Pirate4x4.Com Bulletin Board
Old 06-18-2004, 09:42 AM   #1
doctor_cad
Member # 29609
Send a message via MSN to doctor_cad
Tubing Notchers...
What are you guys using to notch your tubing?
Drill Motor/Hole Saw Jig?
Metal Lathe?
doctor_cad is offline   Reply With Quote
Old 06-18-2004, 04:30 PM   #2
preach
Member # 8713
Cheapo HF notcher. works fine for my needs. runs on the drill press.
Great Northern Ridge Runner
preach is offline   Reply With Quote
Old 06-18-2004, 04:35 PM   #3
Spawn_X
Trailer Park Boy
Spawn_X's Avatar
Member # 16583
Send a message via AIM to Spawn_X
Originally Posted by trampas View Post
you look like a moving violation when you're standing still.
Spawn_X is offline   Reply With Quote
Old 06-19-2004, 02:24 AM   #4
BigWoodyWag
non-crawler
BigWoodyWag's Avatar
Member # 26468
Send a message via AIM to BigWoodyWag
I got this one:
http://www.pro-tools.com/hsn500.htm
but should have spent the extra chedder and got this one
http://www.pro-tools.com/hsn501i.htm
I find myself limited on angles with mine, and think that the extra adjustability would ease some fab jobs and require less grinder work.
Triple Nickel Racing
BigWoodyWag is offline   Reply With Quote
Old 06-19-2004, 03:29 AM   #5
socalchef
Member # 19652
Send a message via AIM to socalchef
i had the harbor freight notcher, the bolts stripped out. i jammed bigger bolts in but i ended up getting an hsn 500 pro tools version for $90 on ebay. i like it a lot better.
Shaffers Diablo Sport chassis on a 4.0L YJ frame
Read the buildup at http://www.abendig.com
socalchef is offline   Reply With Quote
Old 06-19-2004, 06:51 AM   #6
broncofreak2000
broncofreak2000's Avatar
Member # 26394
Ive got the JD2 model from VanSant Enterprises nice high quality cnc machined notcher. I bought a HF model and it was cheap made and didn't notch the tubing on center, you get what you pay for.
78 Bronco, 4" lift, 2" body lift,42" TSLs, KORE Beadlocks, 4.88 gears, 14 bolt with detroit, HP60 front welded, Psycho Fab doors, High Angle rear driveshaft, Warn HS9500
broncofreak2000 is online now   Reply With Quote
Old 06-19-2004, 02:01 PM   #7
THURENfab.
blah...
Member # 30339
Made my own.... does any angle .....
THURENfab. is offline   Reply With Quote
Old 06-19-2004, 10:54 PM   #8
doctor_cad
Member # 29609
now THAT is kick ass. How does the tube clamp work??
Old 06-19-2004, 11:11 PM   #9
BadDog
Member # 8211
Chop saw
Grinder
Plasma
HF notcher
In that order. HF is used only for near 90s and "highly visible" joints. 2 little 45s on the chop saw and a touch up with the grinder is faster for most, but not as good "fit-up".
Russ
85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils.
BadDog is offline   Reply With Quote
Old 06-19-2004, 11:13 PM   #10
RustyNailJustin
TLCA#5305
RustyNailJustin's Avatar
Member # 8568
Grinder... might be slow but you can make perfect fit once you get good at it. I use a hole saw to get the basic shape then grind to the best fit fish mouth.
2009 KOH Team 435 Finished 35th.
THANKS
Moab MS
High Angle
Crossroads Fitness
Maxxis Tires
RustyNailJustin is offline   Reply With Quote
Old 06-20-2004, 04:36 PM   #11
jeeplord
jeeplord's Avatar
Member # 28273
Miller Spectrum Thunder 230V
Does any angle you can imagine
[QUOTE=kodiak1232003]"RUN, WHITE PEOPLE!! RUN!..SAVE YOUR FAWKING SELVES!!!" or some sh#t, in broken engrish...."[/QUOTE]
jeeplord is offline   Reply With Quote
Old 06-21-2004, 09:57 PM   #12
doctor_cad
Member # 29609
Thanks for the replies.
We use patterns developed in Autocad and printed out to be wrapped around the pipe at the shipyard I work at. The line is transferred from the pattern, then cut with a torch. Thats on heavy pipe though...
I guess theres no reason why you cant do the same and use a torch on tubing. Pbly spend more time cleaning it up than just cutting the whole fishmouth with a hard disk on the mini grinder though. Jeez, I wish I could justify a plasma!
Old 06-22-2004, 10:15 PM   #13
JeepinDoug
Banned
JeepinDoug's Avatar
Member # 13028
Like this?
JeepinDoug is offline   Reply With Quote
Old 06-22-2004, 11:01 PM   #14
doctor_cad
Member # 29609
Same idea, yep. I just draw up the members as solids so they run past the intersection point, and use a boolean subtraction.
1st Step:
Old 06-22-2004, 11:03 PM   #15
doctor_cad
Member # 29609
2nd Step:
Old 06-22-2004, 11:05 PM   #16
doctor_cad
Member # 29609
3rd Step: Subdivide perimeter into equal parts, and extend lines to cutting profile.
Old 06-22-2004, 11:07 PM   #17
doctor_cad
Member # 29609
Final Step: Take projected lines off tube and lay them out on a flat surface. This forms the pattern... Notice this tube was intersected at a 15* angle. Concept works for any angle.
Old 06-23-2004, 10:52 AM   #18
THURENfab.
blah...
Member # 30339
I think you can see it from this pic.... I kinda just threw this together to see how it worked before the final design .... It works great and holds the tube really tight.... I just did some notches that were in the middle of a bend and they were soooooo easy compared to my ol' HF POS......
Old 06-27-2004, 10:57 PM   #19
Cannon Motorsports
Member # 32492
We use the JD2 notcher, and I love it. I woulda bought the pro tools, but I can get the JD2 for 100$. Those are the best notchers, the joint jigger, and the hf one suck. Don't settle for anything less.
Cannon Motorsports is offline   Reply With Quote
Old 06-28-2004, 09:52 AM   #20
DRM
The Quiet One
DRM's Avatar
Member # 8
Send a message via AIM to DRM Send a message via Yahoo to DRM
I have the HF notcher - and personally, it sucks. Gonna have to look into modifying it to fix as many of the problems as I possibly can, because as it stands right now - I hate using it.
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
>***FOR SALE: 87 4Runner / 60's / 3link rear / 39" PitBulls - $7500***
DRM is offline   Reply With Quote
Old 06-28-2004, 10:17 AM   #21
toymoto
Token Wheeeeeeler
toymoto's Avatar
Member # 24296
I use the HF notcher and Greenlee Holesaws. It's a love/hate relationship. It's easier to make saddles than with the chopsaw and grinder but I have sprained and almost broken my wrist several times with it. The guide for the shaft has wallowed out causing the holesaw to catch and fling my skinny ass around.
On my next project it will be mounted to the drill press.
toymoto is offline   Reply With Quote
Old 06-28-2004, 04:05 PM   #22
doctor_cad
Member # 29609
I thought there would be priblems catching with the hole saws. They are grabby on flat plate, cant imagine on tubing... I guess the hot setup is to get a plasma and use some sort of comp. generated template. OR, fab up a sweet ass setup like THURENfab.
Old 06-28-2004, 04:09 PM   #23
Cannon Motorsports
Member # 32492
The trick to making a nice cut and making your holesaw last forever, is the slow the drill down, and move a a nice constant pace. Use cutting oil and keep the metal cool. This way, the holesaw never catches on the metal.
Old 06-28-2004, 06:10 PM   #24
JeepinDoug
Banned
JeepinDoug's Avatar
Member # 13028
Here's the ultimate notcher for perfect coping but way too pricey for me. It shouldn't be too bad to build one though.
Mittler's site
Old 06-30-2004, 08:06 PM   #25
doctor_cad
Member # 29609
Could do the same thing as that Mittler thing with a lathe and a creative tool rest/tube clamp
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
