Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Thread Tools Display Modes
Old 08-25-2003, 11:28 PM   #1
Buck91toy
Member # 16584
Using tubing to lengthen and shorten shafts
Good .... Bad anyone done this I'm not talking about square tubing just normal round tube. thick and beefy. Couldn't I get some tube just barely larger than the shaft so it would slide (maybe with a little help from a hammer) right in and then cut the shaft about an inch or two behind the yokes and cut the tubing to length and weld it? very cheap way to do dual cases I would think.
91 toy all the bells and whistles.. blah blah blah
Buck91toy is offline   Reply With Quote
Old 08-26-2003, 12:47 AM   #2
Im4yotas
H M F
Im4yotas's Avatar
Member # 8758
You absolutely could if you aren't worried about balancing it. Best way IMO to change the length is with the same OD tube. Clamp everything together in a piece of angle iron to keep it as straight as possible. Chop saw would help, as perfect 90 degree cuts would make this much easier than a rough sawzall cut. Tack it evenly all around so it doesn't move, then weld around, grind down smooth. If you need it for the rear, have a driveshaft shop balance it.
Team Unite V2R, 4454 right seat...some day!
KOH '09 - #004 Team HMF, we kicked Shannon's ass!
SSS 4x4 - The worlds only 16.5" sticky supplier!
www.F-O-A.com
H . M ..F
Im4yotas is offline   Reply With Quote
Old 08-26-2003, 02:47 AM   #3
TNToy
I call her... Vera
TNToy's Avatar
Member # 5776
Don't buttweld it like im4yotas suggested: Toy shafts are less than .060 wall and it'd never hold. Besides, it's not worth the work: As soon as you dent a rear shaft its just a couple good launches up a ledge (read: clutch dumps) away from a sudden death. If you have to butt weld it, sleeving it inside or out will make it much more likely to hold. But why go through the work just to have a failure-prone thin-wall drive shaft?
Here's how I did mine. Doing it again, I'd use 3/16ths tubing... 1/4" is hella overkill - but good overkill. Someone was watching me crossing a couple of fairly large trees this weekend and I saw him staring at something under the Toy really hard. When I asked and he explained that he was "keeping an eye on the rear driveshaft" I explained he didn't need to bother. If it wouldn't result in possibly needing a strap I'd have perched the rear end on the driveshaft to watch his reaction.
http://www.pirate4x4.com/forum/showt...hreadid=159490
ATTENTION PRIUS OWNERS:
Your hybrid vehicle still requires fuel from time to time. Please stop running them out of gas, towing them to the dealer, and getting all huffy when we charge you to clear the P3193 (Fuel Run Out) code.
Thank you.
TNToy is offline   Reply With Quote
Old 08-26-2003, 03:24 AM   #4
Rwhat
Member # 10177
What size ID is that tubing your using to sleeve?
"Swiss army and a roll a duct tape"
Ricer Cars and Tampoons have alot in common, Sooner or Later Every Pussy has to have one!!!!!!!!!!!!!!!!!!!!
Rwhat is offline   Reply With Quote
Old 08-26-2003, 07:09 AM   #5
OOP'S
Sobriety=Serenity
OOP'S's Avatar
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
Don't laugh to hard, but this year at JV Erik B's Brother-In-Law twisted his D-shaft and Zuk fixed it by cutting out the bad section and replacing it with a new section, before he tack welded it he put a few handfuls of sand in the shaft, tack welded it together and put the shaft back and used fixed points and a hammer to "Tweak" the shaft straight. Pulled it out and welded it up. Ed said he was able to do 90 MPH with hardly a vibration. The sand worked to balance the shaft like golf balls in the tires, centrifugal force.
David & Theresa, Roseville, CA,
Excellent Parts Source
http://www.davezoffroadperformance.com/
http://www.marlincrawler.com/
http://www.12voltguy.com/web/
OOP'S is offline   Reply With Quote
Old 08-26-2003, 08:48 AM   #6
FreakAccident
Member # 3553
Send a message via AIM to FreakAccident
BBs are better!
Thats a smart idea to put sand in the shaft though.
FreakAccident is offline   Reply With Quote
Old 08-26-2003, 09:39 AM   #7
OOP'S
Sobriety=Serenity
OOP'S's Avatar
Member # 30
Originally posted by FreakAccident
BBs are better!
BB's rust, golf ball don't!!!!!
Old 08-26-2003, 09:51 AM   #8
Air Ride
Tech Editor
Air Ride's Avatar
Member # 1656
Originally posted by OOP'S
Don't laugh to hard, but this year at JV Erik B's Brother-In-Law twisted his D-shaft and UK fixed it by cutting out the bad section and replacing it with a new section, before he tack welded it he put a few handfuls of sand in the shaft, tack welded it together and put the shaft back and used fixed points and a hammer to "Tweak" the shaft straight. Pulled it out and welded it up. Ed said he was able to do 90 MPH with hardly a vibration. The sand worked to balance the shaft like golf balls in the tires, centrifugal force.
plus the inside will be all bright and shinny.
2" pipe fits nicely inside older toy d-shafts. built many that way. If you get them straight they dont shake. most dive-shaft shop don't bother to get them straight, thats why they need so much weight.
tinbenders.org
For info on the Forumla Toyota and the full tube X chassis.
Click here to visit Hendrix Motorsports
camo is my hero, even if he is gay
DirtChoppers.net
Air Ride is online now   Reply With Quote
Old 08-26-2003, 07:59 PM   #9
Im4yotas
H M F
Im4yotas's Avatar
Member # 8758
Yeah, it does hold, actually But I guess the Hammers aren't a very good test. I used a .095 shaft though (High Angle).
But like I said, just use the same OD to help keep it straight. You can use whatever thickness you want.
www.F-O-A.com
H . M ..F
Old 08-26-2003, 08:35 PM   #10
Bill Collins
Member # 163
you gonna have it together for moab this weekend buck?i am leaving wednesday,be there friday morning...
85 runner with some stuff...
Bill Collins is offline   Reply With Quote
Old 08-26-2003, 10:12 PM   #11
Buck91toy
Member # 16584
yeah I should be readyI just got a v6 third with a spool for a good deal and so I will for sure throw that in before I go, but the question will be the springs weather or not I can get the 63"ers in before then, I will only have thursday night and fri morning to work on it all so we'll see! If not then I'll stay with the springs I have right now. Hey bill....we will probably meet in the city market parking lot around 9:00 am sat! I'll try to call you when I get there.
Old 08-26-2003, 10:23 PM   #12
TNToy
I call her... Vera
TNToy's Avatar
Member # 5776
.095 would probably work, personally there's no WAY I'd want to try and run a butt-welded factory driveshaft. They're just too thin.
RWhat: The tube I used was either a 2.5 or 3" OD with a quarter-inch wall... had a buddy turn .100 off the ID and it pressed onto both yokes just fine.
As far as balance, I'll echo what Air Ride said. The tube I used was trued up in a lathe (by product of turning the ID) and then press over the factory shaft tubing, ensuring it would be straight. Ended up with 25/1000s of runout. Not much at all considering the shaft is 46.5 inches long. I can see it when I drive down the interstate, etc... where it doesn't vibrate or visibly wobble at ALL. It's just like running a factory driveshaft as far as a seat-of-the-pants feel. Except it weighs an extra 20 pounds and I can support the truck on it.
Thank you.
Old 08-26-2003, 10:56 PM   #13
miniyota
Member # 5963
dang that sand thing is what i should have done. mine is a little out of balance. i was running the morrison jeep trail and toasted another cneter driveshaft bearing and a u joint and after a hour and a half drive home in a vibrating truck i figured screw this two piece crap! i got a dtiveshaft from a long bed truck.
made some lines with my straight edge and cut out two inches. i stuck in angle iron and made it nice and straight. i then heated it with a tourch. and buttwelded with a 210 mig. its really straight, almost perfect. i haven't been able to pretzel it yet. i've dumped the clutch a number of times. and so far its held. the only problem is a vibration once i hit 55 mph. maybe i'll drill a hole and stick some sand in there and then add a plug.
[B]Low-Range (ADJ)- Pull it for maximum pleasure![/B]
[URL="http://WWW.GETLOST4X4.COM"]GETLOST4X4.COM[/URL]
miniyota is offline   Reply With Quote
Old 08-26-2003, 11:18 PM   #14
pitter
pitter's Avatar
Member # 11018
we shortened a BII shaft at my old work and to get it straight we put the truck on jack stands and then put it in drive to see if the shaft was out of allignment, if it was.. hit it with a bfh, we did this till it was true. did a few tacks here and there while we did it. took it out and welded it up. ran fine no vibes TNToy how do you think a shaft would be out of 3/16 at 57.75" long.
93 yota exo - rears - s10's - dual cases - 36 SX - 30 spline longs - hydro assist.
97 cummins extra cab 5 speed 4x4 on 35's 4000gsk slammed afc and #10 plate
pitter is offline   Reply With Quote
Old 08-26-2003, 11:25 PM   #15
TNToy
I call her... Vera
TNToy's Avatar
Member # 5776
.188 (3/16ths) is plenty thick. PMurf runs a .188 shaft and his truck didn't used to be very light, or babied.
I kinda wish I'd done mine outta .188 ... .250 is great but .188 should be hella strong still, and quite a bit lighter. Lighter = easier on u-joints.
Thank you.
Old 08-27-2003, 12:16 AM   #16
pitter
pitter's Avatar
Member # 11018
would length matter at all seeing i am about 10" longer than you on my rear shaft?
Old 08-27-2003, 12:26 AM   #17
johny5
Member # 16250
thanks for the great info guys , i saw this post last night and after work, with in 20 mins i had a new rear shaft ready for the rubicon this weekend i am going to take it in to balance it up tommorow,, it is 60 inches long and mighty heavy (188 wall tube)
johny5 is offline   Reply With Quote
Old 08-27-2003, 12:56 AM   #18
scottz
Technician A
scottz's Avatar
Member # 1730
I've built probably 10-15 driveshafts at home using a cheesy jig made out of an old two piece driveshaft bearing. That and a $12 dial indicator from harbor freight. I can usually get them under 20 thousandths. Good to 90+mph, probably go faster but the rig won't.
if you cut right in front of the weld on the flange only through the tube you can get the stock tube off and have enough flange left on there to put stock inside diameter tube back on. I've been using .095 wall stuff. Next time I buy it Team Tube in west sac said they have some .156 wall stuff that had the right i.d. It was 2 5/8 o.d. x .156 wall DOM. I've been using 2 5/8 od x .095- it will bend but won't really taco after it's bent like the stock stuff. The .156 wall is $6.88 a foot and the .095 stuff is $5.13 a foot.
"they've lowered the speed limit to zero and banned reverse"
scottz is offline   Reply With Quote
Old 08-27-2003, 09:37 AM   #19
SeaBass44
www.12voltguy.com
SeaBass44's Avatar
Member # 40
.188 (3/16ths) is plenty thick........ and quite a bit lighter. Lighter = easier on u-joints.
Last reply you talked about being able to support the truck on the shaft, Uh...............a lil hard on U-joints ya think And as far as BUTT welding goes, I don't recoment it, but my buddy the pro welder has been running square SS BUTT welded shaft 2 years, trailer rig No idea why they hold up
LOTS of GUNS 4sale !
12voltguy.com /
Click here to email me
New # 530.532.4529
OFN Fab BB
-89 1 ton bronco on 47" LTB's-
Hard work often pays off after time, but laziness always pays off right now.
SeaBass44 is offline   Reply With Quote
Old 08-27-2003, 11:41 AM   #20
Bill Collins
Member # 163
i am ready to leave now,i will see you sat at 9:00 at the city markrt...
Old 08-27-2003, 11:44 AM   #21
Bill Collins
Member # 163
also i will be in a silver crew cab ford pulling a flatbed gooseneck with a old wore out toy truck
Old 08-27-2003, 02:26 PM   #22
TNToy
I call her... Vera
TNToy's Avatar
Member # 5776
Originally posted by SeaBass44
My buddy the pro welder has been running square SS BUTT welded shaft 2 years, trailer rig No idea why they hold up
My point with the "dont butt-weld stock shafts" was phrased poorly.
You have a shaft that currently doesn't work. You can butt weld it and make it work until you hit the stock thinwall tubing on a rock, dent it, and it eventually fails... or you can find a tube/pipe that's at least .120 wall and build one that will hold up. If it's closer to .188 wall, it'll hold up for a very long time.
As far as the wall thickness? .188 seems to hold up enough that anything thicker is just wasted weight. I used .250 cuz it's what I had. Doing it again, Sch40 or 3/16ths (.188) would be just fine.
Thank you.
Old 08-27-2003, 06:27 PM   #23
ErikB
Grocery Getter
ErikB's Avatar
Member # 59
He's still running it.
Its his daily driver and he just drove it a few hundred miles from here to Barstow too...
ErikB is online now   Reply With Quote
Old 08-27-2003, 11:06 PM   #24
turbrotoy
turbrotoy's Avatar
Member # 18719
Yeah that rear one stayed togather well,but I remember you did have a issue with the front one lol .Hey I like your new avatar ,I got my sign for the front yard and my bumper sticker coming in the mail .Its time to clean the house "arnold for govenator"
THANKS TOO ALL THESE GUYS FOR HELPING BUID MY RIG!!
[url]http://www.heavymetalfabshop.com/[/url]
[url]http://www.trail-gear.com/[/url]
[url]http://www.inchwormgear.com/[/url]
[url]http://www.budbuilt.com/new/index.html[/url]
[url]http://4xinnovations.com/[/url]
[url]http://calminitruck.com/[/url]
thats all i can fit?
turbrotoy is offline   Reply With Quote
Old 08-27-2003, 11:13 PM   #25
Im4yotas
H M F
Im4yotas's Avatar
Member # 8758
Problem was that 14" of slip in the driveshaft isn't enough The butt weld wasn't a problem.
www.F-O-A.com
H . M ..F
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
