#1 |
Member # 20872
Dana 60 High Steer Studs! The real deal!
Well you asked for them, here they are.
* Fine threads on both ends * Custom made for Dedenbear by ARP * 220,000 psi tensile strength(stock is 180,000) * Fits all Dana 60 high steer arms D60112-----Single stud--------$9.00 each D60116K----4-stud kit---------$29.00($7.25 per stud) D60117K----5-stud kit---------$35.00($7.00 per stud) These are available now! Check out the drawing for the specs
Manufacturers of Dana 60, 44, 30 knuckles and Powerglide transmission cases. Any questions about our products? Like to place an order? Contact us! (925) 935-3025 M-F 9-5pm PST race.mail@reidracing.biz http://www.reidracing.biz Built by Rockcrawlers for Rockcrawlers Made in the USA! |
#2 |
Member # 4830
Do they have the thicker "shoulder" in the non threaded area, like GM units?
beerman |
| Sponsored Links |
#3 | |
Member # 20872
If you are running tapered nuts or washers the studs will be centered in the holes and will not touch the walls of the arm, whether the holes in the arms are .501 or .550
#4 |
Member # 20092
I just bought two sets from you for my highsteer arms, and the studs I received are fine thread on one end and coarse thread on the other. Is it possible to swap them out? I was surprised to see this when I received them, I figured they would be fine thread on both ends due to the large forces placed on them from the steering arms.
Thanks
1985 Jeep CJ7, Ford 5.8l SEFI, C6, Atlas II 4.3, linked, 60/14b, detroits, 42s w/stauns. |
#5 | |
Member # 20872
Ryan
#6 | |
How about nuts? After reading Billavistas High steer article I have been having trouble finding the right kind of nuts. I ordered them from GM but ended up with a Crimped nut and not a tapered nut. All I know is you are not supposed to run a lug nut, Have any hardened tapered nuts?
#7 | |
Member # 37
Ryan, just a suggestion, deleting your previous bumps would clean this up a bit
[url="http://www.colorado4x4.org"]Colorado4x4.org[/url] Wheel the Rockies |
#8 |
Member # 20872
#9 | |
Member # 4830
#10 | |
Member # 1170
Yeah we had just noticed that, the check is in the mail to get it back up.
77 CJ7 "One Week Jeep" [SIZE="4"][COLOR="Green"][URL="www.taylor4re.com"]www.taylor4re.com[/URL] [/COLOR][/SIZE]Click here for all your real estate needs |
#11 |
Member # 20872
Yellow star is back!
| Thread Tools | |
| Display Modes | |
