Pirate4x4.Com Bulletin Board
Old 04-29-2004, 08:34 PM   #1
aibornexj
aibornexj's Avatar
Member # 25636
Send a message via AIM to aibornexj
Toyota MR2 Surpercharged to truck tranny
I am currently working on a buggy project and I found a possible engine choice. A Toyota MR2 4agze motor supercharged... DOes any one know if the bolt pattern will bolt up to a truck transmission... The MR2 is mid engine and I cant use the tranny but a truck tranny with 2 transfercases would be real trick..
aibornexj is offline   Reply With Quote
Old 04-29-2004, 09:03 PM   #2
cdarthvader
Member # 20440
Send a message via AIM to cdarthvader
Well since that engine is made for a tranny to sit underneath i highly doubt it. I don't know if you can use an engine that is rear engine rear drive in a truck that is front engine rear drive.
*edit* not to mention the torque on those were horrible, You'd be better off with a 7mgte or a 6mge supra engine. And those have already been done to Lol.
I only break stuff so i can put bigger stuff on...
[QUOTE=ScottFJ40]A "Jesus Loves You" banner is much more asthetically pleasing, than a "Satan is Going to Dry fuck your asshole" banner.
[/QUOTE]
cdarthvader is offline   Reply With Quote
Old 04-29-2004, 11:12 PM   #3
Pooge
Pooge's Avatar
Member # 30019
Send a message via AIM to Pooge
what about the 2nd gen 3SGTE? those where turbo, so youd have some lag, but ive heard of people putting those in many different vehicles....some in things like old rear drive Carollas and such...
Doug
Pooge is offline   Reply With Quote
Old 04-30-2004, 07:59 AM   #4
BossMann
Member # 29984
The 3SGTE is a "tough as nails" engine...Toyota made them no better than that one. Also, I don't think it would work though.
BossMann is offline   Reply With Quote
Old 04-30-2004, 08:01 AM   #5
MR2
MR2's Avatar
Member # 25963
might look into the 18RG engine. DOHC, around 145 hp stock. the later versions were EFI(18RGEU). Toysport.com has lots of info about these engines, as well as the ones you mentioned.
First Gen 4x4, 22RE 5.29's, Welded Front and rear.
MR2 is offline   Reply With Quote
Old 04-30-2004, 11:22 AM   #6
KarmirToy
Member # 16666
Location: Glendale CA, stright-outada armotown from the streets, around the corner through the alley across the quicky-mart under the bridge over the traintracks passed the Mcdonalds left behind the construction yard stright in the land fill, up over the hill
Send a message via AIM to KarmirToy Send a message via MSN to KarmirToy Send a message via Yahoo to KarmirToy
if Im not mistaken that engine is a twin overhead cam setup... the screams over 4000rpms but has no juice at lower rpms. therefore it sucks for what we do.
08 Rubicon
87 X-Cab Yota ...94 XJ (RIP)...01 Sahara (RIP)...86 CJ7 (RIP)
KarmirToy is offline   Reply With Quote
Old 04-30-2004, 11:31 AM   #7
SR5Dave
Member # 15697
Send a message via AIM to SR5Dave
Yes and no. It just means you'll need even lower gears (say two 4.7 cases) then you'll be 'n
Wait, what?
SR5Dave is offline   Reply With Quote
Old 04-30-2004, 11:32 AM   #8
kyle_22r
Member # 24837
not to mention that the 18RG in any form is rare as hell in the states. lots of 18Rs in the junkyards from early 70s pickups though
kyle_22r is offline   Reply With Quote
Old 05-02-2004, 12:38 PM   #9
MR2
MR2's Avatar
Member # 25963
another idea.....What about getting a Supercharged MR2 engine, mating it to a Corolla GTS AE86 transmission, and running that to a divorced T-case?
Old 05-02-2004, 01:25 PM   #10
Pooge
Pooge's Avatar
Member # 30019
thats what i was thinking, is that you can run any of these engines with a little research into adaptability to trannies and go divorced. could be done pretty easily if you have ever done any other kind of engine swap not ment for the vhicle you are doing it in.... a little creativity and will goes a LONG way.
Doug
Old 05-02-2004, 03:21 PM   #11
SeaBass44
www.12voltguy.com
SeaBass44's Avatar
Member # 40
Originally Posted by cdarthvader
Well since that engine is made for a tranny to sit underneath i highly doubt it. .....l.
It was also used in std aplacations too.IE: same as our trucks. you can use the std type tranny and a divorced t case, single or dual, just find out what cars had the 4ag, think it was corola
LOTS of GUNS 4sale !
12voltguy.com /
Click here to email me
New # 530.532.4529
http://www.davezoffroadperformance.com/
OFN Fab BB
-89 1 ton bronco on 47" LTB's-
Hard work often pays off after time, but laziness always pays off right now.
SeaBass44 is offline   Reply With Quote
Old 05-02-2004, 05:02 PM   #12
Noel Tabor
Member # 18168
There is only one bellhousing out the from toyota that will work. it is from a 3S engine. The engine is in the IS100 form japan. Only car that i know of that as a 3sg3 or 3sgte that is RWD. the 3SGTE was in celica alltrac in the us but i am pretty sure the alltrac tranny will not work. You can use the AE86(corrolla gt-s twincam) tranny to a divorced t-case. you also will have to use a diferent starter than the factory 4agze engine.
check out www.club4ag.com they have lots of info for doing exactly this only 4agze's into NA corolla's.
p.s. if i could find a way to put a truck tranny onto a 4agze i would probably get rid of my mr2 just to do it in my truck. I love the 4agze great neat engine.
89 S/C, HKS PULLEY, SMT-6, HIGHCOMP
[IMG]http://members.cox.net/comjunky/Mr2%20Profile%20small.jpg[/IMG][IMG]http://members.cox.net/comjunky/Noels_Truck%20thumbsize.jpg[/IMG]
85 Pickup. to much to list but far from stock.
Noel Tabor is offline   Reply With Quote
Old 05-02-2004, 05:28 PM   #13
kyle_22r
Member # 24837
one of those mr2 engines sounds like it would be damn cool in a sand rail or something of that nature
Old 05-02-2004, 06:01 PM   #14
fatkid
fatkid's Avatar
Member # 4862
From what I have tried the JDM 4AGE will not fit the W-56 bell housing, I also tried to fit the Corrola bellhousing on the W-56. No workie.
[url]http://www.myspace.com/jerrywsparks[/url]
fatkid is offline   Reply With Quote
Old 05-02-2004, 07:30 PM   #15
OOP'S
Sobriety=Serenity
OOP'S's Avatar
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
That is a high rev engine with out much low end torque!!!! Would suck for rock-crawling unless you modified it with a low-end cam, lowered the compression and ran a heavy flywheel!!!!!!
David & Theresa, Roseville, CA,
Excellent Parts Source
http://www.marlincrawler.com/
http://www.12voltguy.com/web/
OOP'S is offline   Reply With Quote
Old 05-02-2004, 07:44 PM   #16
cdarthvader
Member # 20440
Yhea i was just thinking that that would be a sweet sandrail setup To bad there's no sands or dunes around here
[/QUOTE]
Old 05-02-2004, 09:18 PM   #17
Lord Orange
Member # 9001
Send a message via ICQ to Lord Orange Send a message via AIM to Lord Orange Send a message via Yahoo to Lord Orange
It could work......my buddy is working on putting his 3stge behind the Toy Turbo truck tranny in his ae86.
[URL="http://www.pirate4x4.com/forum/showthread.php?t=530797"]Don't be the nice guy anymore[/URL]
Lord Orange is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
