is offline   Reply With Quote
Old 01-30-2004, 12:21 AM   #25
RedNeckRea
Member # 16333
had these pics for a while, just never updated. it really sucks to have no transportation and be 3+ hours away from your project. nothing new in the past ~2 months other than these little things.
finished hood...well at least finished being cut, re glassed, and primered
~Chris
Forum Jump
