#126 |
Member # 39184
Got a couple of tubes in tonight. i still got 87 feet sitting on the ground, it needs more triangulation
#127 |
Member # 126266
Man your rig is really looking BADASS.. I really like the sliders..everything looks top quality.
1992 Cherokee 4.0 AW4 231w/SYE Dana 60's It's mine and I'll build it the way I want |
#128 |
Member # 39184
#129 |
Member # 39184
those rear tubes go through the floor and cope onto the frame plating top to bottom.
#130 |
Member # 69669
This thing going to see any highway use?
Standard Produce Co. Serving Central VA Since 1910 93 YJ N/A 383 on 'pane 405hp/435tq NV4500 6.34:1 231/300 10.88:1 Locked Tons 5.38's 40's 108" WB Gettin' There
#131 |
Member # 39184
Yep. fully skinned, flared, and mudflapped. bumper heigh is legal, DOT signals/lights. passes emissions super easy.
#132 |
Member # 41059
And back in the day spanked many ricers light to light. Loking good mang
#133 |
Member # 93732
You plan on raising the tank?
#134 |
Member # 39184
#135 |
Member # 69669
I was just curious about how the sliders would perform on road?
#136 | |
Member # 39184
To my knoledge no one has this setup in the front like me I am planning on adding some bilstein 7100 remote res shocks with 12" of travel at all four wheels. and possibly timbren bumpstops if the budget runs out. gonna run a center limit strap in the front to keep my frontend from unloading. havent decided exactly how much downtravel i will allow. suggestions welcome ![]()
#137 |
Member # 39184
FINALLY got my inner fenderwells cut out in the front.
#138 |
Member # 108553
subscribed
#139 |
Member # 142733
#140 |
Member # 93732
Make sure you post plenty of pics of this so I can steal your idea...
#141 |
Newbie
Member # 56394
90 XJ 33 MTR's and some stuff cobbled together to make the tires fit |
#142 |
Member # 39184
If you dont have anything USEFULL to post, dont post at all please.
#143 |
Member # 129959
I didn't see it anywhere in the thread, are those DIY beadlocks? My computer screen sucks ass but they look they are Allied.
Either way, build looks sweet man. I'm especially digging the tube work so far. Last edited by ep191; 11-16-2009 at 07:40 PM. |
#144 | |
Member # 39184
#145 | |
Member # 142733
![]() With 3/8" outers are you worried the inners will cone and maybe crack a weld? Let us know how well they hold air. |
#146 |
Member # 145154
wow sick build man! wondering on belly height with the low stance? considering building one myself with about three inches of lift on 37's minus the extreme fenderwell cutting
cant wait to see how the front inners turn out
#147 |
Member # 39184
Aiming for 20.5" of FLAT belly on the 38's... got the next four days off work. should get something good done tomarrow
The extreme fender cutting is for factory bumpstop placement (relative height) and the 38's.
#148 |
Member # 100778
Looking good marc. Don't remember if I told you or not but I moved over to kitsap so my junks on hold til next month.
I planned on sticking with 3.5" and 35"s, but I'm gonna have to see how yours comes out. 37" rockers might be it for me
#149 |
Member # 39184
got some corbeau baja RS. started work on rear spring sliders. cut off old spring hangers and put some more 1/8" plate on.
#150 | |
Member # 119389
89 MJ-leaf conversion, AW4, d60 welded, hp44 spooled, 5.38's, hydro assist, OBA, flatbed w/LED's! |
