#1 |
Cage Fighter
Member # 2634
Finished my quick disconnect welder/jumper cables
Well since I ditched the OBA and went CO2 I had a spot to mount my OBW instead of a stake pocket set-up... So I mounted the welder and then set it up so I don't even have to open the hood to use it.. The field switch and handle throttle are both in cab and the cables are-set up using quick disconnect fork lift cables.. I also set-it up so that I can use one set of cables for both jumper and welder cables.. The neg clamp always stays neg and the positive side has a quick disconnect tweeco set-up so all I need to do is put the red clamp on or the stinger...
Welder mount and discconects
#2 |
Cage Fighter
Member # 2634
close up of disconnects
Top set is for jumpers and bottom is for the welder
| Sponsored Links |
#3 |
Cage Fighter
Member # 2634
rear disconnect ( welder only )
#4 |
Cage Fighter
Member # 2634
cables
#5 |
Cage Fighter
Member # 2634
close up of tweeco ends for positive side of cable... You can use either the clamp or the stinger... This lets you to use one set of cables for both jobs
#6 |
Cage Fighter
Member # 2634
quick disconnect cable end hooked up to battery
#7 |
Member # 463
take driving lessons and you would have saved yourself some money
] Nick |
#8 | |
Cage Fighter
Member # 2634
#9 |
Member # 7938
Slick set up man. Thanks for the pics & write up.
A fool's lips bring him strife, and his mouth invites a beating. |
#10 | |
Member # 12100
Quote: Originally Posted by randii if you're a Pickle, rolling down the trail in a Smurf, dispensing bowls of dicks. FWIW, I don't want to see pictures of that, either! Randii |
#11 |
Member # 16812
OBJC?
![]() On Board Jumper Cables? I'm not saying it's a bad idea (it's actually pretty cool) but do you use them enough to have thought of that? -t |
#12 |
Member # 26761
LOOKS GREAT
NICE JOB
but now you cant hide the fact lol
82 YOTA 1ST GEN 5" SUSPENSION LIFT, 4.30'S LOCKED, DUAL T CASE. HY STEER 96 F250 TURBO TOW RIG |
#13 | |
Cage Fighter
Member # 2634
#14 | |
Cage Fighter
Member # 2634
Re: LOOKS GREAT
#15 |
Member # 11578
Where did you get the big cable end plugs? I have seen these on tow trucks, etc, but never seen them for sale by themself.
Thanks! D
Longtravelin, Sand Dunen fool!! |
#16 |
Member # 15043
looks like your getting ready for another weldfest-count me in this memorial day if you are going to the con- i'll bring my latest ride- 84 toy 4x4
rust is a four letter word!!!!! |
#17 | |
Cage Fighter
Member # 2634
The TWeeco ends on the positve cable are available through any welding supply
#18 | |
Cage Fighter
Member # 2634
What are the specs on your new "TOY"
#19 | |
Member # 15043
#20 | |
Cage Fighter
Member # 2634
I'll cya at spider
#21 |
Member # 27460
dude you did a shweet job, helped my buddy set up a system kinda like that but just heads out the back and used for a dump trailer instead of a welder. really like the set up
"Friends Of The Rubicon" Outlawz 4x4 NORCAL http://www.members.cox.net/outlawz4x4 well it started as a 85 blue ford f250 not sure what to call it now |
#22 | |
Member # 14455
My new chassis build. 406SBC, 416 Mog axles, and 46's. |
#23 | |
Member # 39
Re: Finished my quick disconnect welder/jumper cables
Eric Parts for Sale --> D44 shafts, 6 lug rims, air tank |
#24 | |
Member # 24336
Drink Powerthirst and you'll win at everything forever! You'll win at running, football, arson, weddings and art! You'll even win at irony! ARGHHHH! Top Score! #544 in JV Virtual Rally |
#25 | |
Cage Fighter
Member # 2634
Re: Re: Finished my quick disconnect welder/jumper cables
GM alt bumped up to 165 AMPS with a 1" pulley for low REVS.. I paid 100.00 for the whole set-up completely rebuilt through an alternator shop In Auburn, ca a couple years ago..
| Thread Tools | |
| Display Modes | |
