Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 04-27-2003, 08:00 PM   #1
Dave Gio
Member # 11329
5VZ-FE / 5VZE / 3.4L V6 Toyota Swap
The swap is done, and I've had it on the road for about a month and a half now.
If you have the following, this is the easiest and best swap for the 3VZE: 1988 to 1995 Toyota with 3VZE and 5 speed transmission.
As said before, the 5VZ-FE bolts right into place with the stock engine mounts (2" body lift or hood mod needed).
The bellhousings are different but have the same bolt pattern, the difference is the clutch slave cylinder, on the 3VZE it is on the pass side, with the 5VZ-FE its on the drivers side.
You can use either the 3VZE flywheel, pressure plate and clutch to the 5VZ-FE parts.
Also, you can use either of the following 3VZE or 5VZ-FE parts, starter, alternator, radiator, fuel pump, fan.
For the 5VZ-FE oil pan, baffle, and pickup tube, you simply remove the forementioned parts from the 3VZE and bolt them onto the 5VZ-FE, same goes for the dipstick and dipstick tube.
You use the power steering pump from the 5VZ-FE, and the easiest route for AC is to use the 5VZ-FE braket and pump, but the 3vze bracket can be modified to fit, then the V-pulleys on the 3VZE idler and compressor need to be swapped for serpentine ones.
The stock crossover won't work so custom exhaust needs fabbing from the manifolds back, included in the exhaust work is the need for 2 ox sensors (that match the computer year).
Then a few minor issues like moving the battery and mounting the 5VZ-FE components in the engine bay.
This swap is rediculously easy, It can be done in 3-5 days vehicle downtime.
Jansonmt has some pics that he'll be putting up.
'91 4Runner / '98 5VZ-FE / '85 SFA / '87 R151F / '97 Toy E-Locker / MTRs & 5.29's / All Toyota Baby & No Chrome
Dave Gio is offline   Reply With Quote
Old 04-27-2003, 08:22 PM   #2
mobil1syn
Pirate4x4 Addict!
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
pics ... we need pics
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
FOR SALE
- DAVE COLE specials - interco truxxus stickies
mobil1syn is offline   Reply With Quote
Old 04-27-2003, 08:42 PM   #3
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
One of them:
Too many idiots, not enough dead people
jasonmt is offline   Reply With Quote
Old 04-27-2003, 08:43 PM   #4
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Another:
Old 04-27-2003, 08:51 PM   #5
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Another:
Old 04-27-2003, 08:55 PM   #6
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Crossover:
Old 04-27-2003, 08:57 PM   #7
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
3.4 going in:
Old 04-27-2003, 08:58 PM   #8
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Wiring Fun:
Old 04-27-2003, 08:59 PM   #9
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Flex plate:
Old 04-27-2003, 09:00 PM   #10
Heavy Metal Toy
Heavy Metal Toy's Avatar
Member # 9265
Send a message via AIM to Heavy Metal Toy Send a message via MSN to Heavy Metal Toy
Wow, there's an engine in there somewhere? Looks good though!
"Four Cam 24V- when 2 just aren't enough!"
82 Toyota 4x4 LOCKED, wheeler
94 Toyota Celia ST, daily driver, 98 Suburban diesel 2500, tow rig
Heavy Metal Toy is offline   Reply With Quote
Old 04-27-2003, 09:00 PM   #11
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
The rest of the ones I have are just small Thumbs. Dave is working on sending me the rest of the pics. in a larger format. He was robbed a while ago, even including his server.
Old 04-27-2003, 10:11 PM   #12
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Alternator:
Old 04-27-2003, 10:13 PM   #13
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Front View:
Old 04-27-2003, 10:14 PM   #14
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Cams:
Old 04-27-2003, 10:15 PM   #15
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Clutch and Flywheel:
Old 04-27-2003, 10:16 PM   #16
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Rear crank:
Old 04-27-2003, 10:16 PM   #17
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Flywheel installed:
Old 04-27-2003, 10:20 PM   #18
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Heater hoses:
Old 04-27-2003, 10:20 PM   #19
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Heater hose:
Old 04-27-2003, 10:22 PM   #20
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Heater:
Old 04-27-2003, 10:23 PM   #21
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Engine on Hoist Driver Side:
Old 04-27-2003, 10:24 PM   #22
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Computer Wiring:
Old 04-27-2003, 10:25 PM   #23
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Wires hooked up to Computer:
Old 04-27-2003, 10:26 PM   #24
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Computer terminals:
Old 04-27-2003, 10:27 PM   #25
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Difference in Fuel pumps:
Old 04-27-2003, 10:28 PM   #26
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Difference in oil pans:
Old 04-27-2003, 10:29 PM   #27
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Sorting out the wiring:
Old 04-27-2003, 10:29 PM   #28
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Extra wires:
Old 04-27-2003, 10:31 PM   #29
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Splicing 3.4 and 3.0 harnesses together:
Old 04-27-2003, 10:31 PM   #30
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
All spliced and cleaning up:
Forum Jump
