Pirate4x4.Com Bulletin Board
Old 08-20-2004, 12:36 PM   #1
66CJdean
Pirate4x4 Addict!
Member # 940
Hummer wheel centers
Price slash on rock rings and centers!
I picked up a new laser cutter that can give me a better price so I am cutting my price on the stuff I have down to the old price they were back before the big steel hike! This will be my new price once again on the new stuff. Wheel centers are once again $50 and Rock Rings will also be $50 not $60 as listed below. I want to sell the stuff I have to make room for new!
I have a new batch of wheel centers in again of the snow flake pattern and have some of the star pattern with the 8x170 and 8x6.5 pattern all in the same center so it has 16 holes.
Here is the snowflake
These are $60ea
And here is the star although this has only 8 of the holes in it. I do have them with only the 8x170 if you need the metric pattern only or I also have them with both the 8x170 and 8x6.5.
These are $55ea
Rockrings are $60ea and plastic runflats $55ea.
I have a new batch of the rebar ring coming in and they are now $6ea
Phone # is in my signature.
Thanks
Dean
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order. 4340, TorMax, or 300M
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 08-25-2004, 02:13 PM   #2
mucknet
Member # 21995
Hey Dean, don't suppose you have any wheels do you?
mucknet is offline   Reply With Quote
Old 08-26-2004, 05:13 AM   #3
montywa
Member # 24676
do you still have any of those 6 lug snoflakes laying around still. I should have bought five last time. I want 1 more.
montywa is offline   Reply With Quote
Old 09-12-2004, 02:32 PM   #4
-=PEAKABOO=-
Take your teeth out
-=PEAKABOO=-'s Avatar
Member # 21296
What about something with a rockwell center?
PM me a price if you can make them.
Shipping will be to 76014
Peddling trash and pushing junk!!!
-=PEAKABOO=- is offline   Reply With Quote
Old 09-13-2004, 09:47 AM   #5
66CJdean
Pirate4x4 Addict!
Member # 940
For Rockwell you will have to get ahold of John351C. He does any pattern for the most part and does good work. Also I only hace a jig for welding in 8 lug centers so I can dial indicate them in so I know they are as true as you can get a hummer wheel.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 09-24-2004, 09:01 AM   #6
66CJdean
Pirate4x4 Addict!
Member # 940
I have 3 of them I think.
I also have a new batch of the rebar rings coming in this weekend.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 10-16-2004, 12:30 AM   #7
Blazr77400
Blazr77400's Avatar
Member # 7228
How much to recenter 5 hummer wheels? I already have the wheels, just need centers and then have them put on.
PICTURE LINK
84 K30 Crew Cab short bed
HP Tuned and Cammed LS 6.0, 4l80e
NP208 range box and divorce mounted 205,
Dana 60, 14 bolt, Hydrualic Assist
4 inch 52s, 3 inch 64s with 4" shackle flip
20x12 Forged Centerlines on 41x14.50 irok radials
Blazr77400 is offline   Reply With Quote
Old 10-19-2004, 05:17 PM   #8
smokd
Member # 26329
Do you sell complete hummer wheels with choice of centers and backspacing?
If so do you got a price?
If you have thin skin, thicken it. Sarcasm is the breakfast of champions......................BITCH!
smokd is offline   Reply With Quote
Old 10-20-2004, 02:13 AM   #9
Rockabilly
rock midget
Member # 13880
how much to recenter four rims with 5 on 5.5 centers?
Rockabilly is offline   Reply With Quote
Old 10-20-2004, 04:52 PM   #10
66CJdean
Pirate4x4 Addict!
Member # 940
You choose the center and add $50 so $105 or $110
For that price I will cut out the old center on the milling machine, jig weld in the new center, bead blast the wheel, and primer it. If you want the rebar ring welded on also add $20 or I also just got a batch of the 3/8" laser cut rock rings. If you want them welded on add $65.
I have a new batch of the rebar rings in now also.
I am all out of wheels so you will have to come up with some wheels to have recentered. I only do 8 lug for the most part. I have 4 of the 6x5.5 pattern left that are 4 for $150.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 10-29-2004, 10:49 AM   #11
66CJdean
Pirate4x4 Addict!
Member # 940
I just got in a new batch of laser cut rock rings and also got in a batch of the rebar rings.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 11-26-2004, 03:32 PM   #12
bigblacktj
bigblacktj's Avatar
Member # 37548
what is the rebar for and do I need it?
bigblacktj is offline   Reply With Quote
Old 11-26-2004, 06:35 PM   #13
66CJdean
Pirate4x4 Addict!
Member # 940
The rebar ring is for the outer lip of the wheel and yes you need something for the outer lip or it will smash in or peal away and leak once you grind the wheel on a rock. The rebar ring and laser cut rock ring do the same thing for the most part.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 11-28-2004, 09:21 AM   #14
bigblacktj
bigblacktj's Avatar
Member # 37548
will the rebar mess with my wheels being balanced
Old 11-28-2004, 12:24 PM   #15
66CJdean
Pirate4x4 Addict!
Member # 940
Yes. Due to the welding you will have to do and if you are running the hammer on weights they will have to come off and you will and should run the stick on weights on the inner part of the wheel.
I'll search for freds40 and see if I can find a photo of his wheels with them on.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 11-28-2004, 02:50 PM   #16
freds40
freds40's Avatar
Member # 14437
Her ya go Dean. I solid welded the outer, did 4 stitch welds on the inner side and ground the outer weld smooth so I can still get da ladies standing outside the mall.
freds40 is offline   Reply With Quote
Old 11-30-2004, 07:47 PM   #17
bigblacktj
bigblacktj's Avatar
Member # 37548
can you take a closer pic of the weld and draw an arrow to it I am still having trouble seeing why I need these so bad.
Old 12-01-2004, 02:52 PM   #18
JeeponRock
Member # 27787
Send a message via Yahoo to JeeponRock
Do you have inserts (to replace the runflats) and how much for 5 shipped to 30087?
71 Commando with 4.0HO, nv4500. D60, D60HP, 38" TSL SXs, Hummer wheels... under construction.
Make April 15th just another day.
[url]www.FairTax.org[/url]
JeeponRock is offline   Reply With Quote
Old 12-06-2004, 05:31 AM   #19
JoshC
JoshC's Avatar
Member # 5378
You need to see Hummer wheels (those that see trail use) without the rings or rebar. They get all mashed up just as Dean described.
IMO The rebar is inexpensive and effective. I have and prefer the rockrings. Not only do they protect the lip, but they protect the 8-bolts too. I found as an added bonus while running up winch hill 3 at fordice they actually work as a traction aid too.
thisDYSFUNCtional.org
JoshC is offline   Reply With Quote
Old 12-08-2004, 10:21 AM   #20
66CJdean
Pirate4x4 Addict!
Member # 940
Yes i have runflats. I'll have to check on the shipping though and shoot you a PM on that.
The reson you need them is only if you are spending time in the rocks. The outer lip of the wheel is not that tough so once it gets smashed against a rock or you pinch the rear into the V or something the chance of the outer lip pealing out or smashing flat and leaking is very good. If you spend all your time in mud then you probably don't need them.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 02-13-2005, 10:34 AM   #21
Jabbodog
Member # 34780
Can you still make weld ins for a toyota 6 lug? I could really use some. thanks.
1985 4Runner, 4-link rear, lifted, locked, chopped, bobbed. Dual cases. 39.5" TSL's
WWW.DIXIECRAWLERS.COM
Jabbodog is offline   Reply With Quote
Old 02-16-2005, 06:10 AM   #22
91blaze
Member # 21282
Can you make a center with to fit a 6lug and 8lug pattern on the same center?????
Edit: No you can't
91blaze is offline   Reply With Quote
Old 02-22-2005, 04:00 PM   #23
Geesh
Academic Speedbump
Geesh's Avatar
Member # 4787
Send a message via AIM to Geesh
You mean these Dean's H/W rocks
wrapped in pleather
Geesh is offline   Reply With Quote
Old 03-14-2005, 12:07 PM   #24
jethrodeg
H Rated
jethrodeg's Avatar
Member # 36099
Dean,
How much for 4 pvc R-F's?
How much for 4 rebar's with welding?
Do you sell the H1 wheels seals?
I will take care of the shipping.
Thanks!
jethrodeg is online now   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
