Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 06-19-2004, 10:16 AM   #1
robinhood150
Member # 21134
Factory 4.88 front diff
I'm regearing from the factory 4.88s to 5.29 and adding ARBs. The front diff is normal, right? I can regear and add an ARB no problems? I know the rear 3rd is wierd, but I've already taken care of that with a new V6 3rd with 5.29s.
'93 4Runner V6, Auto, SAS, e-locker, arb | www.ultimateyota.com
robinhood150 is offline   Reply With Quote
Old 06-19-2004, 10:24 AM   #2
FuzzyZ_83toy
Member # 29877
Send a message via MSN to FuzzyZ_83toy Send a message via Yahoo to FuzzyZ_83toy
what the, are you talking about? anybody get what he's saying? is he saying that he wants to run 4.88 up front and 5.29 in the rear like it sounds to me? lol that would be fun once he puts it in 4 wheel drive.
FuzzyZ_83toy is offline   Reply With Quote
Old 06-19-2004, 10:28 AM   #3
4CrawlR
4CrawlR's Avatar
Member # 4716
He did mention regearing the front diff, so I would assume that means re-gearing from the factory 4.88s to something that might match the rear diff. AFAIK, there is no difference in any of the 7.5" front 3rd member housings, be it 4- or 6-cyl or 4.88 gears or any other ratio. But then again, I'm no IFS expert and I did not stay in a Holiday Inn last night either
4CrawlR is offline   Reply With Quote
Old 06-19-2004, 10:47 AM   #4
robinhood150
Member # 21134
Yup, regearing to 5.29s and Arb'ing. Thanks Roger. I just wanted to confirm that before I buy the front ARB and gears.
Old 06-19-2004, 11:47 AM   #5
cebby
UltimateYota Junkie
cebby's Avatar
Member # 20764
Send a message via AIM to cebby
I concur with Roger. I've heard exactly the same (that the IFS front diffs are all the same). I chose to get a non-ADD diff (only the tubes are different) since I could get it for free. I think it had 4.10's.
Stepping up to 33's too, Steve?
JeepsLimited.com - Jeep Writeups, FSM's and Parts Lists
UZswap.com - A site dedicated to swapping the Toyota/Lexus UZ (V8) engines.
TOOLandFAB.com - A site dedicated to tools, fabrication & workshops. Also see my My JD2 Bender Hydro Conversion
cebby is offline   Reply With Quote
Old 06-19-2004, 11:53 AM   #6
obex26
Banned
Member # 10544
Send a message via AIM to obex26 Send a message via Yahoo to obex26
For the cost of the front ARB you might as well do a conversion to a solid front axle. I say put an ARB in the rear and save your money for the front. Unless you swear you will NEVER ever consider doing a solid axle conversion. Its a disease. I am already making plans to convert a 94 extended cab to solid axle. Oh and Fuzz for your info I ran 4.10 in the front and 4.88 in the rear for about 4 months off road. Didn't break anything. (read the off road part a second time if you missed it the first time)
obex26 is offline   Reply With Quote
Old 06-19-2004, 12:53 PM   #7
OOP'S
Pirate4x4 Addict!
OOP'S's Avatar
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
Speaking from experence, If you are even thinking about doing an SAS, do not waste the money. I know down the road you can sell the IFS stuff but used parts in good shape are worth about one half the cost of new if you want to be fair. If no SAS go for it they are the same, if it has ADD now, get rid of it, that is all a bolt on mod with plenty of stock parts drifting around and the IFS crap from 86-95 will work!!!!!
I think that maybe a reading comprehension class is in order, I figured out what he wanted from the git-go!!!!!!!
David & Theresa, Roseville, CA,
Excellent Parts Source
http://www.davezoffroadperformance.com/
http://www.marlincrawler.com/
http://www.12voltguy.com/web/
OOP'S is offline   Reply With Quote
Old 06-19-2004, 02:38 PM   #8
robinhood150
Member # 21134
Yup, SAS in the future but not anytime soon. I need to buy a house first, I don't think my apt neighbors would appreciate me welding and grinding next to their mercedes. Seriously, though I've thought long and hard about this and I have the buildup process pretty much mapped out in my head.
Cebby, 33x10.5 BFGs MTs (so I can keep the stock wheels $$ and no need for the RB 1" BL $$) will be on the truck as soon as my current tires wear out, which is pretty soon.
Old 06-19-2004, 06:13 PM   #9
cebby
UltimateYota Junkie
cebby's Avatar
Member # 20764
Are you doing anything to fit the 33's? I was under the impression that 33" pizza cutters, even on stock wheels, will do some rubbing.
The RB 1" BL was only $95 - in the scheme of things (for me anyway), a good investment.
With stock BS wheels, you'd have some contact if you went the BJ spacer route too...
I know you are up on all this stuff already though as it's been beaten to death. You might want to ask LAMM how his rides on the 33x 10.5's. He's the only one I can think of off the top of my head who has those on a 2G with IFS.
Old 06-19-2004, 08:37 PM   #10
robinhood150
Member # 21134
There's s thread on 4x4wire where a couple people with 2nd gens are using 33x10.5s without much difficulty. I'm sure I'll have to do some cutting and pounding and if I have to, then I'll go the RB route.
We'll see. I've got a couple months to figure it out anyway, my current tires still have some life.
I'll ask Lamm about his, thanks.
Forum Jump
