Pirate4x4.Com Bulletin Board
Old 07-30-2004, 03:49 PM   #1
Scott@Rockstomper
The winch rope guy
Scott@Rockstomper's Avatar
Member # 1889
Hydrosteer parts in stock, ready to ship
Got a pile of stuff--2.25x8x1.25 cylinders, 2.75x8x1.5 cylinders, 2.75x10x1.5 cylinders, plenty of reservoirs, two sizes of control valves, two different styles of pumps, tons of pieces 'n' parts to build a wicked hydraulic steering system, in-stock and ready to rock-n-roll.
More info:
http://www.rockstomper.com/catalog/s.../fullhydro.htm
Winch rope, DIY beadlock kits, hydraulic steering, and much more: Shop Rockstomper online
Scott@Rockstomper is offline   Reply With Quote
Old 07-30-2004, 05:38 PM   #2
keithflux
xtremist
keithflux's Avatar
Member # 19716
Whats the price for everything there required to make a Kit?
Chopworx Motor Co.
Business# 918.607.3328
Chopworx.com
keithflux is offline   Reply With Quote
Old 08-02-2004, 10:11 AM   #3
Scott@Rockstomper
The winch rope guy
Member # 1889
Kits depend on which components you need or want.
2.75x8x1.5 cylinder, $420
2.75x10x1.5 cylinder (Mog/Rockwell!) $430
2.25x8x1.25 cylinder, $320
Performance pump, $140-on-up
Steering control valve, $300-on-up
Reservoir, $45
High-pressure filter, $15
Column, $60
Coupler, $20-on-up
Mounting bracketry, tabs, etc., different stuff, varies by your needs.
There's no canned-answer one-size-fits-all setup--we've got different parts for different applications, so no one-price-fits-all either.
Old 08-02-2004, 05:01 PM   #4
blackx
Member # 21319
can you mount the control valve straight to the firewall and then run the hydro hoses to the ram?????
[COLOR="DarkOrange"][SIZE="5"][B]It is no longer a hobby it is now an addiction[/B][/SIZE][/COLOR]
1993 Jeep YJ / 351W/ 16" Fox air shocks / Ford 9" rear, disk brake conv, Yukon axles, 5.14 gears & full spool / Front HP D44, detroit locker, warn alloy shafts, 5.13 gears & Longfield U-Joints / C6 trans and 208 tcase / Custom 4-link front and rear
blackx is offline   Reply With Quote
Old 08-02-2004, 06:26 PM   #5
toyotanut
Member # 17269
Send a message via ICQ to toyotanut
price for the 2.25x8x1.25 single ended ram, steering valve(2-3 turns lock to lock), sterring column and coupler, shipped to business addy 98272
toyotanut is offline   Reply With Quote
Old 08-02-2004, 07:25 PM   #6
Scott@Rockstomper
The winch rope guy
Member # 1889
Blackx, you can mount the valve anywhere you want to, that you can get the column to it and the hoses into it. Common is either right behind the wheel (on most buggies) or in place of the steering box on the frame (in most production-based stuff).
Toyotanut, we don't carry a single ended ram at all--I'll assume you meant double ended. Can do 2 turns, or 3.5 turns, on what's in-stock. If you want less than three, I'd recommend non-return. Assuming non-return, and that you meant to type double-ended, $320+300+60+20+19=$719. If my assumptions of what you want are wrong, correct me, and I'll revise my estimate.
Old 08-03-2004, 11:40 AM   #7
blackx
Member # 21319
PM me a price for a basic orbital box please. Looking to go Full hydro
Old 08-03-2004, 12:01 PM   #8
welndmn
Well Done Man!
welndmn's Avatar
Member # 398
Send a message via ICQ to welndmn Send a message via AIM to welndmn Send a message via Yahoo to welndmn
Getting my order ready for ya!
Mark
71 Bronco. 42's and bolt on goats.
welndmn is offline   Reply With Quote
Old 08-03-2004, 12:33 PM   #9
Scott@Rockstomper
The winch rope guy
Member # 1889
Non-return orbitals are $300, return, $350, in either displacement size that we stock.
Return must be used with a balanced steering system; non-return can be used with either balanced or unbalanced systems.
Old 08-06-2004, 12:34 PM   #10
Scott@Rockstomper
The winch rope guy
Member # 1889
Just got word that we've got another shipment of orbitals arriving early next week, so we'll be able to pull from stock for return or non-return, for anything from a D44 on 35's through a Rockwell on 53's, using the strongest components available.
Old 08-06-2004, 06:24 PM   #11
Shoope1
KY Mtn Crawler
Shoope1's Avatar
Member # 9865
Send a message via ICQ to Shoope1 Send a message via AIM to Shoope1 Send a message via Yahoo to Shoope1
I might be needing a pump and resevoir.
My set up is a dan foss valve
and a single ended cylinder right now.
My stock saginaw is shot on my ford 460.
How much for the pump and bracket/ res?
BentFabrications
Bulldog Winch---Pm for pricing.
Greatlakes Offroad
2008 Polaris RZR
90 Toyota DD/ Mild Trail Rig
Shoope1 is offline   Reply With Quote
Old 08-08-2004, 09:14 PM   #12
Scott@Rockstomper
The winch rope guy
Member # 1889
Basic performance pump is $140, reservoir is $45. We don't have pump brackets; quasi-universal reservoir bracket is $15.
Old 09-29-2004, 09:06 AM   #13
Scott@Rockstomper
The winch rope guy
Member # 1889
Got a pile more orbitals in, both return and non-return, plus pumps, more cylinders, and even got some basic econo single-rod cylinders in 2" and 2.5", in addition to the big bad-boy stuff we've had all along.
Old 09-29-2004, 09:57 AM   #14
Lemoore-on
Member # 24
Send a message via ICQ to Lemoore-on
Scott, do you have everything in stock for ram assist? Same set up RE:Todd got from ya.
Lemoore-on
Mike, 85 Toyota SUV
[B][URL=http://www.tinbenders.org]Tinbenders![/URL] [/B]
Lemoore-on is offline   Reply With Quote
Old 09-29-2004, 01:13 PM   #15
Scott@Rockstomper
The winch rope guy
Member # 1889
At the moment on the ram assist, no--waiting on 1.5" cylinders to come in.
Old 09-30-2004, 10:53 AM   #16
Scott@Rockstomper
The winch rope guy
Member # 1889
'k, got 1.5x6" assist cylinders on the shelf now, but waiting on 1.5x8" units. If you've got typical Toy high steer, the 6" is what you'd want (trying to remember what Re:Todd got, and drawing a blank), low steer calls for the 8".
Old 09-30-2004, 11:19 AM   #17
hbar314
Member # 22756
Send a message via AIM to hbar314
Ok im running 4x4labs double double arms and was wanting to go to assist and was wonder if the 6" or 8" would be needed. I have my box tapped, so how much for the rest of what i need?
thanks
hbar314 is offline   Reply With Quote
Old 09-30-2004, 11:28 AM   #18
hbar314
Member # 22756
Oh and on your site you have that photo of a toy on its side in some ones lawn. Whats the story behind that?
Old 09-30-2004, 12:33 PM   #19
Scott@Rockstomper
The winch rope guy
Member # 1889
Not familiar with those arms--the ram needs to have at least as much stroke, as the tierod has travel. So just decide on a couple of reference points, one on the axle, one on the tierod, cycle to full lock one way, measure, then cycle to lock the other way, and measure again. Difference is the tierod stroke, and you'll need a cylinder to stroke at least that far.
1.5" bore assist kits run $225 for cylinder, lines, tabs, and fittings.
The Toy on its side was mine before I cut it up; it was put over (very carefully--the sheetmetal never actually hit the ground) for undercarriage pictures.
Old 10-08-2004, 08:05 AM   #20
Kajo4x4toy
Kajobuilt
Kajo4x4toy's Avatar
Member # 2537
Scott,
I Recieved your orbital valve P/N 100 NR on Wednsday. I don't have it with me right now and I am trying to order the necessary fittings. What are the size of the port?
John Baker
KAJOBUILT
Authorized dealer for the following companies:
Corbeau Seats, Diamond Axle, Front Range Off Road, Pitbull Tires, Poly Performance, Ruff Stuff, Trail Gear.
PM me, email me at kajo@kajobuilt.com or call me at 570-567-4415 for quotes and/or orders
SFC, US Army (Retired)
Cancer Survivor since 2002
Kajo4x4toy is offline   Reply With Quote
Old 10-08-2004, 10:46 AM   #21
welndmn
Well Done Man!
welndmn's Avatar
Member # 398
oh oh oh , I can answer that.
They are 3/4 o-ring fittings
Scott, I got all my stuff on, and it works great going to test it out this weekend.
For anyone that needs a pully that works with scotts pump, I used this one, GM part number 000014084343, its a double groove pulley with the first groove really offset towards the pump and the 2nd groove in the "normal" spot for the P/S
Mark
Old 10-08-2004, 12:38 PM   #22
Kajo4x4toy
Kajobuilt
Kajo4x4toy's Avatar
Member # 2537
Thanks
KAJOBUILT
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
