#1 |
ifs hub swap for solid axle...don't need a spacer
I have heard that there is no need for a spacer when doing the ifs hub conversion on a solid front axle to get the wider track width and upgraded brakes. You just mount the caliper on the other side of the existing solid axle mount tab which give you the 1/1.5" wider track. I heard this from an all pro guy that installed it on his own rig. Anyone ever try to do the ifs hub swap and not use a spacer? Did it work well? Or do you wish you had the spacer?
#2 |
Pirate4x4 Addict!
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
In my opinion, Unsafe, especially on a DD!!!!!!!!!
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ |
| Sponsored Links |
#3 |
thats exactly what I was thinking, but the all pro guy actually said this after I said I wanted to order the spacers. I'm basically wondering if any DDs have tried this setup? I have a daily round trip comute in my mini of 70miles and yep, I'm starting to go deaf.
#4 |
Member # 29957
I am running IFS hubs on a SA as my DD. If you look at a F350's brake setup it's identical to the way I now have mine. What difference does it make which side the caliper is on. You are still relying on a bolt to hold the caliper to the steering knuckle.
#5 |
Member # 21751
I saw some pics of one done that way, and I did this
for a while. After looking closer, I went . It looked very unstable and weak, but the guy said it worked great. Personally, I wouldn't feel safe with it on my rig.
'85 4Runner with chrome wheels and Pioneer 6x9s |
#6 |
Member # 21751
Went back and read the thread:
This one After reading it again, I think it probably would work, but it makes me a little nervous anyway.
#7 | |
Pirate4x4 Addict!
Member # 30
#8 |
Member # 9788
I am not saying that it won't work, but I have to wonder about anyone who compares anything to Ford engineering!!! I have worked w/ F350s for years and I don't trust a single part on the pieces of shit.
#9 |
Member # 16666
Location: Glendale CA, stright-outada armotown from the streets, around the corner through the alley across the quicky-mart under the bridge over the traintracks passed the Mcdonalds left behind the construction yard stright in the land fill, up over the hill
-IFS Hubs
-V6 Calipers -Vented Rotors This setup I did on my rig a few months back... been to the hammers with it no problem, sees 60-70 miles a day to work, school, and back had to mash and lock a up the brakes because of stupid CA drivers numerious times with no problem... [edit] if you are going to go this route... you have to weld a nut on one side of the caliper, or thread the existing hole so the bolt will go through and tighten. 2nd a either the knuckle or the caliper mounting surface requires to be machined flat, 1 because it needs to realine on the rotor and 2 contact surface (I took off .010 off the caliper) you will have to grind some of the inner wells of the caliper beacuse the fended rotors a almost contacting the sides. let me know if you need more info.
08 Rubicon 87 X-Cab Yota ...94 XJ (RIP)...01 Sahara (RIP)...86 CJ7 (RIP) Last edited by KarmirToy; 04-27-2004 at 01:34 AM. |
#10 |
Member # 16666
08 Rubicon 87 X-Cab Yota ...94 XJ (RIP)...01 Sahara (RIP)...86 CJ7 (RIP) |
#11 |
Member # 6650
Kamir has done it as best as can be done. It is important to machine the mating surfaces very precise. The only thing I do not like about that is the limited surface contact around the bolt head. I would use a large washer or machine a plate to cover the surface on the backside. It creates a shear point with just the head contacting. Otherwise I think it would work fine.
#12 |
thanks for all the great info KamirToy. I'll give it a shot and let you know how it turns out.
#13 | |
Member # 16666
lol... I just sqweezed the bolts in temporarly to take a snap shot... don't mean I didnt use washers at the end...
#14 |
Member # 638
sweet. i was just about to try this and could not find any info on it. thanks for the research and write up karmir.
TOYOTA FOR LIFE |
| Thread Tools | |
| Display Modes | |
