Pirate4x4.Com Bulletin Board
Old 06-17-2004, 05:12 PM   #1
preach
Member # 8713
Homemade Welder Carts
I plan on making one this weekend and want some ideas...
Additionally I need to know the diameter of a standard gas bottle.
I am planning on a compartment for consumables in the mix somewhere.
Please discuss.
Great Northern Ridge Runner
preach is offline   Reply With Quote
Old 06-17-2004, 06:09 PM   #2
Murph
Dog is my co-pilot
Member # 15246
Two good places to visit often -
http://www.weldingweb.com/
http://www.weldingweb.com/search.php...der=descending
http://www.hobartwelders.com/mboard/
http://www.hobartwelders.com/mboard/...der=descending
I picked up a bunch of 1.5 square tubing to finally make a cart, but it went towards a flat skid instead...
Edit - my 80cf bottle is about 7.5" in diameter.
Andy
MM175
Murph is offline   Reply With Quote
Old 06-17-2004, 09:09 PM   #3
preach
Member # 8713
Signed up on the Hobart forum. Thanks.
Laugh if you want but my cart will be made from collected bed frame angle iron.
I'm in real estate with a heavy interest in rental property and people leave angle bed frames all the time. I must have 6-7 of them right now, I use the angle all the time for different crap.
Sometimes good for mediocre casters too.
My welding table will be framed from the same stuff capped by an old 3'x3' stamped steel grate that used to be an inlet for an archaic furnace.
Old 06-17-2004, 09:32 PM   #4
chumly2071
chumly2071's Avatar
Member # 8293
Send a message via AIM to chumly2071 Send a message via Yahoo to chumly2071
another real good welding/fab site that is getting off the ground is www.shopfloortalk.com . A lot of the people that made the other two boards what they are are now hanging out there. new site, but growing rapidly.
I'm an Engineer. Why leave it alone, when I can REALLY screw it up?
There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance.
chumly2071 is offline   Reply With Quote
Old 06-17-2004, 11:01 PM   #5
ironpig70
NO HOE'S OR BRO'S
ironpig70's Avatar
Member # 6957
my dad is a landlord and he does the same thing
ironpig70 is offline   Reply With Quote
Old 06-18-2004, 07:43 AM   #6
Murph
Dog is my co-pilot
Member # 15246
A lot of familiar names over there, I just signed up. Thanks.
Andy
Old 06-18-2004, 07:54 AM   #7
Pdaddy
Pdaddy's Avatar
Member # 8133
I scored a SBC engine cradle real cheap that was missing a few parts (cross braces I didnt need) and welded angle to the front and rear of the sides to make it fit my welder, need to finish it but it works great and I have 15 bucks in it with the casters
LCQ / KOH 09 Co-Driver #62 HardlineCrawlers.com
08 2 seat cadi junk.
Pdaddy is offline   Reply With Quote
Old 06-18-2004, 08:31 AM   #8
D60
D60's Avatar
Member # 6398
Well, in keeping with the bed frame angle, here's my plasma cart:
Not exactly what you're looking for, but I'll offer this: design something into your cart to place/wrap your ground strap and gun lead. My Hobart 210 is self-contained so it didn't need a cart, but my buddy's Miller 210 has a nifty rubber "thing" on top to "plug in" the tip of your gun..............I wish my Hobart had that. I can wrap everything around the body of the welder kinda sorta, but it's a PITA. There's nothing more annoying than trying to navigate your welder/welder cart thru your cluttered shop floor during a project while holding your cables in one hand so they don't get sucked under the wheels and stop forward progress.
So, basically, two things: 1)someplace to store the cables out of the way and 2)a hole or holder (holster?) for your gun *while* you're working.............ya know how you always go to set your gun down somewhere within reach and it manages to snake it's way onto the floor 'cause the lead is so stiff?
HOA communities: Little boxes, on the hillside. Little boxes made of ticky-tacky
D60 is offline   Reply With Quote
Old 06-18-2004, 08:46 AM   #9
The Joker
Member # 943
I just used a piece of 3/4" plywood put some casters on the bottom and used some "L" brackets to hold the tank up. Nothing to fancy but I can move it around easy enough.
The Joker is offline   Reply With Quote
Old 06-18-2004, 10:04 AM   #10
LazyDog
(a.k.a. Rockrig)
LazyDog's Avatar
Member # 25216
IMO, make a cart that will carry two bottles.
Just to give you some ideas, here are some pics of the cart I made for my TIG machine.
LazyDog is offline   Reply With Quote
Old 06-18-2004, 10:06 AM   #11
LazyDog
(a.k.a. Rockrig)
LazyDog's Avatar
Member # 25216
and some pics of my plasma wagon...
Old 06-18-2004, 06:59 PM   #12
yager
yager's Avatar
Member # 10695
Send a message via AIM to yager
heres mine,
first one i made was from a generator tube frame with some stuff added.
This one is much better suited for my garage... and it has some drawers... I've since added some cheep-o brackets on the back side and front to hold the cables/cords etc..
edit: i sould point out, i cut a hole in front to operate the welder and a hole in back for the cord/hose to enter... i typically leave it open when im welding so air flow isnt a prob...
-mike
Mike Yager
Current Build - Blue Jeep - http://www.pirate4x4.com/forum/showt...php?p=10456307
yager is offline   Reply With Quote
Old 06-18-2004, 08:16 PM   #13
frankenfab
Member # 18989
I'm about to build a new design, but here's my current cart:
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator.
frankenfab is offline   Reply With Quote
Old 06-18-2004, 08:51 PM   #14
preach
Member # 8713
Why did you mount it so high?
Old 06-18-2004, 11:23 PM   #15
BadDog
Member # 8211
Another forum with good stuff you can check for the cart, shop stuff, and general fab info... OFN
Mine along with my table.
Russ
85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils.
BadDog is offline   Reply With Quote
Old 06-19-2004, 07:00 AM   #16
frankenfab
Member # 18989
Ever weld on the roof of your junk? With the machine low, the leads are not long enough to reach. I also don't have to bend down to adjust a setting or change wire.
Old 06-19-2004, 08:43 AM   #17
Eric
Member # 39
Hey BadDog.....Can you give us a little more info on the welding table?
Eric
Parts for Sale --> D44 shafts, 6 lug rims, air tank
Eric is offline   Reply With Quote
Old 06-19-2004, 09:06 AM   #18
K2Orion
Member # 28084
I can't find the pic of it but somebody over on CK5.com used a $20 2 wheeled hand cart from HF as a base. Like the kind movers and stuff use. They built 2 shelves for the welder and stuff, put casters on the front and strapped the tank to the back of the cart. It worked good cause you could roll it around on the shop floor or lean it back on the rubber tires and go offroad with it to roll over crap in the shop or out into your crappy rock driveway.
K2Orion is offline   Reply With Quote
Old 06-19-2004, 01:50 PM   #19
BadDog
Member # 8211
Not much to say, and OT, but here goes...
  • 4 x 4 x 1/2 top plate.
  • 2 x 2 x 0.120 square tube legs.
  • 3" x 1.5 x 0.188 channel "belt" around the top of the legs and forms the base for the top.
  • 1 x 1 x 1/16 square tube for the shelf frame.
  • 1/2" expanded metal shelves for shorts, clamps, etc. No worries about accumulating grinding dust and such since it just falls through. I hate cleaning…
  • 2 "Receivers" on the back for mounting things like my bead roller, strap bender, and anything else I care to build a 2" adapter for.
  • Piece of scrap roll bar tube about 6" long on the front right corner used as a "holster" to hold the MIG gun so it's not in the way on the table, dropped, or accidentally getting triggered by laying it down.
The top just sets there. I was going to add tabs to the top for a mechanical attachment to the frame, but it sets fine without it and I have had no trouble with it moving. Plan was to weld on some short (1/4") pieces of angle that would lock on the legs inside the "belt". That way I can still separate the top plate for moving (which we plan to do within the next 1-2 years).
Russ
Old 06-19-2004, 09:12 PM   #20
preach
Member # 8713
Here is what I ended up doing using your ideas...thanks.
Points of interest include:
AMC20 side gear gun holster
Random 2.5" ID exhaust connector beer holders
Stock CJ tierod push handle
Holds 400+# easy.
4" castors.
Thanks for the help.
Old 06-20-2004, 08:51 AM   #21
kpj
Ridge Runner
Member # 6920
All you need now is a place to put the empties and you are good to go.
kpj is online now   Reply With Quote
Old 06-26-2004, 10:05 AM   #22
jerseyzuks
Member # 24273
I just built mine yesterday.
I put 6" wheels on the back and little legs on the front. Tilt it back to roll it (like a hand truck). Top has a flat unfinished metal surface that I can use as a portable welding table.
8' of 1" angle iron (had in the shop)
22' of 1" square tube $22 (.99 a foot, used to be about .30 a foot)
2 pieces 18"x24" 12 gauge sheet metal (had in the shop)
22" piece of roundbar, for axle (had in the shop)
2 6" wheels $12
A few random pieces of scrap, to hold the axle
Deja Moo: The feeling you've heard this bullshit before
jerseyzuks is offline   Reply With Quote
Old 06-26-2004, 08:38 PM   #23
clutter1
Member # 22059
here's mine........ one day plasma cutter on top
83 toyota 4.3 700r4 toy xcase rockwells & 44 tsls
clutter1 is offline   Reply With Quote
Old 06-28-2004, 05:51 PM   #24
wilber
Member # 6237
Send a message via AIM to wilber
does it matter if a mig welder sits horizontal? or can it be tilted on an angle or almost vertical?
wilber is offline   Reply With Quote
Old 08-06-2004, 11:02 AM   #25
Brandon
Pirate4x4 Addict!
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
I just dumped my old rickety cart, "acquired" a small shopping cart from the 99cent store as a basis for the new one. Any reason the bottle can't lay back at an angle? Anyone have any "cart conversions" to share?
This Space for rent!
Brandon is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
