#1 |
www.12voltguy.com
Member # 40
lets see pics, easy homemade jackstands
post um up
. . . LOTS of GUNS 4sale ! 12voltguy.com / ![]() Click here to email me New # 530.532.4529![]() http://www.davezoffroadperformance.com/ OFN Fab BB -89 1 ton bronco on 47" LTB's-![]() Hard work often pays off after time, but laziness always pays off right now. |
#2 |
Member # 908
I'd like to see TALL ones - ie, ones that can go up like 3ft in the air..
![]() Anything higher than say the 6ton HF ones would be a good start!
I take my zuk out for walks. |
| Sponsored Links |
#3 |
www.12voltguy.com
Member # 40
yes tall ones is what I'm talkin about
#4 |
Member # 26181
That would be nice, I just bought the HF 6 tons today. Had to use blocks under them.
Jon, old toyota with a broken stero |
#5 |
Member # 6398
Welded angle to the HF specials:
but I also like the idea of just welding them to old wheels. note the ones in the pic have WAY more extension available, they're only open to like the 2nd notch, but I'm now limited by how high my floor jack can take a vehicle.
HOA communities: Little boxes, on the hillside. Little boxes made of ticky-tacky |
#6 |
No pics, but I went to a friends house who had the regular jack stands welded to a set of 15" steel rims. Very stable and gave the added height to work on lifted trucks.
EDIT: Guess this qualifies as "old wheels"
Undoing years of Toyota engineering one SAS at a time!! 2007 Yaris--1959 FJ25--www.yankeetoys.org Last edited by Foxfab; 06-14-2004 at 11:34 AM. |
#7 |
Member # 26495
"There are no such things as accidents—just two people competing for the same point on the space-time continuum." —Linda G., ER nurse and administrator |
#8 |
Member # 7938
These look go to me. Tall & strong. They belong to Logjam-grant.
Didn't someone make some adjustable stands something like this with some 1" threaded rod?
I love plywood |
#9 | |
www.12voltguy.com
Member # 40
soon as I find some cheap steel
#10 |
Arizona Trail Riders
Member # 1418
I made some like the ones above but I didnt make them adjustable ....... made four of them tall enough (40") for the suspension to droop and get the axles on and off
![]() I was bummed I couldnt take them when I moved to Az from Ca ........ I should have fed Ex'd them .........
You need a Thneed 84 Toyota CJ2a Get Propane |
#11 |
Pirate4x4 Addict!
father n law was an airplane mechanic and has some super tall jack stands I was thinking of using - but for my needs the tall version of the HF jacks has done great, and for the price not worth breaking out the welder!
This Space for rent! |
#12 |
Newbie with a Star
Not really a jackstand but a friend built this to work on the under side of his z. I was very skeptical when he told me about it but it was VERY sturdy and the car would not budge
#13 |
Here is what we use...and they are stout. They work great for holding up frame snouts.
WWW.MAD4WD.COM Phone: 330-549-9082 Custom Axles, Machining, Welding and Bending Custom Ford 9", Dana 44 & Dana 60 Axles Dana 60 & Dana 44 High Steer Arms Tube Clamps Bilstein Shocks - In Stock |
#14 |
#15 |
www.12voltguy.com
Member # 40
those are nice
bought or built? look like alot of work to build, I'm thinking factory made
#16 |
H M F
Member # 8758
Figured I would bring this back up to add the ones I built.
Base is 2' of 2" pipe with 3 1" supports. 2" .120 inside of that. 1" allthread is supported by some 1 1/4" .120, and a couple small 1 1/2 and 1 3/4" sleeves to keep the allthread centered. Welded a washer to a nut and another washer to the tube, then welded the bent plate to the top of the allthread. Welding magnets held the tube in place and square to tack the supports on. Still have a little left to do, straps to tie the supports together and handles, maybe removable so I can turn it with a wrench if there isn't enough room for the handles. Thinking of threading a bolt into the top of the base piece so I can tighten up the slop. Fully extended, it can move about 2" side to side. Max height - 58 1/4" Min height - 25 3/4"
Team Unite V2R, 4454 right seat...some day! KOH '09 - #004 Team HMF, we kicked Shannon's ass! SSS 4x4 - The worlds only 16.5" sticky supplier! www.F-O-A.com H . M ..F
#17 |
Member # 10462
This set is mine, made 8 other sets for guys with tubeframe race car chassis so they could get them up in the air and leveled out good. Mostly made from cutoffs of 1.75"x.120 DOM for the main tube and HREW for the legs. The center piece is 1.5x.250 with an adjustable threaded end. What I really like about them is there is very little play at all so when they're up high it's still hardly any movement side to side.
Tell ya what Seabass, I can make ya a set and do some trading.
MySpace crap |
#18 | |
www.12voltguy.com
Member # 40
those are pimp
#19 |
www.12voltguy.com
Member # 40
Pimp-ologist
#20 | |
one shot, one thrill
Member # 26382
87 4runner d44f/9"r full width, 5.38/5.43/ARBs, superior shafts, ctm's, twin stick 4-1 dana 300 behind toy t-case, allpro springs f/r, 39.5 iroks on aluminum trail ready bead locks ΜΟΛΩΝ ΛΑΒΕ It doesn't have to be practical to be tactical
#21 |
H M F
Member # 8758
Yeah, check out the one on the left. Allready has the handles. And it has already lifted a couple rigs off the ground from just turning the handle. Has about 9" of lift from the allthread.
#22 | |
Member # 26382
#23 |
Rotten Sperm
Member # 63386
Mine isn't totally DIY but I welded D60 drum brake drums to the bottom of 2 HF cheapo's.... I thought I had pics of them on this computer but I guess not
#24 |
Member # 52074
HF with 14 bolt drums. Cheap and works great.
[URL="http://bronco.tophersworld.com/"]Bronco.tophersworld.com[/URL] 1990 Full Size Bronco Camo Paint SAS 8 Lug. D44 Front 14B Rear |
#25 |
OCX Off Road Audio
Member # 72810
I bought these from a welding supply, but I love 'em. I can lift the front of my heavy chevy by turning the t-handles. They're called black jacks. For smaller stuff and axles I use HFs on rockwell drum covers.
OCX Off Road Audio ******* Wake Board Speaker, Amp, Wiring Package Special $155 through NOVEMBERPrice Dropped http://www.pirate4x4.com/forum/showt...2#post10443342 Rock Spotter Cam/Monitor Combo Special http://www.pirate4x4.com/forum/showthread.php?t=833962 |
| Thread Tools | |
| Display Modes | |
