#1 |
Member # 20872
ALL NEW FORGED DANA 60 KINGPIN INNER "C"s
Forged Dana 60HD Kingpin Inner "C"s
* The only new FORGED kingpin Dana 60 "C"s on the market * Heat-treated for extra strength * Available for 2-3/4", 3", 3-1/8", and 3-1/2" tube sizes * Can be custom bored using the fixturing ring machined on the "C" * Ideal for new builds, narrowing, or hybrid axles * Forging based on the huge Dana 70 inner "C" * Much stonger than factory Dana 60 "C"s * Powder coated bright orange for long lasting looks * 100% interchangeable with all factory and aftermarket Dana 60 kingpin components. * As always, Made in the USA $244 each Right and Left sides are the same. Part # ----- Bore size -- For Tube size D60005-1 --- 2.7475 --- 2-3/4" D60005-2 --- 2.9975 --- 3" D60005-3 --- 3.1225 --- 3-1/8" D60005-4 --- 3.4975 --- 3-1/2" Available the first week of March, now taking pre-orders Dealer and Axle builder inquires welcome!
Manufacturers of Dana 60, 44, 30 knuckles and Powerglide transmission cases. Any questions about our products? Like to place an order? Contact us! (925) 935-3025 M-F 9-5pm PST race.mail@reidracing.biz http://www.reidracing.biz Built by Rockcrawlers for Rockcrawlers Made in the USA! Last edited by Dedenbear; 03-05-2004 at 09:31 AM. |
#2 |
Member # 20872
Here is one next to a stock 60 "C"
Manufacturers of Dana 60, 44, 30 knuckles and Powerglide transmission cases. Any questions about our products? Like to place an order? Contact us! (925) 935-3025 M-F 9-5pm PST race.mail@reidracing.biz http://www.reidracing.biz Built by Rockcrawlers for Rockcrawlers Made in the USA! |
| Sponsored Links |
#3 |
Member # 11598
What's the biggest u joint you can fit in your Cs and outer knuckles? Stock D60?
This space for rent. |
#4 |
Pirate4x4 Addict!
Member # 2160
With all this stuff for a dana 60 coming out they sure are looking good -Jesse
http://highangledriveline.com Bringing Innovation to the market ! http://highangledriveline.com/HAD1.gif 530-877-2875 DISCOUNTS on our new on line store available - Also 1410 32 spline yokes- and 14 bolt 1410 on over stock sale- |
#5 |
This really makes me want to build a hybrid 9"/60 ...
DEAR MADAM: THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE. YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY. PLEASE SELECT ANOTHER ITEM. THAT'S OUR FIRE EXTINGUISHER |
#6 |
City Slicker
Member # 9835
What does it weigh compared to the stock one in the pic?
79 SSII Fiberglass bod, hydroboost, 4whl discs. looks like im going to be a bowtie guy, ls1, 4l60, klune on the way |
#7 | |
Member # 20872
Jason, Yes, this is all for the stock 60 ujoints. Ryan
#8 | |
Member # 20872
Ryan
#9 |
Member # 7847
Two Questions:
1) Is there a package price if you purchase knuckles and inner C's as a set? 2) Won't the powder coat get all messed up when you weld the "C" to the tube....or am I missing something Thanks, Mike
"Go Big or Go Home" |
#10 |
Member # 20872
As of now ther is not, Im not sure if we will be or not. 2) Won't the powder coat get all messed up when you weld the "C" to the tube....or am I missing something The powder coat on the production "C"s will end about .5" from the point of where you are welding. We think the powder coat will be ok, as it is baked on at 450F and has some distance from the weld.
#11 |
4xdork
Member # 3263
are they forged 4340?
Team Tank old junk, new junk, unfinished junk Live Large-RIP Jason Payne |
#12 | |
Member # 20872
No they are not, they are an alloy steel. The same material that Dana/Spicer used. Ryan
#13 |
4xdork
Member # 3263
are the dana spicer version forged?
could you make them from 4340?
#14 |
Member # 20872
Yes, all Dana/Spicer "C"s on all Dana 60s, 44s, and 30s were forged. could you make them from 4340? No we wouldnt. 4340 is not the correct material for "C" forgings. It has a very high carbon content that will cause hard spots in the forging among other things. Then they will have to be anealed, preheated, TIG welded, then heat-treated again to prevent cracking when welding to a tube. Ryan
#15 |
4xdork
Member # 3263
what is the alloy that you make them from? 8630?
#16 | |
TJ MallCrawler Edition M-715 Urban Assault Edition 383 SBC/TH400/203/205/60/14B "If your junk didn't come standard with 38's and gun mounts in the cab/bed STFU." -- me |
#17 | |
Member # 20872
The alloy we are using is the same as the factory Dana/Spicer "C"s. We did a material analysis on a few different factory "C"s to determine what they used. We believe that the material Dana/Spicer used was for a good reason. Im sorry but I cannot release this information. Ryan
#18 | |
Member # 20872
This should be fine, just about any 220v welder should do. The factory "C"s look to have on average .220 penetration into the the material. Ryan
#19 | |
Ah come on!!! If were going to spend $500 on a pair of these at least you could tell us what they're made out of.
#20 | |
Member # 2798
anyway they look good they are forged and not cast like competitors i look forward to seeing these being used
go marlin and dont support the china. dont trust unhonest vendors that lie to you and play games |
#21 | |
Sometimes it seems things go by too quickly. We are so busy watching out for what's just ahead of us that we don't take the time to enjoy where we are.
Sometimes one should just look at things and think about things without doing things. |
#22 |
Build em' Big
Man yall are killing me! every size but 3.25" damn.... damn.. damn... I wanted to order ASAP.... is is possible to bore a 3 1/8" on a vertical mill? Thats all I have access to!
Southern Motor Sports Ruston, Louisiana |
#23 |
Member # 1075
The C's can be bored on a vertical mill. The ring on the back of the C can be grabbed in a rotary table or a v notched vise and a standard boring bar can be used.
All the C's are the same forging, so any hole diameter can be made up to 3 1/2.
Storebought zuki, 4.3, 700R4, atlas, arb'd 60's, etc. etc. etc. Are you happy now Brian???????? |
#24 |
Member # 20872
Gopar is correct, you could also clamp it to the table on some parallels.
What axle are you building using a 3.25? If there turns out to be a large demand for this size we may do a run of 3.25" Ryan
Manufacturers of Dana 60, 44, 30 knuckles and Powerglide transmission cases. Any questions about our products? Like to place an order? Contact us! (925) 935-3025 M-F 9-5pm PST race.mail@reidracing.biz http://www.reidracing.biz Built by Rockcrawlers for Rockcrawlers Made in the USA! Last edited by Dedenbear; 03-18-2004 at 09:38 AM. |
#25 |
Build em' Big
I got a great deal on a 5 foot piece of 3.25x.500 DOM... Free to be exact... we turned the tube down to fit in the Dana 60 housing but we cannot turn the ends down for the Inner C's because all the grinding was done on a Crankshaft machine and we don't have a way to jig it up to grind on the ends.. we orginally ground the center of the DOM and then cut it in half. I will see if we have a cutter for the mill and go from there.
Thanks, Mark
| Thread Tools | |
| Display Modes | |
