Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > Shop and Tools
Thread Tools Display Modes
Old 06-16-2004, 12:56 PM   #1
unimogken
snatch cannon
unimogken's Avatar
Member # 11745
Plumbing your garage/shop for air.
Lets hear some ideas and see some pictures of your set ups.
I'm in the process of planning out my projects and I pretty much have in mind what I will be doing with my power. So, now I need to think about my air system.
Theres another thread that covers air compressors so I thought that this would be a good thread to cover the plumbings side of things.
Off we go ! !
Later, Ken
1 Mercedes Benz Unimog 404s
unimogken is offline   Reply With Quote
Old 06-16-2004, 01:14 PM   #2
D60
D60's Avatar
Member # 6398
I'm just using Type M brass.
My gf's father used brass and did a zillion quick connects, just like outlets, throughout..........but honestly I don't see the advantage.
I'm just gonna have two hose reels with 50ft each. I've been getting by with one hose reel for quite some time, and one dedicated line to where the plasma usually sits near the bench.
I REALLY HATE having to roll/coil hose, just like I hate extension cords that are over 10ft long (always tangle). I figure my two reels will reach anywhere in the shop, so don't see the need for multiple outlets.
But the hose reels are sweet, VERY easy to roll the hose back up, stores on the wall out of the way, always "plugged in," and you can just roll out as much as you need.
Speaking of, I need to get some of the self-retracting electrical cord reels, maybe then extension cords and I can get along.
Plus with electric you might have a cordless fone, fridge, drill press, band saw etc etc etc always plugged in, but for me with air I'm only using one or two tools at a time and they don't stay "plugged in" 24/7..................so I just don't see the need for lots of air outlets. And very few air tools are stationary like a drill press. One or two outlets outside, tho.
EDIT: this one works well for me, comes with 30 ft but I replaced it with 50ft (fits fine)
http://www.harborfreight.com/cpi/cta...emnumber=40131
and I'm not certain but suspect this might be the same thing Northern sells under the "Rapid Reel" brand name for much more $$:
http://www.northerntool.com/webapp/w...ctId=200224724
at the very least the bodies and handles look identical. Wall mounts might be different,tho..........
HOA communities: Little boxes, on the hillside. Little boxes made of ticky-tacky
D60 is offline   Reply With Quote
Old 06-16-2004, 01:30 PM   #3
plunkinberry
cranky bastard
plunkinberry's Avatar
Member # 20868
I work in a 2 car garage. My compressor is on the front wall. Line out to a flex line to black pipe up the wall and across the ceiling and down between the 2 garage doors. This is where I have my seperator/regulator/etc... One drop with a dirt leg. I screwed up and used unions and pipe dope and some of my connections lead, but I've heard tell that you need some real distance between the compressor and the seperator to cool the air so that the seperator can do its job and get the moisture out of the air.
Brass would be nice, but you'd need to sweat all those joints and it would be difficult to add stuff later - although the way I'm currently set up, it won't be easy to add stuff either... Whatever you do, don't use plastic.
I have been in shops that only use hose line.
plunkinberry is offline   Reply With Quote
Old 06-16-2004, 01:34 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Member # 7903
The local costco has a hose reel, and I keep thinking about getting it, but I wonder if it is junk. Has anybody tried it?
I was watching "two guys garage" the other day on the speed channel, and I saw them putting in this quick connect stuff. I just check the web site and it costs about 2x what it would to plumb it. It did look cool, so those looking for the bling might like it. garage pak
My hookup is still the sad setup. Compressor in back of garage next to some shelves and a 50' hose to get it where I need it. I do hate the constant running over of the hoses and electrical with jacks or my creeper. If I thought I would be at this house more than a year or two, I would seriously think about setting it up better. Part of me still thinks it would make it worth it, even if I didn't get my money back when selling.
2001 TJ Now with 4.7 V8 power : 1975 Wagoneer
JohnnyJ is offline   Reply With Quote
Old 06-16-2004, 01:37 PM   #5
Brandon
Pirate4x4 Addict!
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
I bought the $80 one from Harbor Freight half off and actually I reaaaally like it! It is in the middle of my garage and I use it for most of my stuff. My compressor is in the front corner and T's off to a hose that is coiled on the sideyard for stuff out there as well. I have PVC routed all the way around my garage, just need to run the down lines, I plan on having a couple or so near my bench so I can make some real short like 3' hoses for work on the bench, one poking out the front of my garage for air there, and one through the house to the other side where I have a small shed.
This Space for rent!
Brandon is offline   Reply With Quote
Old 06-16-2004, 02:33 PM   #6
tsm1mt
Member # 2071
Send a message via AIM to tsm1mt
I went with 3/4" galvanized, because I've never worked with copper. Bought a cheap pipe threader, some pipe dope, and 100+' of 3/4" galvanized from Home Depot and a pile of elbows and other fittings.
I put a full circle in the attic, looping around, but leaving the center of the trusses open for access (for now, until it gets insulated).
I put a 5' tall (30gal?) upright air tank at the far end of the loop (from the compressor), and made it the lowest point, with a through-the-bottom-and-ceiling drain point.
The pipe came in 10' lengths, so when convenient, I put drops at the 10' mark.
8 drops, plus the drain, in my 34x28 shop, including the "supply" drop.
One drop in the ceiling on either side of my work bay. I have one 3/8x25' reel, and I'll get a 3/8'x50 for the other side.
Putting a reel on either side so I won't have to drag the hose over the hood, etc. to get to the other side.
If you look roughly at the end of the garage door track, just inside on the "far" end, and between the two door tracks in the center, you can make out the stubs coming through the ceiling. In the far corner you can see a pipe running down the wall, for another drop. Just above the window is the drain pipe coming from the tank.
The one in the corner comes out of the top of the air tank in the ceiling. Air gets compressed by the compressor in the corner "behind/left" of the photographer, goes up the wall to the peak of the roof, where it enters the "full loop" supply system. It slopes down 34' to the far end of the shop, where the air tank is.
The "corner" drop takes air out of the top of this tank. This should be the driest air in the whole system, and will be used for painting when the time comes.
All other drops come from the "loop" system, and go "up" before going "over and down" to try and keep water in the "loop" (and ultimately, in the tank and the drain pipe) and out of the "drops".
This shows the corner drop better.
So I'll have an overhead reel on either side of the work bay.
Gonna have a regular disconnect in the corner.
There's a drop coming down the wall between the two garage doors. Either between the doors, or in that corner again, will be the 100' manual wind reel for going outside.
Two drops above the work benches. One will probably just get a reel, the other will come down the wall to a disconnect, and will also "T" and run THROUGH the wall outside, to the back of the shop (the point about as far from the "between the garage doors" reel as possible).
Another drop in the opposite corner from the first will probably just come down to a disconnect for now, but will provide a good spot for a blow gun or something. This is also a potential location for an aux air compressor.
The compressor will be mounted above my oven. This is how I have it set up at my mom's:
Same basic idea, but I'm putting the 5hp 220 horizontal at my place and leaving the 1hp 2-stage 30gal 220 horizontal up there at mom's.
I'll supply the blast cabinet with a drop straight from the compressor, and probably have a quick connect in that general vicinity just because it's easy.
I've been tripping on a single host strung through the shop for too long. So now I'm overkilling.
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote
Old 06-16-2004, 03:14 PM   #7
AthlonAJ
AthlonAJ's Avatar
Member # 10462
About using PVC, not a very good idea at all. Yeah yeah yeah, I know some guys have had it for years and no problems, blah blah, but it's not designed for compressed air so why use it? The place I used to rent had airline run using PVC, one day out running the DA and BOOM, plastic shrapnel fawking hurts!! Glad I was wearing my safety glasses at least. I have no clue why it burst, looked like it happened at a 90 joint that was in the corner, nothing else around it so not like it was damaged to my knowledge.
At my shop now I ran all copper line, use 1 hose reel for the bay and an outlet at the workbench and one where I do all the fab work. The plasma/welder is all on a cart where I run 2 hoses(weld gas/air) and electrical all bundled together, works slick. The hose reel is a cheapo Harbor Freight self rewinding job, doesn't leak yet and have had it for about 9 months.
AthlonAJ is offline   Reply With Quote
Old 06-17-2004, 09:22 AM   #8
D60
D60's Avatar
Member # 6398
PVC contracts and expands too much with temperature changes, it will eventually fatigue and go boom as you discovered.
Old 06-17-2004, 10:39 AM   #9
AthlonAJ
AthlonAJ's Avatar
Member # 10462
Funny part about that whole deal was my landlord blamed me for it and tried to make me pay for it. Granted it was only a couple bucks worth of material but I told him to shove it up his ass sideways, he should be thankful I didn't get hurt. Nevertheless I promptly unhooked my compressor from it.
Old 06-17-2004, 02:40 PM   #10
killertoy
Member # 23293
I have my 50x75 and adjacent 30x20 shop plummed for air with copper tubing every ten feet a fast coupler facing up at a 45 then every other one has a 6" piece with a drain petcock for water. The fast couplers got spendy but overall a prett nice setup I have 20' foot hoses so it reaches everywhere in the shop and we have multiple users so everyone is happy. It doesn't cure the hoses on the floor prob but it isn't that hard to rap up 20' hoses. All the tire changers, used oil furnace and bead blast cabinet are plumbed in directly to them because they do not need to be disconnected.
killertoy is offline   Reply With Quote
Old 06-18-2004, 04:38 AM   #11
Sixty-Ninth Airborne
Member # 31672
Originally Posted by killertoy
...All the tire changers, used oil furnace and bead blast cabinet are plumbed in directly to them because they do not need to be disconnected.
Used oil furnace? With compressed air? Huh?
Sixty-Ninth Airborne is offline   Reply With Quote
Old 06-18-2004, 12:11 PM   #12
Firefyter_Emt
Firefyter_Emt's Avatar
Member # 2192
Ok, Here is a question.. How many of you run 1/2" copper v's 3/4" copper. My compressor is mounted in the cellar of my house, I have not got it plummed yet. I have about a 30 foot run before it gets to the point where it will enter my garage. This point will be at floor level in the garage, but celing height in the cellar. There will also be a 90 degree corner at a wall about 10' to 15' from the compressor. I can get a good up hill run out of this, but I have few questions.. Being a 25x25 shop, I am mostly running only one hose at a time. I plan on one QD near the wall where it enters the shop. What is the best way to put a drain in if it enters from the floor? Also, I am thinking of running up into the attic and a installing a drop from the celing with a coiled hose over my work bench. I suppose installing a "T" at the celing height on the wall the line enters at and dropping the line back down would be the best, but is there another way to add a drop drain? How effective is a second tank added to the system at the celing right where the drop would come down for the main hose (not the workbench). And what size tank? The compressor is old, very old.. In fact, we are guessing pre 1940's due to the size of the motor and the HP rating. (It seems as they changed they way they rate the HP on motors in the late 30's and a 2hp motor is now like a 5hp+) It is maybe a 120-180 gallon tank (old Devillibs compressor)
Soo.. got any thoughts?
Firefyter_Emt is offline   Reply With Quote
Old 06-18-2004, 12:20 PM   #13
D60
D60's Avatar
Member # 6398
Good questions................I'm only using 1/2" copper but I've got a short run to get into the shop, less than 15' of pipe. I don't know what sort of drop you'll see over a given length of line, but there's gotta be a chart out there somewhere, just like electrical.
I hadn't thought about the drain... I'm running a filter off the compressor, then I was going to run copper out of the shed (shed and shop are 3' apart), down into the ground (shallow) and then back up into the shop.
I'm doing this so I can still walk between the shed and shop
Do you guys think I'll have an issue w water collecting in the copper in the ground (lowest point)?
Old 06-18-2004, 02:37 PM   #14
pcorssmit
Member # 4406
I bought a self-rewinding (spring) Amflo hose reel with 50' of hose at bLowes for $80 a few months ago, and it works great. The hose isn't the absolute best, but I would say its good quality; better than the cheapie 50' I'd been using for several years until I got it. Keeps things so much neater. Someday I'll plumb the shop, but for now I just mounted the reel to the ceiling, and used the old line to supply it.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote
Old 06-18-2004, 03:12 PM   #15
tsm1mt
Member # 2071
Eventually.
It's nice n' cool underground, so that'll be a great moisture trap.. except it'll trap it in the middle of your air line, and condensate will be sitting directly against the pipe at the lowest point.
Will it be a problem in your lifetime? :shrug:
Water filter right off the compressor is the worst place for it, since the air is the hottest and holds the most moisture.
Ideal is to come out of the compressor, then zig zag up a wall in big, wide sweeps (think: big tranny cooler) but such that the water runs all the way back down the pipe to a drain. THEN come off the top (driest) go to where you want to use the air, and install a moisture trap there.
I'm told a "receiver" (spare tank) near a "big consumer" device is a good idea. It'll help make up for any lost efficiency in your piping.
As I noted above, I put a 30gal tank in my attic, upright. Air comes in near the bottom (after the rise out of the compressor, the air tank is the lowest point in the system, and about 40' from the compressor, as the pipe-goes).
For my driest air (for painting) I draw air from the top of this tank, but it still goes to a water vapor filter before going to a gun.
-Tom
KE7VUX
Old 06-18-2004, 04:02 PM   #16
snaps10
Member # 30338
Send a message via AIM to snaps10
ive got 2 of the costco reels in mine. i plumbed them with the hose i was replacing, going on 3 years no problems, very smooth, now i just need to move the compressor to a box outside, cuz that mug is loud when it runs.
snaps10 is offline   Reply With Quote
Old 06-18-2004, 04:09 PM   #17
Scott@Rockstomper
The winch rope guy
Scott@Rockstomper's Avatar
Member # 1889
Somebody somewhere along the line plumbed my place with PVC... I've had problems with it. Haven't gotten to redoing it yet, but when I do, I'll use copper. Meantime, since the shop is so small, I can reach anywhere I need to with just a 50'-er off the compressor, so I get by on that.
Winch rope, DIY beadlock kits, hydraulic steering, and much more: Shop Rockstomper online
Scott@Rockstomper is offline   Reply With Quote
Old 06-19-2004, 06:25 AM   #18
Firefyter_Emt
Member # 2192
I am glad I see a lot of people who have had problems with the PVC.. I was going to go that route, but had only heard one or two people against it.. Well, now it is a no brainer..
Old 06-19-2004, 08:30 AM   #19
PTSchram
Member # 12499
Location: In the office writing letters to Land Rover's attorney, trying to stay in business,
I'm not convinced not to use PVC.
My shop is plumbed with PVC for air, my laboratory was plumbed with PVC. Every lab I worked in had air lines run in PVC. I've used PVC for process plumbing for many years, running any of a number of aqueous compounds running through it, some pretty aggressive.
With 4500 sq. ft of shop, I'd hate to think how long it would take or how much it would cost to do it with something other than PVC.
So far, the only mistake I've made (other than those of you who tell me I shouldn't have used PVC) was using 3/4" PVC when I should have used perhaps 2" so I could have a bigger "tank" on the wall.
With regard to Harbor Freight reels, they leak! When it leaks badly enough that it becomes expensive, I'll worry about them.
Wrenchin' to riches!
PTSchram is offline   Reply With Quote
Old 06-19-2004, 10:02 AM   #20
larryboy
Member # 9222
osha noticed problems in 1988.
"Only one type of plastic pipe has been approved for use with compressed air. That pipe, Acrylonitrile-Butadiene-Styrene (ABS), is marked on the pipe as approved for compressed air supply.
By law, employers must protect their workers by avoiding the use of unapproved PVC pipe in such systems. Existing compressed air systems which use PVC piping must be completely enclosed, buried or adequately guarded according to specifications approved by a professional consulting engineer. "
http://www.osha.gov/dts/hib/hib_data/hib19880520.html
larryboy is offline   Reply With Quote
Old 06-20-2004, 04:36 PM   #21
PTSchram
Member # 12499
Larryboy:
Thank you. That damned General Duty Clause gets you every time.
I have been thinking about this one for some time and was not able to come up with a reason not to continue to use PVC.
Now that we have a regulatory reason to avoid PVC in compressed air piping, somebody explain the reason for the failures with gases and not liquids (at ambient temperatures) and at pressures within the allowable limits for the pipe.
Old 06-20-2004, 05:09 PM   #22
Jeff Knoll
Jeff Knoll's Avatar
Member # 13974
Lots of good ideas... I would like to add a few more.
I have done a few air systems over the years both for commercial use and hobby. The first one I did was for Safari Gard about 12 years ago. I learned a few things from this Copper installation that is still in use.( heavy use)
The last one I did was for a paint and body shop and he has had good luck with the system over the last year.
please save yourself the possibility of injury. Dont use PVC. PVC sch 40 ( The white stuff) is not rated for this use. It has no ability to withstand UV rays and sunlight makes it brittle. It is my experience that it does not do well with oil and metal dust build up. Dropping a tool on it or sparks could be bad.
I use Type "L" copper It is spendy but will last a long time. It is twice the thickness of Type "M". Most of the systems I have done I use 3/4 and 1/2" for the most part. I have also used 2" for traps but found it to be over kill.
Remember that Copper does not like steel and should be isolated from your metal building.
The most important thing I have learned is that once there is water in your system You will play hell getting it out. Greg at Safari Gard has been dealing with wet air for years. I asked him if he wanted his Money back for the system about 4 years ago and tossed him a cold beer.( He got what he payed for) This being said I suggest You grade all your lines and install traps at every branch. I run the main at a 1/4 " per foot and reverse trap the branches down to the outlet. At each outlet I run a 3/4 or 1" piece past the outlet with a ball valve for a drain. The paint shop drains the system at the main drain every day and the branches every few weeks. The main drain has water every day. little comes out of the branches.
For conection I use a 1/2" FIP and adapt with a brass 1/2" X 1/4" bushing.
The one thing I have not come up with is a trick way of conecting the compressor to the system. I use a short piece of air line so that the compressor can vibrate. I would love to hear of a trick for this.
As far as pressure loss due to friction. I could not say, but I guess that someone on this board has a formula. I have noticed that the compressor runs longer but less often. Which may be good or bad depending on your out look.
I am starting to convert a barn to a shop so when I get around to running air I can add a write up to this thread for reference.
Great forum thanks for adding it.
Jeff Knoll is offline   Reply With Quote
Old 06-20-2004, 05:38 PM   #23
Hickeyjones
Hickeyjones's Avatar
Member # 14570
PLease do!
Hickeyjones is offline   Reply With Quote
Old 06-20-2004, 05:43 PM   #24
PTSchram
Member # 12499
Jeff:
Why the higher wall thickness? Are you concerned about oxidation on the inside?
OK, I hate the internet. After spending far too much time obsessing on why PVC pipe shouldn't be used, now I'm forced to research the specifications of various pipe sizes, etc. If Al Gore really had invented the interweb, would ASTM specifications be available free?
Alright, I'll be replumbing my shop air with copper. Even using the thinner wall type M, you have a six-fold safety margin at 100 PSI.
Old 06-20-2004, 07:45 PM   #25
D110pickup
Member # 11169
[quote=Jeff Knoll]Lots of good ideas... I would like to add a few more.
Jeff,
I've used hydraulic hose to connect from the tank to the rest of the system. It can handle the pressure and the temperature of the compressed air.
The one on my system has been in use for about 8 years.
Mike
D110pickup is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
