#1 |
Member # 1176
Need some sb rams horn plug wirees
I have searched and even looked through boxes plug wires at the parts store and can't find what I need.
since i put chevy rams horns exhaust manifolds on my sb 350 i want to use straight boot plug wires that fit a HEI distributor. I have been told the bb chevy might work ,,, need to know what early years went hei and what application, car , truck.. anyone know? I'm not real familiar with big blocks.. what year application would you suggest? thanks
June 28th 2003 Last edited by Berg; 07-11-2005 at 11:33 AM. |
#2 | |
Member # 6582
Try a mid 70's Vette, see what they look like and go from there.
[QUOTE=Muddin]You must be able to blow harder than me [/QUOTE] [QUOTE=Bubba Ray Boudreaux]Shooting is gay.[/QUOTE] |
| Sponsored Links |
#3 |
Dabbler
try a 1969 corvette
#4 | ||
Member # 6582
#5 | |
Member # 6582
#6 |
banndededed
Member # 29016
just buy a set of accel "cutsom fit" wires 20-30$. you can get straight or ninties,just cut to length. they will come with both hei and points ends.
i dont like straight boots, the have a tendency to pull the terminal end off the wire accel or stock.
S&H 4x4one of the only 4x shops that you can buy production tcases, trannies and axles, as well as the cool shit. 916-927-3919. |
#7 |
Member # 9991
I used the Accel wires that you make up the end for the distributor yourself. After your done, check them with an ohm meter to make sure you did it right.
[url]http://www.scotthansen.net[/url] Last edited by MrWillys; 07-11-2005 at 06:31 PM. Reason: picture |
#8 |
Member # 38880
I would build my own wires you get exatly the length and the ends that you need. I like the MSD wires. The initial investment is more expensive but once you buy the proper crimping tool the wire and ends are not really any more expensive than a good set of wires. My .02$
#9 |
Member # 34756
If you don't adamantly want the wires to go over the Rams Horn manifolds then, as mentioned above, a '75 vette had HEI with Rams horns. The wires have 90º boots and are routed down the back of the engine and up to the spark plugs. It's not as *cool* looking as over the top wire routing, but underneath routing easily prevents wires from making direct contact with the Rams Horns.
<>< Worthy is the Lamb that was slain to receive power, and riches, and wisdom, and strength, and honour, and glory, and blessing. |
#10 |
Member # 39602
2nd MSD DIY wires... I think you can bend the straight boots to whatever angle you want. I don't like Accel stuff much because of spotty quality issues.
#11 |
Member # 44136
Get wires for a late 70's ford with electric ignition and a windsor block. I run them on my ram horns. They work great and have straight boots.
| Thread Tools | |
| Display Modes | |
