#1 |
Cheap deals on 2x6 and 2x8" Hy rams
Baileynet.com has the 2x6 and 2x8 Tie rod, clevis ended hyd rams on sale right now
p# - 219-008 2x6.5" 49.00 (perfect for a LC axle) p# - 219-766 2x8" 49.00 (Perfect for Dana axles) Time to go hydro assist
DEAR MADAM: THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE. YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY. PLEASE SELECT ANOTHER ITEM. THAT'S OUR FIRE EXTINGUISHER |
#2 |
TLCA #5305
Member # 8568
Those are cheep
2010 KOH Team CrossedUp Mike Klensin and Justin Reece. Starting 7th 2009 KOH Team 435 Finished 35th. THANKS Moab MS High Angle Crossroads Fitness Maxxis Tires |
| Sponsored Links |
#3 |
Member # 752
No 1.5's??
Josh C. TOTR , ECV7-11 RanchFab.....opening soon |
#4 | |
4X4HIM.COM
Member # 34369
surpluscenter.com page 38 of their catalogue...item # 9-6645.... 1.5"x8" double acting cylinder for 49.95......this is the cylinder i have on my cruiser....i cut off the ends and welded heims on it and use it as a assist cyl... works good so far....
chris
#5 |
Member # 18907
can you get away with running an 8" on a LC axle? I will be changing to a Dana soon and dont want to buy two rams.
#6 |
You can if you limit the ram
#7 | |
4X4HIM.COM
Member # 34369
i limited my ram with an internal "plug" that was 1" long made of derilyn? ( i think thats how its spelled) basically hard plastic. lines were 15 bucks-ish and about another 12.00 in fittings. 38 for the p/s box gasket kit from napa and an evening of time to teardown, clean, drill-tap the saginaw box and reassemble. figure another couple bucks for brake-clean, p/s fluid etc.... BTW i paid 52.00 for my ram shipped when i bought it... heims i already had.....
chris
| Thread Tools | |
| Display Modes | |
