Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 06-21-2007, 10:40 AM   #1
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
Mythbusters plastic mold trick
If anyone has ever seen the epidsode of Mythbusters where they build Buster II from scratch, you'll remember the vacuum mold machine they used to create the molds out of plastic to make Buster's flesh out of. Basically what they did is carved the body pieces out of foam and placed the pieces on a table inside of a vacuum chamber that had a sheet of clear plastic at the top. They then heated the plastic until it was pliable, lowered it down onto the molds, and applied vacuum to the underside of the plastic to form it perfectly over the foam "decoys."
I would like to do something similar for a buggy hood, mianly because I want something unique, but also because no factory hood is easily workable for my buggy. Carving the foam decoy would be easy, but creating a vacuum chamber would probably be fairly difficult. (Vacuum source would just be a shop vac.) It would also be difficult to heat the plastic evently so that it would form right.
I was thinking that it may be possible to do something similar with a heat gun and some clear plastic stuff. (Forgot the actual name for it right now, but you can get it at Lowe's.)
Anyway, what are your ideas? Heat gun plausible? Vacuum chamber plausible? If so, how woudl I heat the sheet of plastic effectively.
J. J.
www.patooyee.com
Build thread
patooyee is offline   Reply With Quote
Old 06-21-2007, 10:58 AM   #2
Scout Dude
Member # 4001
Mike (login name on here) made a vacuum thing for doing wood laminate. See if he can help you.
Dysfunctional Rockcrawlers
Scout Dude is offline   Reply With Quote
Old 06-21-2007, 11:00 AM   #3
sn0border88
Master Apprentice
Member # 56692
why not make the foam mould and take it to somewhere that does it. I doubt they would charge much.
1992 Explorer SAS'ed on HPD44/9" W/ 5.13 Locked F/R 36" TSL-SX on DIY Locks
sn0border88 is offline   Reply With Quote
Old 06-21-2007, 11:03 AM   #4
sceep
SchuitOverBuilt
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
mold it then lay glass.
http://www.boogerwelds.com
Scale RC gravelmaker build!!
Originally Posted by Travis Waldher View Post
I hate pussy
sceep is online now   Reply With Quote
Old 06-21-2007, 11:10 AM   #5
RickyRetardo
Celebrate Perversity
RickyRetardo's Avatar
Member # 74849
X2 on making the mold and laying fiberglass. In the long run, it might be cheapest way to go as fiberglass is pretty easy work with and to fix, or if it's completely destroyed you could make a new one in no time.
RickyRetardo is offline   Reply With Quote
Old 06-21-2007, 11:12 AM   #6
CrashKnott
Member # 37403
It's called thermo-forming, and it's not as easy as they made it look. Plastic is some particular stuff when it comes to melt temp, versus burnt plastic.
Scout Dude's got some good advice though...make it out of whatever you can, then try and find somebody who does thermo-forming. Keep in mind, the size of the "bed" of the thermo-forming machine will likely dictate how big your hood can be (usually beds are 36" x 36")
A more feasible solution would be to carve it out of foam or whatever, then lay fiberglass over it. You can either use that fiberglass piece to make your hood, or as the negative to pour some acrylic or 2 part something into for your hood...all depends on what you're trying to do and how much effort/$ you wanna put in.
Good luck!
-I seem to remember someone making buggy hoods out of clear acrylic kinda recently.
CrashKnott is offline   Reply With Quote
Old 06-21-2007, 11:33 AM   #7
jpmassey
Yep
jpmassey's Avatar
Member # 52710
We did this exact same thing for a race car body a few years back. I built molds out of foam (spray can stuff) and wood, layed fiberglass on top, and then smoothed it out with bondo.
The trick is to heat the plastic to the right temp, too little it doesnt form, and too much it turns liquid. I ended up building a big oven, basically a big metal box made from an old AC system, and adding several 220v oven coils inside. It allowed the temp to be held constant and even.
The plastic was clamped in a wooden frame, and when ready, was simply removed from the oven and pulled down over the mold. We had drilled hundreds of holes in the mold to pull a vacum with, but it turned out to be much more effective just smoothing it out by hand.
Slowly building:
http://pirate4x4.com/forum/showthread.php?t=530478
jpmassey is offline   Reply With Quote
Old 06-21-2007, 11:35 AM   #8
Triaged
Member # 5110
x3
Read some of the how-to articles here
http://www.fiberlay.com/
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote
Old 06-21-2007, 11:36 AM   #9
guidolyons
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
J.J.-
I assume you would be using the vacuum mold to make the mold, then lay fiberglass for the actual hood.
I think it would be fairly difficult to make a vacuum mold and get a sheet of the plastic large enough to make a mold for a buggy hood, probably cost prohibitive for a the few times that you would use it.
Years ago in college I took a plastic manufacturing class and we had a small 2'x2' vacuum mold. It had a large heating element similar to a heater or an electric stove, held the edges of the plastic sheet firmly you ran the heating element until the plastic got soft, then lowered it over the mold, the lower half had a bunch of small holes like an air hockey table to draw the air out.
Yes a shop vac would work, the challenge would be heating the sheet evenly, getting it into place, drawing the vacuum evenly, all before it began to harden again. I honestly don't think you could heat a section at a time, it would have to be done at once. Also, the plastic sheet (Polystyrene IIRC) sheet hardened fairly quickly and was pretty brittle once it hardened. Not all plastics can be used for vacuum forming, and fiberglass resin will disslove polystyrene.
I doubt that a vacuum bag like woodworkers use for laminates would work, because of the heat invovled.
Like snoboarder said, make a "decoy" form you like and check around and see if you can get a few molds made from it from a plastics place that has a large vacuum mold. Maybe somewhere that does boats?
Or go ahead and make a mold from fiberglass, then use the fiberglass mold to make your hood.
1965 Scout 80 7.3PSD/ZF/203/205
Originally Posted by General Dwight D. Eisenhower
History does not long entrust the care of freedom to the weak or the timid.
David H. Petraeus for President 2012
guidolyons is offline   Reply With Quote
Old 06-21-2007, 11:38 AM   #10
paulkeith
Member # 18543
its already been said, but fiberglass man. it will still be easy to get a unique shape, and is relatively cheap if you buy bulk scrap glass (check ebay, they sell it by the pound). get a block of foam, cut/hotwire/sand to the shape you want it, and lay the glass. pull/scrape the foam out, sand/bondo the top, prime, and paint if you want to. done and done.
dd/tow: '02 4x4 powerstroke 6spd manual ext cab shrt bed, lifted, straight piped, and chipped
rig: buggy, begun 3/05, 350/465/205/60/14/39.5 transplant in progress
paulkeith is offline   Reply With Quote
Old 06-21-2007, 11:56 AM   #11
soilantgreen
Black Terror!!!
soilantgreen's Avatar
Member # 70321
One of my customers is a large wholesale supplier of acrylic pan faces for interior lighted signs. (You know, those signs that have the lights on the inside that, at night, light up so you can still read what the sign says?) He builds such big faces that he has invented his own giant ovens for making them. A large sign shop like that could make what you want, BUT fiberglass would be so much easier.
Originally Posted by Kurtuleas
The problem with the OHV and 4x4 community is that people only fight for their own backyards. If we can all come together as one voice and fight for each others trails, do you know how powerfull we could actually be?
That's why I made that promise on Pirate 3 years ago: Tooth and nail for every trail.
Originally Posted by Ripley
"I say we take off and nuke the entire site from orbit."
soilantgreen is offline   Reply With Quote
Old 06-21-2007, 12:11 PM   #12
ZukIzzy
Member # 50632
Fiber glass is easier but I have built several airpalne canopies from plexi and it is doable. Your oven can be plywood or even a large cardboard box for a one time thing heated by a couple heat guns or electric shop heaters and vacume from a shop vac is fine. You have to build a plug or mold and then work out the vacume. Pool table felt is your freind . You cannot heat form Lexan in a home shop. It will haze and "craze" ( thousands of small cracks) when you heat it exposed to air. I have tried and could not get it to work.
wayne
KOH starting position #48
Longfield Super axles
General Tires
ZukIzzy is offline   Reply With Quote
Old 06-21-2007, 06:40 PM   #13
upnover
metal manipulator
upnover's Avatar
Member # 17729
I have done some reverse molds using Rhino Linings. It's pretty fast to do due to the fast set up time and in the end its less prone to cracks and breakage than fiberglass.
Wayne
Up and Over Innovations Inc. ------4wd sales,service and fabrications
Rhino Linings of Aston-------#1 spray-on liners
610-358-3179
W.E.Rock team#504 Unlimited http://www.teamupandover.com
upnover is offline   Reply With Quote
Old 06-21-2007, 07:31 PM   #14
LT1SCOUT
Member # 31414
Originally Posted by jpmassey View Post
im pretty sure that thing was deemed a giant fire hazard, taken out back, and shot.
My '91 CJ build
http://www.pirate4x4.com/forum/showthread.php?t=569010
LT1SCOUT is online now   Reply With Quote
Old 06-21-2007, 07:37 PM   #15
kiyul4130
Member # 37026
J. J.
did you watch that episode yesterday? cause i know i did.
ECV 7-11
RIP troy & daniel, KYOTA Forever.
kiyul4130 is offline   Reply With Quote
Old 06-21-2007, 07:39 PM   #16
patooyee
Pirate4x4 Addict!
patooyee's Avatar
Member # 4821
Yes, but I think it was a rerun, right?
J. J.
www.patooyee.com
Build thread
Old 06-21-2007, 09:58 PM   #17
heep86
Member # 13090
jj, if you still know anyone at auburn, then find someone in industrial design. when i was there we had 2 vaccume formers. one would accomodate 4 x8 sheets of polystyrene. the students should have after hours access to it. i dont think the heat gun will work, you need to heat the whole sheet at once. give me a call and i'll tell you more about the process
Mike Ward
[url]www.undergroundoffroad.homestead.com[/url]
205-233-1802
heep86 is offline   Reply With Quote
Old 06-21-2007, 10:02 PM   #18
ThatKid
Member # 84865
Vacu-Forming is expensive and hard.
Fiberglass would be a shit ton easier, and cheaper.
ThatKid is offline   Reply With Quote
Old 06-22-2007, 02:57 AM   #19
nissancrawler
nissancrawler's Avatar
Member # 76684
I think fiberglass would be much better for repair, too. If it cracks, file it out, fill it with some kitty hair and resin, and off you go again. If you want to get really lightweight, you could use microbeads, too.
Originally Posted by nahmus View Post
asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.
nissancrawler is offline   Reply With Quote
Forum Jump
