#1 |
Tech Editor
Member # 1656
Toy hub and brake rotor mod $149.00
Send us your wheel hubs, locking hubs and brake rotors and we will do the 6 pin install on the hubs, cross drill and counter sink the rotors and ship them back to you for $149.00.
add $20.00 for vented rotors. Hubs and rotors must be clean and in good condition. Brake rotor must be removed from wheel hub. Extra charge for cleaning and disassembly of brake rotor and wheel hub. Brake rotor mod for off-road use only. Ship to: 10100 Digger Pine Road Santa Margarita, CA 93453
tinbenders.org For info on the Forumla Toyota and the full tube X chassis. Click here to visit Hendrix Motorsports camo is my hero, even if he is gay DirtChoppers.net |
#2 |
Kajobuilt
Member # 2537
How much for just doing the 4 pin install on the hubs?
KAJOBUILT Authorized dealer for the following companies: Corbeau Seats, Diamond Axle, Front Range Off Road, Pitbull Tires, Poly Performance, Ruff Stuff, Trail Gear. PM me, email me at kajo@kajobuilt.com or call me at 570-567-4415 for quotes and/or orders SFC, US Army (Retired) Cancer Survivor since 2002 |
| Sponsored Links |
#3 | |
Tech Editor
Member # 1656
$100.00 plus shipping
#4 |
Master of Disaster
Can you, and/or have you done this with the fj80 drive flanges?
If so will the price be the same? What do you charge to disassemble(sp?) and reassemble the hub rings from the rotors? |
#5 |
Member # 2982
Didn't see a "ship to" address on your site. Where are you at?
AJ 93 ExCab on 1-tons |
#6 | |
Tech Editor
Member # 1656
$45 an hour. Most come apart easy but some take a little time. Depends on how much rust there is and if they have been taken apart before.
#7 |
Member # 2982
Either I missed it the first time, or the addy was posted after I asked. Either way, it's in the orginal post...Thanks.
AJ 93 ExCab on 1-tons Last edited by AlaskaToy; 03-18-2004 at 10:56 AM. |
#8 |
Member # 14627
any problems if the hubs are off an ifs truck (i'm runnin a sky wide axle kit)? thanks
[QUOTE=Jeepguy74]As a newbie here, I must say..... you guys have some of the bestest topics! I think i'll stick around:D[/QUOTE] |
#9 | |
Tech Editor
Member # 1656
No problems
#10 |
Member # 16789
I'm assuming that $100 is for both side correct?
The Parts Pimp. I'm looking for highpinion TTB Dana44 gears in a 3.08. Let me know if you've got some. Collision Parts warehouse San Diego for replacement fenders and radiators: http://www.1800bodyparts.com/ |
#11 | ||
Member # 6650
#12 | |
Tech Editor
Member # 1656
#13 |
Member # 16135
front hubs
Hey Mike....received my hubs/rotors from you on friday.....
They look awesome....I really appreciate the fast turn around and the quality fit...matched up the arrows and installed them today... I'll test them next week at the jambo.......Thanks again for the great product and quick shipping...
#14 |
Why is the brake mod for offroad only?
[url]www.wheelingarizona.com[/url] [url]www.crawlinaz.com/forum[/url] |
#15 | |
Blood Never Lies
Member # 16502
My guess is they are for "off road only" because cross-drilled rotors tend to crack. So, safety/liability becomes an issue. Just a guess though.
#16 |
Member # 13912
The fix?
I assume this is the fix for shearing off lockout hubs after one has installed longfields and uprated inner axle shafts?
Visit the NEW www.tlca.org!!!!!!! TLCA Member 6235 TLCA Prez |
#17 | |
Tech Editor
Member # 1656
so far no one has lost a hub after having this mod done.
#18 | |
Fully desmogged '88 FJ62 w/ 222K miles; Flowmaster exhaust, Mallory ignition, Tuffy center console, '88 Mazda MX6 front seats, fully Dynamat'd, four wheel discs USAF Active Duty, proudly serving |
#19 |
Member # 16969
Originally posted by montezuma I'm assuming that $100 is for both side correct? correct, both sides
Camo is a fag! |
#20 |
Member # 19837
Can you do the 4 pin set up on my rear FF drive flanges/hubs?
If it does not go easy just force it David Dearborn Atlanta GA www.urbanlandcruisers.com TLCA Associate member Got a question, need an opinion, do you love puppies, just want to talk or stage a cage match? For all of these issues and more PM Mark, 65SWB45. |
#21 |
Banned
Member # 3933
Just set my hubs off today for the new axle I'm building....
(2) hub bodys and (3) locking hubs for $125+shipping. Just incase I break a locking hub onthe trail I got a spare to match. Oh and for you guys that don't know, He actually removes the OEM toyota studs and installs (6) new 5/16" Dia pins because the Toyota ones are to very low tolerance. Should work out great with FROR upgraded hub studs... http://www.pirate4x4.com/forum/showt...=stronger+stud Last edited by 4RnrRick; 08-13-2004 at 02:51 PM. |
#22 |
Member # 4464
i still do not believe i have seen an answer on being able to do FJ80 drive flanges. i run the flanges on my rear with a fror full floater. the flanges do have the step in, so it sounds doubtful.
only the dead have seen the end of war 1995 T100 - finally done 1988 4Runner - DD 2005 CTD 600, 4x4, NV5600 - Tow Rig |
#23 | |
Member # 2982
#24 | |
Tech Editor
Member # 1656
After weeks of measuring different toy hubs we found that Toyota didn't keep a very tight tolerance between the pins and the studs. It was much easier for us to get a tighter tolerance by replacing the factory pins with 5/16 pins. So far as I know no one has broken either setup.
#25 |
Member # 2982
can you remove a broken factory dowel? It doesn't protrude past the the surface of the hub. Can you mill it out?
| Thread Tools | |
| Display Modes | |
