#1 |
Member # 88052
steering box center???
So I have almost completed my power steering install in my Defender 90 using a D1 box. I have centered the steering wheel and box, 3.5 turns lock to lock, so I centered it at 1.75 turns per side. My wheels are straight and I have the 924mm from balljoint center to balljoint center that the Landrover workshop manual specifed for the track rod. But the drop arm is offset slightly to the drivers side. Is this normal?
#2 | |
Newbie
Member # 47968
#3 |
Member # 88052
Is this to compensate for the ball joint hole being offset from center in the knuckle?
#4 |
Member # 21218
Also prevents the box hitting the internal stops if you lose one of the Lock stop bolts.
http://forums.lr4x4.com/index.php?sh...=&fromsearch=1
Tony Defender 90-Modified Last edited by tony cordell; 11-08-2009 at 06:56 AM. |
#5 |
Member # 12499
Location: In the office writing letters to Land Rover's attorney, trying to stay in business,
If you read the manual closer, you will notice that the dimension given is only there to get you in the ballpark and that further adjustment is going to be necessary.
Wrenchin' to riches! |
#6 |
Member # 21218
I think that is clear in the thread?
Tony Defender 90-Modified |
#7 |
Member # 12499
First off, Tony, good to see you here. How've you been?
Perhaps in the thread you linked to, but it was not clear in the discussions here. It is silly to think that Land Rover could hold close enough tolerances that if one were to measure a distance between tie rod ends that they'd be spot-on and not need any fine adjustments! Fortunately, the steering is so simple that is easily achieved.
#8 |
Member # 88052
I centered the steering box, Adjusted the the track rod to 924mm, and the fawkin thing tracks straight as an arrow at max speed of 120km/h. Too easy!
#9 | |
Member # 21218
that's finished now so back to the L/R
#10 |
Member # 7755
Lift requires you to slightly lengthen the drag link. I always try to center the arm on the box.
:evil: |
#11 |
Member # 14944
Mine is off to the driver's side a bit, must be an LR thing. When you center the steering wheel and mount the shaft, the box is not centered on mine. It has nothing to do with the track rod.
92 RRC. Wheels like butt. 68 IIA. ww.ROAV.org |
#12 | |
Member # 12499
The FSM states: 23. If driving straight ahead and steering wheel is offset by 0°to ± 5°in either direction. Remedy by adjusting drag link length. WARNING: To correct steering wheel deviations greater than ± 5°. Remove and reposition steering wheel.
#13 |
Member # 14944
my steering wheel needs to come off then. I would like to switch to a smaller wheel anyway, I just do not want to spend the $$$ for the momo setup. I need to find a way to mount one of those cheap ones I see in all the Jeep catalogs.
#14 |
Member # 88052
In all land rover manuals what Americans call the draglink is called the track rod, a pitman arm is called a drop arm, What americans call the track rod is a Panhhard rod. Hope this clears up some confusion.
#15 | |
Member # 12499
The arm that comes off of the steering box is the drop arm. The tube that runs between the drop arm and the right steering knuckles (LHD) is the cross tube. The tube that runs between the left and right knuckles is the track rod. The Panhard rod is a solid rod that runs from the frame to the axle to maintain the position of the front axle. FWIW, in later years, Land Rover began to use the term drag link, etc. but fo rthe vintage of trucks most of us are discussing, the above nomenclature is consistent with the FSM.
#16 |
Member # 88052
My mother is from Lancashire and I live in french Canada, 15 minutes from Vermont. and every thing I typed came straight out of the 4 Land Rover shop manuals sitting beside my Mac.
#17 |
Member # 20394
I have a custom AL adapter to run a grant or apc wheel. You need it?
2009 King of the Hammers BUCK Wild Racing Team 911 Driver: Me Co-Driver: Pat Quirk Rover Tracks www.rovertracks.com PSC www.racesteering.com DJ Safety www.djsafety.com West Coast Rovers www.westcoastrovers.com Spidertrax www.spidertrax.com JE Reel www.reeldriveline.com |
#18 |
Member # 14944
Sure, what do you need for it? What wheels were you using with it?
#19 | |
Member # 20394
It's a five bolt pattern same as some grants. No adapter. The horn will not work with it. I was using a $10 steering wheel. ![]() If you want to go sexy, and have a spare steering wheel, I can make you a nice one like I made for myself for a MOMO or sparco. The adapter that you can still find is really cheeseball.
#20 |
Member # 14944
how does $20 plus shipping sound?
This would be on an RRC, my horn is on the end of the turn signal. Are the bolt patterns the same?
92 RRC. Wheels like butt. 68 IIA. ww.ROAV.org Last edited by cptyarderho; 11-15-2009 at 10:26 PM. |
#21 | |
Member # 20394
edit: $20 is fine
2009 King of the Hammers BUCK Wild Racing Team 911 Driver: Me Co-Driver: Pat Quirk Rover Tracks www.rovertracks.com PSC www.racesteering.com DJ Safety www.djsafety.com West Coast Rovers www.westcoastrovers.com Spidertrax www.spidertrax.com JE Reel www.reeldriveline.com Last edited by Buckon37s; 11-15-2009 at 10:35 PM. |
#22 |
Member # 14944
Buck- pm sent, sounds good to me.
