Pirate4x4.Com Bulletin Board
Old 06-10-2004, 08:47 PM   #1
Foxfab
Member # 2058
Send a message via ICQ to Foxfab Send a message via AIM to Foxfab Send a message via Yahoo to Foxfab
What to use on floor?
Whats the preffered floor covering on bare concrete floors? I'm looking for something that'll take the plasma cutter and welding sparks. Is there such a thing?
Undoing years of Toyota engineering one SAS at a time!!
2007 Yaris--1959 FJ25--www.yankeetoys.org
Foxfab is offline   Reply With Quote
Old 06-10-2004, 11:38 PM   #2
camo
Attention Whore
camo's Avatar
Member # 4
Send a message via Yahoo to camo
I have always painted mine with International 2 part epoxy paint. there are several tricks to acheiving a good finish.
1. cleaning, i pressure wash the floor and allow to dry for at least a day.
2. chemical prep. i scrub it down with lacqure thinner.
3. temp. MAKE SURE the concrete is at least 75 degrees before painting and does not drop below that until dry. ( i usually leave the heater on in the shop for several days prior to painting to make certain it is heated throughly)
I find that the floor holds up for about 3 years before needing a fresh coat. my floors have been done this way for about 15 years.
chuckie is a douche bag
Originally Posted by FISHMOUTH FABWORKS View Post
GOT-DAMMIT KURT! Get the WHORE off the RIG!
camo is offline   Reply With Quote
Old 06-11-2004, 09:33 AM   #3
The Joker
Member # 943
When I was in construction I worked on a jiffy lube building and in the last coat or second to last coat they sprinkled sand on the floor as they were painting for traction. Maybe something to consider since epoxied floors can be very slippery.
The Joker is offline   Reply With Quote
Old 06-11-2004, 02:35 PM   #4
HandBuilt
Member # 13395
What about tile?
If you had a really straight nice slab to cover, why not put some industrial tile on it? Imagine how easy to clean that would be. Does anyone have experience with using tile on a garage floor? And not the plastic interlocking stuff, either. Something that would hold up to grinding, welding, etc. I guess if you were to drop something like a hammer on it it might break though, if it was hard enough. Just an idea.
J-L
JL.
Trailer queens. Must be a west coast thing.
HandBuilt is offline   Reply With Quote
Old 06-11-2004, 03:08 PM   #5
The Joker
Member # 943
Originally Posted by HandBuilt
What about tile?
J-L
For me the main reason would be cost and I think tile would still be very slippery. Im just on plain ole concrete myself havent epoxied painted or anything fun yet.
Old 06-11-2004, 03:37 PM   #6
Jam Master Jay
I should be working
Jam Master Jay's Avatar
Member # 18829
I know this is of little use to anyone with their shop already built, but when I build my shop I plan to have the floor finished with a ride-on troweling machine until it's got a mirror finish. That way I shouldn't have to worry about porosity soaking up oil etc and I won't ever have to worry about coatings flaking or having to be reapplied.
On an existing floor I would use industrial epoxy. If I remember the names of some stuff I'll post it. We use it all the time on new projects.
Ride 'Em Cowboys !
Jam Master Jay is offline   Reply With Quote
Old 06-11-2004, 04:41 PM   #7
Murph
Dog is my co-pilot
Member # 15246
Our warehouse floor is like this, and it's a skating rink when it's wet.
Andy
Murph is offline   Reply With Quote
Old 06-12-2004, 03:08 AM   #8
speedo
speedo's Avatar
Member # 23262
When our current shop was built they used a white pigment in the concrete and the floors are white all the way through and it helps with the lighting.
Gus
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
--Herbert Spencer, English Philosopher (1820-1903)
speedo is online now   Reply With Quote
Old 06-12-2004, 08:59 AM   #9
Brandon
Pirate4x4 Addict!
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
why coat the floors? I drop stuff all the time, weld on the floor, etc.. I can't imagine ANYTHING taking that abuse? Sure it looks good but for a metal shop?
This Space for rent!
Brandon is offline   Reply With Quote
Old 06-12-2004, 02:44 PM   #10
kpj
Ridge Runner
Member # 6920
I vote for the epoxy coating. At the shipyard that I work at, that is what we use on the floors and it withstands all sorts of abuse...welding, grinding, oil, alcohol, etc... You can wash, hose, buff as you see fit, or just let it be and repaint in another few years.
kpj is offline   Reply With Quote
Old 06-12-2004, 03:20 PM   #11
tdavis
tdavis's Avatar
Member # 908
Polished concrete floor.
Seriously good stuff, time consuming and expensive I'm told.
I take my zuk out for walks.
tdavis is offline   Reply With Quote
Old 06-12-2004, 06:03 PM   #12
camo
Attention Whore
camo's Avatar
Member # 4
we are pouring the slap for my new shop on monday and will put a polished finish on it. i was going to color it black but decided againt it since we will be filming some video stuff in it and need a brighter color.
Old 06-12-2004, 06:04 PM   #13
camo
Attention Whore
camo's Avatar
Member # 4
cause it looks good been welding, fabricating, driving forklifts and generally beating on my painted floors for years and it holds up great.
Old 06-12-2004, 06:11 PM   #14
surlynkid
surlynkid's Avatar
Member # 4464
can you put that 2 part epoxy down on a garage floor that is already the rough, brushed finish? i destroy my clothes and tools sliding back and forth across that rough surface.
only the dead have seen the end of war
1995 T100 - finally done
1988 4Runner - DD
2005 CTD 600, 4x4, NV5600 - Tow Rig
surlynkid is offline   Reply With Quote
Old 06-13-2004, 01:25 AM   #15
camo
Attention Whore
camo's Avatar
Member # 4
actually you will probally get better adhesion with a brushed finish since the surface has more open pours for the paint to adhere to. with a smooth surface you have to be carfully to get the floor very clean to get the paint to stick and not peel
Old 06-13-2004, 08:32 AM   #16
Brandon
Pirate4x4 Addict!
Brandon's Avatar
Member # 6
I didn't realize it could hold up to some abuse, figured it was more for a show car garage..
How about someone make this thread worth something.. add some pics
Old 06-13-2004, 01:52 PM   #17
camo
Attention Whore
camo's Avatar
Member # 4
perty
Old 06-13-2004, 05:21 PM   #18
Brandon
Pirate4x4 Addict!
Brandon's Avatar
Member # 6
wow, hard to clean? Where did you get that stuff - Lotsa places are selling some epoxy kit in the ads now - pep boys or whatever..
Old 06-13-2004, 05:26 PM   #19
camo
Attention Whore
camo's Avatar
Member # 4
be carful with the crap the mass merchants sell ( home depot ) cause it is water based latex and does not hold up well. the good stuff is only sold at real paint stores. you want a two part epoxy with the it's gonna kill you warning labels on the can.
no it is not hard to clean. i just mop it once in awhile and if i really wanna get it shinny i will hit it with a floor buffer.
Old 06-14-2004, 05:25 PM   #20
BillaVista
Web wheeler/welder
BillaVista's Avatar
Member # 3547
perty
Camo you pussy - that's not a shop floor, that's a fawkin ballet studio
THIS is what a real man's shop floor looks like !!
I find the deep crevices add a satisfying challenge to trying to roll anything across the floor, particularly a floor jack masquerading as a tranny jack with a 203 doubler balanced precariously on it!
BillaVista
See my tech articles:
Pirate4x4.com Tech
Back up...a little bit...and come with it. Would ya just take the skirt off...and drive!
- Charlie M
Originally Posted by BootsntheJeep View Post
Oh for God's sake man, don't burden these obviously talented and skilled people with ENGINEERS.
BillaVista is offline   Reply With Quote
Old 06-15-2004, 08:54 AM   #21
xj4rocks
Member # 9287
Rust-o-leum has a floor epoxy that they call their "industrial epoxy" It's a true 2 part resin expoxy. I bought it at home depot has held up very well so far to 2 years of abuse. I weld, throw tools and about any part I can think of and it has only just scratched the surface...nothing down to the concrete. Rust-o also makes a 1 part water based epoxy which is junk.
The floor has to be cured for at least 30days for many epoxies and then you clean the floor with muratic acid or some such which you scrub on with a deck brush. Then rinse and epoxy. I am VERY glad I did this. Floor gets oily? out comes the mop and I clean it like the day I put it down. i would suggest adding a little bit of sand. as was said earlier, this stuff gets slicker that snot when wet.
88 XJ 8"/36s/locked
when I grow up - I don't want to be like you
xj4rocks is offline   Reply With Quote
Old 06-15-2004, 01:03 PM   #22
tsm1mt
Member # 2071
Send a message via AIM to tsm1mt
Before everyone screamed it was junk, I bought 3-4 gallons of the Behr stuff from HD..
After brooming, washing, degreasing, acid-etching, and rinsing.. we primed...
Then painted..
That was a year ago..
Haven't done much wrenching.. but oil wipes up easily.. and it held up to the sheetrock party..
And here's after we finished roughing in the wiring and air system, Corbond insulated the walls, 'rocked the ceiling and walls, taped, mudded, and put down two coats of White Walmart primer n' paint on the walls and ceiling.
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote
Old 06-18-2004, 08:59 AM   #23
Jam Master Jay
I should be working
Member # 18829
For those of you with the sand/epoxy mix on the floor do you find it troublesome when rolling stuff across it or laying on it? I'd think I'd rather trade having wet traction for having a nice smooth surface.
Also, I guess part of it is climate you live in. In OK my garage would see a lot less wetness than a garage in the snowy north.
Ride 'Em Cowboys !
Old 06-18-2004, 02:32 PM   #24
pcorssmit
Member # 4406
I used the same stuff last summer, its holding up quite well. The only thing that really hurts it is big gobs of spatter if booger welding overhead. If I'm going to be dropping a lot of boogers on the floor (like when welding up my rusty paper thin headers) I throw an old piece of sheet metal under it, otherwise I don't worry too much. I didn't put any sand in it, but I don't park my DD in there either, so its usually not wet. But its a death trap if you spill anti freeze. It did noticably brighten up the shop, too.
I think for a new pour though, the polished white concrete would be great.
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote
Old 06-18-2004, 02:42 PM   #25
welndmn
Well Done Man!
welndmn's Avatar
Member # 398
Send a message via ICQ to welndmn Send a message via AIM to welndmn Send a message via Yahoo to welndmn
I used the Rustolem shop paint, held up pretty good, but brake fluid ate large holes in it.
I am recosting it with the $$$$ stuff from the paint store
Mark
71 Bronco. 42's and bolt on goats.
welndmn is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
