Pirate4x4.Com Bulletin Board
Old 02-01-2002, 08:29 PM   #1
DougM
Member # 4481
How does Hill Descent mode work?
What's it using to slow the vehicle? A speed sensor and a way to apply the brakes? A device in the tranny for engine braking, like a hydraulic Jake Brake?
Thanks.
93 80 Series LandCruiser, dual lockers.
99 Montero, rear locker
DougM is offline   Reply With Quote
Old 02-01-2002, 08:33 PM   #2
Old Scout
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
A Jake Brake is an Exhaust brake.
Old Scout is offline   Reply With Quote
Old 02-01-2002, 09:40 PM   #3
DougM
Member # 4481
Yeah, I know what a Jake brake is. Was speculating that the LR system may use a similar non-brake system to slow the vehicle as the Jake brake does, but is doing it hydraulically in the auto tranny with some type of valve that shuts to cause enormous internal tranny braking. Total flyer. I have no clue what is actually used, but that was a random thought I had to impress you with my fathomless engineering savvy.
So, what is the Hill Descent braking force generated from?
Old 02-02-2002, 10:57 AM   #4
Cutter
Member # 5510
brakes...if you're really interested, I'll go out and read the owners manual in my Disco II
Lewis'Cutter'Jones
Moab, Utah
'99 Disco II TReK and some other junk...
www.anasaziexpeditions.com
www.moabslickrockhouse.com
Cutter is offline   Reply With Quote
Old 02-02-2002, 03:20 PM   #5
DougM
Member # 4481
Sure, that would be great if it goes into that detail. I'm interested enough in knowing about it if you're interested enough in grabbing the manual!
Old 02-02-2002, 05:31 PM   #6
evilfij
Member # 7755
Answer to your question:
poorly
Basically it works like ABS and limits your speed to whatever mph (dependent on what gear you are in)
LR installed it in part because they eliminated the CDL and thus the rear end tend to try to beat the front down the hill.
Ron
:evil:
evilfij is offline   Reply With Quote
Old 02-03-2002, 12:49 AM   #7
DougM
Member # 4481
Holy Crap! I must be using Outer Mongolian language conversions here. Let me try this again:
Hill descent mode slows the vehicle. HOW does it do it? Brakes? Some internal engine braking via the torque converter/tranny? Elves? A 15lb Danforth anchor? JATO units? Fred Flinstone method? HOW is what I'm looking for - please explain that aspect of the system to me if someone knows, eh? Thanks.
Old 02-03-2002, 05:29 AM   #8
Strange Rover
Member # 7962
Heres what I think.
An exhaust break just blocks the exhaust off the slow the motor. This has nothing to do with hill decent
A Jake break actually alters the valve timing in the diesel motor and actually tries to run the motor backwards. Diesel engines that we get in OZ now have about 600hp driving power and the 600hp retarding power (via the Jake break) Also by pulling in the horten fan you get about anouther 50hp retarding. This also has nothing to do with hill decent.
Like Ron said hill decent works poorly. Ive had first hand experience at this. In some situations it is just plain dangerous.
The braking sys on the disco has a hydraulic pump and computer controlled solenoid valves. When the computer sences wheel speed greater than 7kph (4mph) (I think) then it brakes the wheels individually to slow the rig down (while retaining steering control). It uses the same components as the ABS system. The hill decent does work well in its element (works well for someone that has no off road driving ability) as it makes the vehicle much simpler to drive in that it does everything for you. Same goes for the traction control instead of the centre diff lock. To engauge the centre diff requires judgment and the traction control is totally automatic. The traction control also uses the same components.
So the answer the question how does it slow the vehicle, it just applies the brakes via solenoid valves and a hydraulic pump in a selectable and controlable manner.
Sam
Land Rover SIIa, 302W, NP435, NP205, MOG404s, 42in Swamper TSLs, 112in WB
"An expert is somebody who learns more and more about less and less until one day they know absolutely everything about nothing."
Outerlimits4x4.com - home of aussie rock crawling.
Strange Rover is offline   Reply With Quote
Old 02-03-2002, 09:38 PM   #9
antiredneck
Member # 7967
To "split hairs" the Jake doesn't shut off the exhaust to increase back pressure. On the compression stroke, even without fuel introduced to cause burning/expansion, the piston just compresses air then bounces off of it, with no net energy being absorbed (other than friction). When the Jake brake is activated, It lets the piston compress the air in the cylinder, but denies it from using the pressure to be pushed back down by instead opening the exhaust valve and the pressure leaves through the exhaust, (and makes a blat sound. ) Read about this on the "howstuffworks.com" site.
antiredneck is offline   Reply With Quote
Old 02-03-2002, 11:22 PM   #10
Strange Rover
Member # 7962
I knew it had something to do with the valve timing. Thanks for the explanation
Sam
Old 02-04-2002, 01:37 AM   #11
merv
fawkin newbie
merv's Avatar
Member # 9396
Of course, a real cliff decsent conrol involves a rear mounted winch
Merv.
Merv.
Warning, spellchecker is switched off, gramma may be errotic.
merv is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
