Pirate4x4.Com Bulletin Board
Old 06-14-2004, 07:48 PM   #1
Lickitysplit
Member # 14227
Tacking axle brackets
I'm building an 8.8 for my TJ and want to place the brakets myself then take them to a shop to weld up good & proper. I don't have a welder, and have no prior experience. My reasoning for placing myself is that I really don't trust any shop around here to both have the knowlege and take the time to place the brackets exactly where they should be. While we're at it, I'd rather fuss the details myself (something i'm good at) at let them fuss the welding strength (something that hopefully they're good at).
What's my most economical & safest way to do this? I know i can rent a 100amp welder from Home Depo for $27 / 4 hrs, but this seems more equipment than i should need for tack welding. However it does come with a face shield, which i would otherwise have to buy.
What are your suggestions?
TIA.
Cheers.
Devin
Lickitysplit is offline   Reply With Quote
Old 06-14-2004, 08:21 PM   #2
BillaVista
Web wheeler/welder
BillaVista's Avatar
Member # 3547
Renting a MIG welder seems like a good idea. Do some reading first (Hobart, Miller, and Lincoln sites) and you should be fine to tack stuff in 4 hours.
Remeber prep is everything (fit up, cleanliness, etc)
Not that I'm in any way qualified to give any kind of welding advice
BillaVista
See my tech articles:
Pirate4x4.com Tech
Back up...a little bit...and come with it. Would ya just take the skirt off...and drive!
- Charlie M
Originally Posted by BootsntheJeep View Post
Oh for God's sake man, don't burden these obviously talented and skilled people with ENGINEERS.
BillaVista is offline   Reply With Quote
Old 06-15-2004, 06:21 PM   #3
64Trvlr
Member # 6582
Have you thought about getting everything all together and having a portable welder come over and weld it on site? That way you can be sure everything is in the right spot before he leaves.
[QUOTE=Muddin]You must be able to blow harder than me [/QUOTE]
[QUOTE=Bubba Ray Boudreaux]Shooting is gay.[/QUOTE]
64Trvlr is offline   Reply With Quote
Old 06-15-2004, 09:03 PM   #4
BrettM
Member # 11998
Send a message via AIM to BrettM
paying $27 to rent the welder, then taking it to a shop would probably be cheaper than a portable welder coming out.
you could even JB weld all the brackets in place then take them to a shop
awshifting.com
awshifting@gmail.com
BrettM is offline   Reply With Quote
Old 06-15-2004, 10:22 PM   #5
64Trvlr
Member # 6582
By the time he pays for the rental the time and gas to get it and take it back, then takes it to a shop he might be money ahead having it done on site. Call around tell them what you need and that it's ready to be welded whenever they are in the area and see what kind of quote you get. If you have it ready to go it shouldn't take more than an hour to zip it up. Whatever you do DON'T JB weld it because then you'll be paying for them to clean it off so they can weld it.
Old 06-16-2004, 09:43 AM   #6
tsm1mt
Member # 2071
Send a message via AIM to tsm1mt
What about buying a face shield and using some jumper cables to string 3 batteries together to make a crude DC stick welder to tack things in place?
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote
Old 06-16-2004, 11:35 AM   #7
64Trvlr
Member # 6582
That would be quite a learning curve for him.
Old 06-16-2004, 02:16 PM   #8
Lickitysplit
Member # 14227
And actually this is something i had in the back of mind. I have a Optima Yellow Top & a Mean Green 200Amp alternator. Can I tack weld on the Jeep's juice? My thinking was for the price of the rod & shield I can just rent the FCAW (Lincoln Weld Pack 100).
Old 06-17-2004, 09:43 PM   #9
doctor_cad
Member # 29609
Send a message via MSN to doctor_cad
Get some clamp-on style brackets. You just clamp 'em loose, then play with the angles. Once you're happy, clamp em tight. take the axle down to the welding shop, and they can weld the brackets up solid for ya. If you take it REAL FAWKIN EASY you could drive the rig down... Once theyre welded, you can remove the clamp piece if you want.
doctor_cad is offline   Reply With Quote
Old 06-17-2004, 10:27 PM   #10
Lickitysplit
Member # 14227
Nice idea doc... if i had leaf springs.
Old 06-17-2004, 11:00 PM   #11
doctor_cad
Member # 29609
Argh... Guess I should have read your posy a bit more closely!
Old 06-18-2004, 12:48 AM   #12
braxton357
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Fwiw, and if there are no other options, you can usually find a small flux only mig at harbor freight for less than $100 and it wouldn't be too much shittier than that 100 amp from HD. Then at least you'd have something to show for that 100 that you just wasted.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
98 locked beater xj on N20.
braxton357 is offline   Reply With Quote
Old 06-18-2004, 06:29 AM   #13
kwrangln
DOUBLEWIDE ENGINEER
kwrangln's Avatar
Member # 6971
So there is nobody else who wheels or builds jeeps in Wi? No clubs? No one you know or can find that has a welder?
I'm the "tack tack tack" welding nazi.
http://www.pirate4x4.com/forum/showp...&postcount=218
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote
Old 06-18-2004, 07:53 AM   #14
ZJim
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
If you're going to tack it, why not just go all the way? I've been looking at cheapie welders for 100 bucks or so from Harbor Freight. Not the best, but then again... I'm not much of a welder either.
Might be something good for you to learn on, so in the future you can fabricate all the shit you want. If you're in the process of an axle shop I'm sure there's a billion things in your near future you might enjoy having a welder around for.
ZJim is offline   Reply With Quote
Old 06-18-2004, 08:23 AM   #15
kwrangln
DOUBLEWIDE ENGINEER
kwrangln's Avatar
Member # 6971
Are you actually suggesting that he learn to weld with a buzzbox putting his axle brackets on? What, are you fawking nuts?
Old 06-18-2004, 03:59 PM   #16
Lickitysplit
Member # 14227
Yeah as much as i'd like to learn to weld i don't think axle brackets are the place to do it. I've been asking around and no freebie welding yet. There really is nowhere to wheel around here, I typically end up driving to Badlands for a couple weekends a year. In fact I blew my D35 pinion on an I-80 onramp heading to Badlands.
Old 06-18-2004, 06:23 PM   #17
braxton357
braxton357's Avatar
Member # 14685
Haha riiight....he lives in wisconsin.
Although, on the other hand...most farmers/ranchers have welders. Might be a place to look?
In vino veritas
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
