Old 10-20-2009, 07:45 PM   #1
sha_ba_do_bang
Member # 69347
LCG TJ build
It seems like everytime i come on here i find so many freaking 1 ton TJ builds,
I wanted to do something different, something low, stable and unique.
So here is my 1997 Tj i bought totaled this past winter.
Stock 4cyl with 2.5 rough country lift. And some bald 32 TSL's
I highlined it and took it to URE to give it a proper beat-in
It did really well, i blew the motor, bent the shit out of the front end and tie rods. But I had no problems with the axle or driveline.
Then we added a 8.8 rear with a triangulated 4 link. Also stretched the frame and moved the axle back 12" to make the comp cut look cooler
I also swapped a 4.7 stroker motor with electric fan, ax15 and new radiator
Next up was the roll cage and paint, also herculined the interior of the tub and the custom tube body work.
sha_ba_do_bang is offline   Reply With Quote
Old 10-20-2009, 07:47 PM   #2
sha_ba_do_bang
Member # 69347
More paint work in our huge paint booth
I couldn't be happier with the final stance/look
It is amazingly stable running the 36x12.50 TSL;s with 1.5" wheel spacers.
I have a rubi 44 coming this week as well as a 4:1 transfer case planned. I have an ARB for the rear 8.8 to run with the stock rubi front locker. I am also upgrading the front axle to the larger knuckles and brakes off of a WJ i think. The front suspension is also going to be long armed and possible air bumps all the way around.
I hope to wheel it again in the next week or so and I'm sure I will have more things to improve on and fix.
There are more pictures here www.per4manceinnovations.com
Old 10-20-2009, 11:44 PM   #3
bardenk1
FCUKTARD
bardenk1's Avatar
Member # 93306
looks nice only thing i don't like about it is the front squat. put some 4" coils in the front to boost it up or 1.25" spacers. jeeps don't sqaut (unless you got a suckdown winch)
bardenk1 is offline   Reply With Quote
Old 10-21-2009, 06:08 AM   #4
sha_ba_do_bang
Member # 69347
The front only squats in a few pictures before I added the coil spacers.
It sits level now
Old 10-21-2009, 06:12 AM   #5
cavaliers1323@aol.co
cavaliers1323@aol.co's Avatar
Member # 69669
I like the ring gear axle support. No offense but uhh I don't think the build is very unique, sorry.
Standard Produce Co.
Serving Central VA Since 1910
93 YJ N/A 383 on 'pane 405hp/435tq NV4500 6.34:1 231/300 10.88:1 Locked Tons 5.38's 40's 108" WB Gettin' There
cavaliers1323@aol.co is offline   Reply With Quote
Old 10-21-2009, 08:44 AM   #6
YellowJK
Member # 113620
Originally Posted by cavaliers1323@aol.co View Post
I lke the ring gear axle support. And uhh don't think it's very unique, sorry.
x2 how ever it is the first time ive seen it...
nice build
'05 Softcore TJ
When I taught my dog to roll over, I didn't know my jeep was Listening!
YellowJK is offline   Reply With Quote
Old 10-27-2009, 02:57 PM   #7
sha_ba_do_bang
Member # 69347
My jeep flex's more than yours!
Here are the obligatory poser forklift flex pictures courtesy of my new fork lift.
Not bad for 2.5" of lift and stock short arm front suspension
I also got a rubi 44 for $300, the axle tube was bent so a little bottle jack and chain action got that straightened back out.
The 8.8 is also getting a ARB and 5.13's next week.
Old 10-27-2009, 03:35 PM   #8
SwampFox89@aol.com
SwampFox89@aol.com's Avatar
Member # 120166
Send a message via AIM to SwampFox89@aol.com
^^ Not gonna lie, that bottle jack set up looks sketchy
Knowing my luck, I'd take the jack to the nads when it slipped off the tube...
oh, nice rig
'76 CJ-5 '83 CJ-7
Lift it! Fat chicks can't jump!
SwampFox89@aol.com is offline   Reply With Quote
Old 10-27-2009, 03:51 PM   #9
sha_ba_do_bang
Member # 69347
Yea it looks sketchy, we tack welded the chain to the jack and the jack base to the axle tube so it couldn't slip off and shoot out.
The biggest problem was the spring back, we ended up heating the opposite side of the tube red hot and quenching it to get it to stay perfectly straight
Old 10-27-2009, 06:38 PM   #10
YredJ
YredJ's Avatar
Member # 130903
Nice work with the straightening, thats quality engineering, I would never of thought of that method.
STRAIGHT UP GANGSTA FAB!!! AIGHT BRUTHAS
YredJ is offline   Reply With Quote
Old 10-28-2009, 08:24 AM   #11
Member # 69669
Are you planing on beefing it up at all?
Old 10-28-2009, 08:13 PM   #12
stjjames
stjjames's Avatar
Member # 51899
I dig mang !!
any new wheeling or overall shots ?
The sky was your playground . . .
stjjames is offline   Reply With Quote
Old 10-28-2009, 08:25 PM   #13
kirbyiv
K^2
kirbyiv's Avatar
Member # 49704
Send a message via AIM to kirbyiv
you know that makes steel more brittle, right?
I dont believe I would run that front axle, especially considering it has dana 30 tubes on it in the first place. The only thing you are gaining over the 30 is a larger r/p. Why not go with a waggy 44?
Slinky Blue Ballz
http://www.pirate4x4.com/forum/showthread.php?t=551947
kirbyiv is offline   Reply With Quote
Old 10-28-2009, 08:51 PM   #14
dozer_xj
dozer_xj's Avatar
Member # 90594
Location: Illinois, Far enough south that we dont call soda "POP"
I dont care much about your bottle jack like everyone else but the jeep looks AWESOME!
Check out Effingham Jeep Club at http://www.f-n-hamjeepclub.com/
For Sale:Toyo competition tires
Originally Posted by ashmanjeepXJ View Post
I love seeing leafs on [the front of] a cherokee. Its like having a mohawk at church.
dozer_xj is offline   Reply With Quote
Old 10-28-2009, 09:09 PM   #15
Milky
Member # 96014
I like how you used the stock brackets on the rear and raised the frame. I did the same thing on my build. Here's mine.
And as far as the Rubi front goes. Before I started my 60/70 swapp this is what I did to mine.
Back side....
Nice work.
V
The American Indians found out what happens when you don't control immigration.
Milky is offline   Reply With Quote
Old 10-28-2009, 09:15 PM   #16
joe_and_jeep
Member # 40665
Send a message via Yahoo to joe_and_jeep
Yea, but they sell Longfields for the Rubi axle. Then you still have the crappy unit bearings and weak ball joints.
2002 Harley Softail For Sale - PM me.
Tellico Rally #610
joe_and_jeep is offline   Reply With Quote
Old 10-28-2009, 09:56 PM   #17
Pirate Joe
Member # 140656
I'm loving this build. Can you post some more pics of the fenders? I really like them.
-Joe
Pirate Joe is offline   Reply With Quote
Old 10-29-2009, 05:01 PM   #18
gtxracer
gtxracer's Avatar
Member # 25303
Send a message via AIM to gtxracer Send a message via Yahoo to gtxracer
The tubes are still tiny. I would rather build a Waggy 44 for something like that. Rubi 44s are cool but you have to dump more money into them unless they came stock on your rig. With the money you spend on a Rubi44 (not his, but most), you could have built a budget 609 hybrid.
2004 Nissan Titan for sale/trade
2004 Ford F-250 PSD for sale
gtxracer is offline   Reply With Quote
Old 10-29-2009, 08:43 PM   #19
kirbyiv
K^2
kirbyiv's Avatar
Member # 49704
RCV is coming out with 300M cv shafts for the waggy 44 soon.
Slinky Blue Ballz
Old 10-30-2009, 11:16 AM   #20
feva4u
feva4u's Avatar
Member # 28865
V
If you swap the stock rear brackets to the opposite side in the rear you don't have that goofy ass triangle piece hangin out FWIW.
My build here: greatlakes4x4.com/showthread.php?t=111464
feva4u is offline   Reply With Quote
Old 10-30-2009, 01:47 PM   #21
sha_ba_do_bang
Member # 69347
I got the rubi axle for $300
I am building a truss for it when i do the coilovers and bumpstops.
I didn't go with a waggy 44 because of the lug pattern, converting it to five sucks, and then the rear axle still won't match. And it has a air locker that i can use for time being and I wanted to!!!
I'm not running any larger than 38's so some chromo axle and an arb in the 44 will make it pretty stout.
Old 10-30-2009, 08:11 PM   #22
Milky
Member # 96014
Yeah, I noticed that to when I flipped them, but if you run them with the "goofy ass triangle piece" out, the springs are further apart on the axle and frame rails for better stability. I'm going to cut them off and box in the bracket when it's all said and done.
Old 11-03-2009, 01:09 PM   #23
sha_ba_do_bang
Member # 69347
-Joe
Here you go...
Old 11-03-2009, 01:19 PM   #24
01TJCRAWLER
ROCKS RULE
Member # 117427
your tire is crooked.
01TJCRAWLER is offline   Reply With Quote
Old 11-03-2009, 06:42 PM   #25
Jeepman14wheel
Jeepman14wheel's Avatar
Member # 46071
oh, nice rig
X2, that is some funny sh&t! It would get me for sure!
If you argue with an Idiot, it is hard to tell who the Idiot really is!
Jeepman14wheel is offline   Reply With Quote
