Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 06-24-2003, 11:40 PM   #1
poorwheeler
Member # 14283
Lame attempt at some motor mount tech.
My Graphic skills need some great improvement. But I have recieved several PM's asking about the way I do my motor mounts and for some pics. Well all the mounts I have done are still in the vehicles and I have never taken a pic while I was doing em. This is close to the way Marlin showed me how. The only thing I changed was using a bigger stringer bolt and drilling out the hardware to make it fit. After I did these mount I could barely notice any more motor vibration. But marling has been running these style mounts for over 3 years and swears by em. Even with his budbuilt before the mounts he broke stock mount often. And he didn't like the vibration of other aftermarket ones. And well this way just seems better than chain. Although chain has done me well for a long time. So take a look and see what can be done better and comment/flame away. But total cost was like $4.50 a side from OSH not including the mount(even though your just modifying yours.
After you get the mount together just tighten it enough to make the lock washers go flat. I even used a lock nut and other friends have tack welded theirs. Try and drill directly in the center. If using a used mount you can usually see where the circle has rubbed from wear against the frame.
Yeah I know my spelling sux...
"Cut em All JACK!"
poorwheeler is offline   Reply With Quote
Old 06-25-2003, 03:29 AM   #2
TNToy
Cardboard Killer
TNToy's Avatar
Member # 5776
So you basically drill out where the original bolt was... and the rubber that was previously in tension... is now just a bushing?
ASE Certified Master Automotive Technician
Toyota Certified Expert Technician
Volvo Certified Expert Technician
Suzuki Certified Master Technician
IDPA Certified Master Cardboard Killer
TNToy is offline   Reply With Quote
Old 06-25-2003, 09:18 AM   #3
CRS
CRS's Avatar
Member # 11669
Send a message via AIM to CRS
that was my last weekend project did know if it would work but its cool to see others do i didnt like the chain much and rockstomper was to much vibe Girlfriend liked it though yeah i just drilled the hole out and and a bolt all the way through and boltd to the motor just like above
works good. hope it holds up.
CRs
1/4 TiLT Krawlers Petaluma CA 707 799 5747
Jake my waterfall, see you at the gates till then your always by my side<3
CRS is offline   Reply With Quote
Old 06-25-2003, 09:29 AM   #4
Scott@Rockstomper
The winch rope guy
Scott@Rockstomper's Avatar
Member # 1889
Any suggestions for how to keep the bolt-hole centered over the original stud?
One other suggestion--might want to periodically replace the bolt because of fatigue issues.
Winch rope, DIY beadlock kits, hydraulic steering, and much more: Shop Rockstomper online
Scott@Rockstomper is offline   Reply With Quote
Old 06-25-2003, 10:50 AM   #5
poorwheeler
Member # 14283
Pretty much. But 99% of the time the motor is still resting on the rubber and putting no strain on the bolt. Which gives you no more vibration than stock. Only under a load does vibration slightly increase and the bolt actually take a load.
"Cut em All JACK!"
Old 06-25-2003, 11:06 AM   #6
poorwheeler
Member # 14283
The centering issue was kind of a shot in the dark and hit her in the face . But with the about 7-10 of these I have done on the used mount there was a clear mark from the perfect circle on the frame where the motor mount had been resting. This would only be a problem if you were using a new mount that had never been in a truck.
Scott what size bolt do you use in your mounts? Is it stronger than a 1/2" Grade 8? This bolt only sees stress under hard accelleration/low gear wheeling tourque.
Marlin Czakowski has used this design(and he was the one who told me about it about 1 1/2years ago) for over 3 years now and had had no problem. He uses an old head bolt for his just cuts it down. His crawl ratio is over 1000:1 and he said even with the Budbuilt crossmember and dual tcase he was still braking both of them until he came up with this motor mount modification.
"Cut em All JACK!"
Old 06-25-2003, 11:06 AM   #7
WARDOG
Member # 13422
I did the same thing and it lasted one trip and broke. So I went with Rockstomper's and they'll probably outlast the truck. Good idea though. Scott's don't vibrate much more than the bolt-through design either.
WARDOG is offline   Reply With Quote
Old 06-25-2003, 11:08 AM   #8
poorwheeler
Member # 14283
CRs
What did you use for the rubber bushing? I used a peice of mudflap for my first set and it worked great.
"Cut em All JACK!"
Old 06-25-2003, 11:54 AM   #9
CRS
CRS's Avatar
Member # 11669
a piece of rubber floor mate 1/8 to a quater thick just cut it with a razor blade
Old 06-25-2003, 12:07 PM   #10
poorwheeler
Member # 14283
Not critisizing the way you did it but my way the hardware is alot stronger than the rockstomper's. They use a smaller grade 5 bolts. Your hardware must not have been up to the task.
"Cut em All JACK!"
Old 06-25-2003, 12:50 PM   #11
85runnerAZ
Member # 17610
This thread couldn't have better timing. I am putting in new motor mounts this weekend. I can take pics if someone wants me to email them to em so they can be posted...don't have my red star yet.
KK
www.crawlinaz.com/forum for AZ crawling and trail runs
85runnerAZ is offline   Reply With Quote
Old 06-25-2003, 01:18 PM   #12
SeaBass44
www.12voltguy.com
SeaBass44's Avatar
Member # 40
Send me the pics I CAN POST THEM
TTC 2010 #1 truck pick,I'm in!
12voltguy.com /
Click here to email me
New # 530.532.4529
http://www.davezoffroadperformance.com/
OFN Fab BB
-89 1 ton bronco on 46" MT's-
03 crf450
Hard work often pays off after time, but laziness always pays off right now.
SeaBass44 is offline   Reply With Quote
Old 06-25-2003, 02:33 PM   #13
poorwheeler
Member # 14283
One thing I forgot to add. Make sure your washers/rubber are not bigger than the hole in the frame mount or they will cause interfearance. Good luck and I can post some pics for ya also.
Anyone know the tensile strenght of a 1/2" grade 8 bolt?
"Cut em All JACK!"
Old 06-25-2003, 02:47 PM   #14
Scott@Rockstomper
The winch rope guy
Member # 1889
Stronger than a 1/2" Grade 8 bolt? No... it *is*--that's as big as fits. Bigger and you can't get it through the stock engine ear.
The mount bolts to the frame are smaller, though. Still stronger than stock, but smaller than 1/2". I'm not sure offhand (can't remember what size the stock bolts are) if they're bigger or smaller than stock.
Old 06-25-2003, 02:56 PM   #15
poorwheeler
Member # 14283
Rockstomper makes a great product. Would have went that way if I had the money. Was shown this way one day and thats the way I have done it. Hence my username. Just trying to help out the brokedicks like me
"Cut em All JACK!"
Old 06-25-2003, 07:02 PM   #16
85runnerAZ
Member # 17610
Sounds good
KK
Old 06-26-2003, 03:03 PM   #17
Scott@Rockstomper
The winch rope guy
Member # 1889
No harm in it... that's why I hopped on with what (I hope) was useful info, not "oh, just buy my stuff"... I've been (still am) a brokedick for a long time.
One other word of advice regarding this setup--you may want to oversize the washers on the motor mount ears--it'll help support the motor mount baseplate from bending. I've actually found that a burly motor mount, with stupid-gear, and stock dinky-washer bolts, can start to pull the frame ears upward, dimpling the bolts into them (did it myself), and the frame side of the motor mount plate setup, is stronger than the stock motor mount baseplate is. That's part of why our mounts include new bolts and washers.
Old 06-26-2003, 06:41 PM   #18
poorwheeler
Member # 14283
I hear exactly what your sayin. About 2months after I did this I went to a FROR X-Member/Skid Plate setup. Alng with these mounts and that setup I have had no problem. I don't know if you are familiar with the rubicon but there is a spot called toyota hill/toyota pullout at the Little Sluice. I went up it this weekend at 200:1 to the floor hopping on all 4's. Everything help up great. Was waiting for something to pop but the shifters didn't even wiggle.
Scott if you guys could just get a little more rubber in there or somethin I would run em. Just like the feelin of a smooth runnin truck while I am puttin down the trail.
"Cut em All JACK!"
Old 07-23-2003, 07:04 PM   #19
KS Toy
Member # 7938
MM mod...
Ok, I just got done with this mod. It took about 20 min on the pass side and 35 on the d side. I could tell a BIG diff right away as soon as I let out on the clutch just a little it grabbed. It was a piece of cake other then getting the drivers side off and on. What a bitch. Anyway...I must have the bolts to tight. That SOB shakes like a puppy shitin' razor blades. I will loosen them tomorrow and see what happens. Also for the flat washer that goes in the MM connected to the frame I used a 3/8" washer and drilled out to 1/2" Thanks for the tip-Brad
A fool's lips bring him strife, and his mouth invites a beating.
KS Toy is offline   Reply With Quote
Old 07-23-2003, 07:17 PM   #20
Bones
Member # 3007
I just installed my rockstomper MM's and was roilling it around the driveway in lo lo and since my cage is against the roof it makes a NICE Hmmmm sound. Can't wait to drive 4 hours to Disney in that! But no longer does my drivetrain bounce around like before. Anyone want some 1-2 year old stock mounts, let me know. I'll never go back
Bones is offline   Reply With Quote
Old 07-23-2003, 07:35 PM   #21
Alabamatoy
Alabamatoy's Avatar
Member # 2497
How much?
Buy Rescue Tellico stuff! Profits go to Rescue Tellico fund.
86 4Rnr (orig owner), SAS, inchworm, lotsa doghair
Rocket City Rock Crawlers
If you didnt buy your 1'st gen 4runner new, then YOU are a newbie!
Alabamatoy is offline   Reply With Quote
Old 07-23-2003, 07:36 PM   #22
Bones
Member # 3007
PM me a price and we'll go from there.
Old 07-24-2003, 07:12 PM   #23
poorwheeler
Member # 14283
Re: MM mod...
Only tighten until the lock washer colapses. Took me a time or two to get it right before my vibrations went away.
Sam
"Cut em All JACK!"
Old 07-24-2003, 08:44 PM   #24
KS Toy
Member # 7938
Re: Re: MM mod...
Sam
I backed them off so the washer is seperated. This helped some but it still has vibration. Maybe it will loosen up alittle when I drive it.
Old 09-06-2003, 09:18 PM   #25
Rock-Wear
Member # 15186
anybody ever get pics? how well is this working for everyone?
Rock-Wear is offline   Reply With Quote
Forum Jump
