Pirate4x4.Com Bulletin Board
Old 04-16-2004, 07:26 PM   #1
ItsaCJ6
ItsaCJ6's Avatar
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
electric fan, Ford Taurus fan, fan, tech
Ok I used the funny tittle so it comes up on search....ya I know.
Any who here is the tech.. I picked up a 12 volt 30 amp continuous duty relay from Radio Shack for 8 bucks and change.
I have not hooked it in to my Fan yet, but the price was right.
Marc
Originally Posted by JoshTurner View Post
Ill go MUDDING with you
Super conversion calculator website
Maynard the Whore the Pimp the God.
"When the going gets weird, the weird turn pro."
-Hunter S. Thompson
"I wouldn't recommend sex, drugs or insanity for everyone, but they've always worked for me."
-Hunter S. Thompson
ItsaCJ6 is online now   Reply With Quote
Old 04-16-2004, 07:48 PM   #2
preach
Member # 8713
How about a part #?
Great Northern Ridge Runner
preach is offline   Reply With Quote
Old 04-16-2004, 08:11 PM   #3
JeepCrawler98
JeepCrawler98's Avatar
Member # 18342
Send a message via AIM to JeepCrawler98
I think the fan at running draw is 30amps exactly - so you'd be cutting it exactly at the rated running capacity of the relay. On startup it draws almost 100amps - but that shouldnt be a problem cuz it wont be more than a few seconds.
Either way - let us know how it works out
98 TJ, goin crazy with the sawzall
[url=http://www.4x4tj.com]www.4x4tj.com[/url] - the Jeep
JeepCrawler98 is offline   Reply With Quote
Old 04-16-2004, 08:50 PM   #4
Damage, Inc.
Member # 20298
Yeah, it *will* be a problem. 'A couple of seconds' is a fricking lifetime in the electrical world. It'll probably work for awhile, but will fail you eventually, likely when you most need it.
I didn't read what he said, but he's right. - BHC
Damage, Inc. is offline   Reply With Quote
Old 04-16-2004, 10:44 PM   #5
bigjeepguy
Member # 15959
Besides, at most napa/schucks etc, I think you can get a thirty amp one for less than $8.00
I think it draws over thirty amps for a "substantial" amount of time, especially after what damage said. I base this on the fact that when I turn my Taurus fan on, with my stock alternator (don't have the cash to change it yet), the headlights go really dim for about 3 seconds, and then slowly go back up (correlating with how much power the fan is using). I would think it would be a better idea to use that relay for the low output, and a bigger relay for the high output.
Anyway, are you going to run a thermostat at all? Are you going to use both outputs, or just one?
BTW the title is very much appreciated for those of us newbies that tend to search every once in a while.
bigjeepguy is offline   Reply With Quote
Old 04-16-2004, 10:56 PM   #6
JeepCrawler98
Member # 18342
Well then - I guess I'm glad I'm running a continuous duty 85amp relay on mine (Napa ST85 - Continuous Duty Glow Plug Relay, also listed for use in Golf Carts) Keep in mind though too that the "rated" current draw for a relay is usually a few amps below what it can really handle. Unless you get the way cheapy made in china junk that falls apart as soon as you touch it. But for 8 bucks I hope you got something better than that.
Old 04-17-2004, 07:43 AM   #7
Balsax
Member # 22345
I tried a 30A and it didn't take long to fry! Like it was already said, the fan draws 30A after it's up to speed...It takes a heckofalot more just to start it!!! Get something like JeepCrawler98 is talking about. It will be cheaper in the long run and save you tons of grief!
Balsax is offline   Reply With Quote
Old 04-17-2004, 02:52 PM   #8
TJP
Mental Guru
TJP's Avatar
Member # 7595
Send a message via MSN to TJP
ttt
TJP-'89 MJ Project
Life's Journey is Not to Arrive at the Grave Safely in a Well Preserved Body. But to Launch Hard at Red Line, Shedding the Tires, Get Wicked Air, Land Hard, Drift in Sideways with the Tires Smoldering, Totally Worn Out, Thrashed, Screaming "Holy Shit What a Ride!!!"
TJP is offline   Reply With Quote
Old 04-17-2004, 02:52 PM   #9
TJP
Mental Guru
TJP's Avatar
Member # 7595
ttt
TJP-'89 MJ Project
Old 04-17-2004, 03:52 PM   #10
ItsaCJ6
ItsaCJ6's Avatar
Member # 6340
Good info... I am going to use the relay anyway and see what happens, since I purchased for another 8 bucks a 30 amp mini circut breaker and I already have a fuse holder. I have been runing my fan with just a switch and a fuse holder ,no problems so far with the 30 amp fuse. So I want to see how it works... using the relay
The main reason I doing this, since the switch has been working, is that I am rewiring this area for another reason and I am using Number 8 wire for the fan and wanted to ad somemore protection (fire is bad)
I'll get ya the part number Preach
Marc
-Hunter S. Thompson
-Hunter S. Thompson
Old 04-17-2004, 08:25 PM   #11
ItsaCJ6
ItsaCJ6's Avatar
Member # 6340
Originally posted by preach
How about a part #?
Here ya go.
275-226
Marc
-Hunter S. Thompson
-Hunter S. Thompson
Old 04-17-2004, 09:53 PM   #12
megolfer
megolfer's Avatar
Member # 17744
I just wired up my tauras with the starter relays first and it fried them. I went and got the ST85 from Napa and it works great. Ya it was $40, but know I wont be worried about it failing.
megolfer is offline   Reply With Quote
Old 04-17-2004, 10:27 PM   #13
thenodnarb
Member # 7252
Send a message via ICQ to thenodnarb Send a message via AIM to thenodnarb
why not use a solenoid?
[url=http://www.geocities.com/toyotatacoma2001]My Jeep Site[/url]
thenodnarb is offline   Reply With Quote
Old 04-18-2004, 07:37 AM   #14
JeepCrawler98
Member # 18342
Sure that could work - but you need to make sure its a continuous duty, or 100% duty cycle, solenoid. Your average gasoline engine starter solenoid will not like being turned "on" for long periods of time.
Old 04-18-2004, 09:32 AM   #15
doctor_G
Member # 3013
I'm using a Bosch 75A for my Mark VIII fan. P/N 0-332-002-156, cost was around $20.
"Instead of being a trail guide, you should put on a clown suit and give pony rides at kids' birthday parties"
94 YJ. 5.0 HO, NP435, NP-203 W/3.2:1/NP-205 WMS doubler, Bilstein/Alcan suspension, 104" WB.
60's front and rear.
doctor_G is offline   Reply With Quote
Old 04-18-2004, 02:26 PM   #16
HybridPOS
HybridPOS's Avatar
Member # 14442
Send a message via Yahoo to HybridPOS
I use a Bosch 75 amp, your fan will pull 33amp continuous, get something for twice the price and you wont have to replace it or have to worry about it on the trail.
Only makes sense to me....
83 CJ-7, 360 .030 over, shaved heads on the pane.
105 inches of noise and booger welds.
HybridPOS is offline   Reply With Quote
Old 04-18-2004, 07:18 PM   #17
bigcamojeep
Member # 20339
Send a message via Yahoo to bigcamojeep
Well these aren't cheap upgrades, but this is where my money goes. The permacool fans move 2950 cfm and draws only 9.9 amps. Flex-lite fans don't have the same cfm rating and generally draw 19.9 amps. I used a Perma cool on my built 305 in my YJ and never had a cooling problem. As far as power goes, 8 gauge wire is plenty big enough, and a 30 amp relay should be plenty. but remember to ground DIRECTLY to the battery, not the body.
Personally, I like Centech's fan controller. It's got the 30 amp relay inside, and it's got an electric sensor, not the leaky radiator hose probe.
http://www.centechwire.com/catalog/cooling/fc2p.shtml approx. $75
http://www.jegs.com/cgi-bin/ncommerc...14&prmenbr=361 approx $85
bigcamojeep is offline   Reply With Quote
Old 04-19-2004, 12:00 AM   #18
thenodnarb
Member # 7252
explain "don't like"
not saying your wrong, but what factors lead to a solenoid not "liking" the cycle length.
I understand a relay. the contacts can overheat and "fry" on lesser duty relays. it is my understanding that solenoids pull a large pin to connect the working circut. the only thing I can imagine wearing out and overheating are the windings that conrol the pin. so please explain
Old 04-19-2004, 12:27 AM   #19
LilRocky
Member # 28566
You're on the right track.
Little details like resistance and heat come into play.
LilRocky is offline   Reply With Quote
Old 04-19-2004, 12:43 AM   #20
HybridPOS
HybridPOS's Avatar
Member # 14442
A solenoid is a coil of insulated or enameled wire wound on a rod-shaped form made of solid iron, solid steel, or powdered iron. Devices of this kind can be used as electromagnets, as inductors in electronic circuits, and as miniature wireless receiving antennas.
In a solenoid, the core material is ferromagnetic, meaning that it concentrates magnetic lines of flux. This increases the inductance of the coil far beyond the inductance obtainable with an air-core coil of the same dimensions and the same number of turns. When current flows in the coil, most of the resulting magnetic flux exists within the core material. Some flux appears outside the coil near the ends of the core; a small amount of flux also appears outside the coil and off to the side
Old 04-19-2004, 08:44 AM   #21
JeepCrawler98
Member # 18342
That's exactly it - unless you get the proper solenoid of course.
Old 04-19-2004, 07:15 PM   #22
Recurve
Member # 3587
Send a message via AIM to Recurve
What's the deal with the relay that the Taurus uses? Is it mucho dinero? Anyone tried to snag one when they got their fan?
Recurve is offline   Reply With Quote
Old 04-19-2004, 07:48 PM   #23
ItsaCJ6
ItsaCJ6's Avatar
Member # 6340
Got the radio shack relay hooked up today........All is good. I am still using the switch instead of a temp sensor. Amp draw on high was only 28 using my meter and inrush was not a problem I put in smaller fuses to determine the inrush threshold and It pops 15's but not 20's so I am running with it...will see how it does in the long term..
Marc
-Hunter S. Thompson
-Hunter S. Thompson
Old 04-20-2004, 07:32 PM   #24
guinea13
Freak on Wheels
guinea13's Avatar
Member # 20873
I went to AutoZone and asked for a 75amp relay. I even gave them the part # for the bosch. They had no clue. They sold me a Ford taurus fan relay. Is there a reason that now one is using a stock ford taurus fan relay? It was only $10.
Hole! What Hole? ahh, shit That hole!
04' 2500HD Crew Duramax, Tow Rig
84' Jeep CJ7, D60, 14FF, 350TBI, 700r4, A work in progress......
www.twistedintentions.com
www.twistedfab.com
guinea13 is offline   Reply With Quote
Old 04-21-2004, 02:40 AM   #25
HybridPOS
HybridPOS's Avatar
Member # 14442
it was only $10? What is it rated at? Does the Taurus Fan controller take up some of the heat on the amperage?
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
