#1 |
Shenanigengineer
Member # 33543
tractor supply or chief rams for full hydro?
Anybody got info on using the rams from tractor supply for full hydro? I saw a bunch of rigs at summertown running them. Pros? Cons?
Thanks Matt I searched but found nuthin
BustedKnuckleFilms.com "SOUTHERN SHENANIGANS" the DVD Order it now for only $19.95 shipped
#2 | |
Pilot in training
From my limited knowledge (I do run full hydro - but DE cylinder and load reactive valve) the orbitals used for SE cylinders are non load reactive - no feedback to the wheel. I think it would be fine for off road only - but maybe not as good a choice if there is some street time. Also, your steering will take more turns one direction than the other - something to get used to. DE cylinders are same lock to lock. The reason for the SE turning difference is the fluid bypass when turning one way or the other. Someone will chime in with more answers - but it has been covered so search a little more.
1968 Jeepster, turbo'd |
| Sponsored Links |
#3 |
Member # 17654
Mine work fine (front and rear), cheap enough I can cary a spare.
Trail only, I've had it on the street and it isn't that bad, but not a good idea. |
#4 |
Shenanigengineer
Member # 33543
Why is it so bad on the street?
#5 |
Member # 14059
Because there is no return to center, no road feel, and no mechanical linkage connecting the steering to the wheel. Blow a hose and your in for a hell of a ride.
"free 71PA_Highboy!" |
#6 |
Member # 22799
A Single Ended (typically non ballanced) ram will work well for a rear steer app. It will also work for a front steer as well, but with some drawbacks. One will be a 'walking' steering wheel due to the unbalanced nature of the ram. If you are running a stock steering wheel with any kind of hook up (airbag, radio controls, etc) you will eventually run out of slack on the connectins and have to 'rewind' the wheel. Plus you will constantly have to correct for the wheel walking as you drive. I also found that the steering was quicker on way than the other.
You can use a load reactive valve on a SE ram. In my opinion, go with a double ended balanced ram.
-- Hero |
#7 |
pimpin' IS easy
My previous rig used one, but i won't go that route again, this time it will be double ended.
#8 | |
Member # 17654
No mechanical linkage Unbalanced cylinder makes it faster turning in one direction than the other. As far as return to center/ road feel, that is affected by the orbital valve as well. It never bothered me to run 55 mph with an open center non-reactive valve. And mine is so slow that the unbalanced ram isn't uncontrollable. |
#9 |
Shenanigengineer
Member # 33543
I have an aftermarket steering wheel and no controls or cruise on it so that wouldnt matter. Im doin an sas on a tacoma not my DD but i would like to drive it around town a little bit and to close by trails. I looked into this setup becuase i can easily do this for just a little more than regular steering. But if there is no way to be able to drive it on the road at like 65 then ill have to figure out sumtin else.
#10 |
Close by wheeling spots would be the Gardendale area... so a 2-2.5 hour drive on the highway or interstate.
How would those 2 hours at highway speeds be compared to just driving around town? Just want to know what some of you consider working okay for a little around town road use. |
#11 | |
Member # 17654
2.5" bore 8" stroke unbalanced Tractor Supply ram. ($74) Regular P.S. pump (1-Ton hydroboost with pressure mod) ($35) 7.3 gpm Dan Foss Orbital (open center non reactive) ($399) Narrowed Rockwells, hubs out, welded (front/rear) 44's Trailer Queen I've ran mine at 55mph about 3 times on country roads with no one around. Mine is not for interstate use. I could kill people. Now, country roads (35 mph), to and from the trail, that's a different story. As long as I don't blow a line... Just my opinion Last edited by Aaron871; 01-11-2006 at 12:27 PM. |
#12 | |
Member # 17654
I would never concider mine on the hwy. Well, I might go one exit down if it was an emergency and I was stuck on the back side of Stagecoach and the gate was closed. But not 2 fawkin hours, no way, not even with a ballanced ram and reactive cylinder. With my luck I'd blow a line and drive over a church bus... lol |
#13 |
Member # 2129
I run a SE chief ram and a load reactive orbital. It doesn't walk and has return to center. It's trail only though. I don't ever really notice that it takes more turns one way then the other. I just turn till it hits the stops most of the time. Been running it for 2 plus years with no problems.
startin' in the lucky 13 spot KOH 10 9th place KOH 08 16th place KOH 09 http://www.ballisticfabrication.com/ LetzRoll Offroad www.letzrolloffroad.com 480 797-0469 |
#14 |
Member # 8965
The unbalanced nature will really show itself with short stroke systems. I only require 5" of stroke on mine, and need a 2" bore. I could not get the unbalance to an OK level unless I only had a 1" shaft size. I figured that was a bit small to be reliable. So I spent the extra $100 and bought a balanced ram from surpluscenter.com. I think I will be happier with it.
I did take my buddies buggy for a quick drive. It has an unbalanced ram, but it is 8" of stroke and 2.5" bore, thus able to hide some of that unbalance. His drove great. Which is backed up by his 70 mph runs out to the trail heads in the Hammers. -Wayne
[URL=http://www.pirate4x4.com/forum/showthread.php?t=364808]Short version of my buggy build thread.[/URL] [URL=http://www.pirate4x4.com/forum/showthread.php?t=392230]Low rider trailer for the buggy.[/URL] [URL=http://www.pirate4x4.com/forum/showthread.php?t=583138]My Samurai project.[/URL] |
#15 |
Shenanigengineer
Member # 33543
I was planning on a 2 inch bore with 8 inch stroke. I have a f150 hp dana 44
#16 |
Shenanigengineer
Member # 33543
If I bought a little bit better ram would I be better off?
#17 |
SchuitOverBuilt
i guess i just dont understand WHY?
the doble ended ram is only $200, it uses the same amount of lines, 2 extra heim's and less material for the tie rod. yes mounting is more trickey but it seems like a no brainer to me. |
#18 |
Shenanigengineer
Member # 33543
Will a double ended cylinder be alot better on the road?
#19 | |
SchuitOverBuilt
| Thread Tools | |
| Display Modes | |
