Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Nissan
Old 06-30-2004, 11:28 PM   #1
AirTrooper
Member # 20564
T100l
guys, I have a 86 turbo diesel Trooper that I am putting a second Nissan T100L divorced transfer case in.
I could sure use a source for old Nissan drive shaft FLANGES I need all three.
Here is a couple of links...
T100L xfer case
AirTrooper
86 Topless Turbo Diesel Trooper SAS SOA Custom Alum Dash, Cage, Dana 44 front, Detroit ezlocker, Zoo 12 bolt rear Lincoln Locker, cherokee springs, Alum radiator, 36" Super swampers, Stack & Snorkle, VDO gauges
2001 Dodge Ram 2500 4x4 Cummins Superchips, K&N, TST j-hook, transgo VDO gauges
AirTrooper is offline   Reply With Quote
Old 06-30-2004, 11:38 PM   #2
TRed
Member # 12100
Interesting, but I can not help you.
Originally Posted by randii
if you're a Pickle, rolling down the trail in a Smurf, dispensing bowls of dicks. FWIW, I don't want to see pictures of that, either!
Randii
TRed is offline   Reply With Quote
Old 07-01-2004, 07:08 AM   #3
JoeyS
JoeyS's Avatar
Member # 24600
This place rebuilds them, and may be able to get you parts:
http://www.rebuilttransmissions-r-us...es-prices0.htm
I guess you weren't able to straighten that flange?
JoeyS is offline   Reply With Quote
Old 07-01-2004, 05:52 PM   #4
fivetenben
Member # 1710
T100L xfer case
AirTrooper
Maybe post some measurements, they could interchange with the hardbody stuff. If so, theres plenty of people with SAS leftovers to get parts from.
Killer trooper BTW...
Ben
fivetenben is offline   Reply With Quote
Old 07-01-2004, 07:10 PM   #5
AirTrooper
Member # 20564
Joey,
Everything is fine. have't tried to straighten that bent one out yet.
Been driving it withstock zoo xfer case. but have now too many drive shaft issues in front. Need to get this done, while it is busted now.
I sure wish you had the stubs of the original driveshafts.
Anyone know if the flanges are NIssan specific? or share dimensions with spicer? (fat chance)
many thanks.
Old 07-02-2004, 07:53 AM   #6
JoeyS
JoeyS's Avatar
Member # 24600
Joey,
many thanks.
I had seen a scan of a parts book for the 85 4x4 pickup, and I remember that it was a spicer part, but I just can't find it again. I have been looking.
You probably already have, but have you called an O'Reilly or AutoZone?
Junkyard may be the best bet, though. There is a Mazda-Nissan Heaven in Fort Worth, and a Nissan Yard in South Fort Worth that may have a wrecked one.
Old 07-02-2004, 03:30 PM   #7
AirTrooper
Member # 20564
Spicer!
i SURE hope your memory is good! I'm just now getting around to investigating this. Spicer would be ideal. Inland Truck Parts....here i come...
Old 07-03-2004, 09:47 PM   #8
AirTrooper
Member # 20564
spicer record
For history
The T100L does or can use spicer flanges. The following insured spicer 1310 connectivity at all 3 corners.
P/N 2-2-1949 2 each
p/n 3102-20 1 each
Old 07-06-2004, 07:00 AM   #9
JoeyS
JoeyS's Avatar
Member # 24600
I knew I had seen that somewhere...
Forum Jump
