Share | Thread Tools | Display Modes |
#1 |
Poseur SUV ®
TOTW #1: Pig Shave - Building a 14 bolt that doesn't sacrifice ground clearance.
Lets get a discussion going on shaving a 14 bolt for better ground clearance. All you guys who have done it let us see what you've got. If you've got questions lets hear them.
Paul Gagnon Sherwood Park, Alberta eh? "No Brain, No Pain" pirate4x4.com King of The Hammers Coverage! |
#2 |
Member # 4526
I want the cut/plated 14FF that was in the mags a few months back.
Shave the ring gear, cut the bottom of the pumpkin, weld plate across the bottom. It would need a heavily modified cover to keep it from leaking with the small sealing surface.... |
| Sponsored Links |
#3 |
Member # 9610
Shaving the pig on the 14 bolt is the best way to increase ground clearance by far (Aside from tire size) but how far does one have to go? Cutting the housing and shaving the ring gear is great for an extra inch or so, but that is a lot of work, and if the ring gear is damaged, you have to have it shaved again. When I get around to mine (College Sucks), I am just gonna shave the lip off of the bottom to get rid of the ditch digger impersonation in ruts. It is easy, cheap, retains the carrier strength without having to weld plate, sealing is retained, and the internals won't have to be machined again if they ever fail. Just my $.02. If anyone does have pics of a more involved shaving, I would love to see them posted up for sure!
Duct Tape is like the force, it has a light side, a dark side, and it holds the universe together. |
#4 |
Pirate4x4 Addict!
Member # 12429
14b
I shaved my 14b here are pics.
http://4x4help.com/axle/pics/shaved/14b/index.htm Write-Up coming soon! |
#5 |
Donkey Hunter
I would like to know exactly what tooling guys are using to cut the ring gear. If your not grinding it, what grade of insert are you using, What RPM, ETC. I think a water jet would be the way to go, but I dont have access to one.
What Rod are you using to weld the plate on the bottom? What temp are you pre-heating the housing to? What are you using to insulate the housing for cool down? Has anyone measured how much the housing distorts cause of shaving the diff? Ever heard of stress relief? Who many shaved diffs are daily driven? and hows the bearing life?
#6 |
Donkey Hunter
some what off topic, but directly related to modifying the 14 bolt: Has anyone ever tried to remove material from the diff housing to save weight?
#7 |
Member # 5691
Heres mine.2 cuts with a sawzall and smoothed it out with a flap disc on my 4.5" grinder.I took as much off as I thought I could without getting into the bolt holes.
![]() A shot from the back. ![]()
The Woohoodilly- 69 FJ55-350/465/203/205,D60/ARB,D70/Detroit w/5.86s,42"IROKs on H1s Last edited by FRIZZLEFRY; 02-18-2003 at 08:36 AM. |
#8 |
Pirate4x4 Addict!
Member # 12429
Yep - I cut as much off to without getting into the bolt holes, I will take another pic tomorrow and measure how much I left between the bottom bolt and axle lip.. I can actually grind a lil more off... but haven't..
I used a 4.5" Grinder to do ALL my work I just didn't like the way the sawzall cut this stuff, after I used the cut-off wheel I ground it down so that it would slide over rocks and not even have a lip.. I also grinded my 14b Diff guard to match the axle too... Pretty easy just took a while with the small grinder |
#9 |
Member # 4001
I have a friend who cut the bottom out, turned the ring gear down, and made a new cover that bolts to the back, bottom and the front pinion support. It is not welded onto the housing.
He says that it has ~1/4" more clearance than a D44. I have seen it and it does have a shiat load of clearance. I was thinking about having him do mine for my comp vehicle but I decided not to use a 14 bolt afterall. BTW, the bottom cover is 1" plate machined with a groove for the ring gear to fit into. If I ever get back up to his place, I'll get pics.
Dysfunctional Rockcrawlers |
#10 |
Member # 4830
I cut and shaved mine. shaved the ring gear with a hand grinder. Welded in a 3/8" plate with gussets on the inside and remade the cover.
I can do all that but I'm too stupid to post pics!!! All I have is a yahoo pic account and I don't think they allow it. Can I send them to someone to post for me? blake Last edited by HeyBeerMan; 02-18-2003 at 05:57 PM. |
#11 |
Member # 2143
the full brazil
here's a pic of my bro's shaved 14 bolt diff
Outlaw , 604 539 1818 Last edited by AIRZUKI; 02-18-2003 at 05:35 PM. |
#12 |
Member # 10049
Here's Mine:
Cut Housing using a skillsaw and finished it up with a mini grinder
Jimbo |
#13 |
Member # 10049
Welded on the 1/2" plate. I had to put a 1/8" groove in it to clear the ring gear as I left the gear it's full thickness.
Jimbo |
#14 |
Member # 10049
Cover done, drilled and tapped the bolt on the right. Housing ground and shaped.
Jimbo |
#15 |
Member # 10049
Brakes:
Jimbo |
#16 |
Member # 10049
Done Deal:
Ya, I know the 35 Boogers are too small, and this is a Chevy thread but
Jimbo Last edited by pumpkinhead; 02-18-2003 at 06:43 PM. |
#17 |
Member # 4352
[IMG]DSC00160.JPG[/IMG]
No idea if this will work but here is a pic of mine. |
#18 |
Pirate4x4 Addict!
Member # 12429
pumpkinhead - That looks sweet! Eventually I want to get that done! But since I can't weld (no welder and haven't learned) I have to wait until I can afford to have a friend do it...
That is awesome looking though!! |
#19 |
Member # 4526
More pics/links/comments from CK5.
http://coloradok5.com/forums/showfla...t=1#Post668763 I still want one of the flat plate designs....
#20 |
Member # 4830
Just for the record. I trimed my ring gear abut 3/8" with a 9" grinder. I took out the pinion. Left it set up on the carrier and in the housing. the second I touched it with the grinder. It started spinning. And depending on how you held the grinder, is how fast the ring gear spun. But trust me it could get going scary fast. It never heated up the gear. Then I took a 4" grinder with a 60 grit and beveled the edges. Been in use 1-1/2 years. I had it apart about 3 months ago and it looks perfect.
#21 |
i dont have any experience with this subject except what is on this BB, but i was wondering if people take into account their pinion angle when shaving(as in take a little more off the cover too), or if everyone just cuts it straight across like at 0 degree pinion angle???
- Jake |
#22 | |
Member # 4001
#23 |
Member # 8703
do you guys think that the bottom of the axle is durable after yall do that? seems like if you hit a rock it might fawk it up.
"i had a cj5 with four wheel drive and Smokey's on my tail" boggers, 400hp, 1/2 ton axles, and beer. we can make it. |
#24 |
Member # 41
I think 1/2 inch plate will be durable enough. My toyota housing has been drug over a ton of rocks, and it holds up fine. I think it is about 3/16 thick.
#25 |
Hello Govna
Member # 28812
pretty sure 1/2" plate decently welded will work fine.
Custom Fiberglass CJ, TJ And X Chassis Hoods Now Available YJ, JK And FJ40 Hoods Coming Soon RustynutsFab.com X-Chassis 007 LS1 42's 4 Wheel Steer HP60's |
| Thread Tools | |
| Display Modes | |
