#1 |
Member # 15061
Fj80 Chromoly Birfields
OK GUYS
We are coming out with FJ80 4340 chromoly LONGFIELDS these will be the same as our new toyota chromoly birfs the inner cage an race will be heavyer and longer also. They will be out in about 6 weeks, they will run about $315.00ea.
MADE IN THE USA! WWW.LONGFIELDSUPERAXLES.COM ORDER LINE TERRA 360-893-0235 24 HOUR TECH LINE 253-847-8254 FREE SHIPPING! |
#3 | |
Member # 15061
Yes it will be the style that takes the ABS ring it will be the longer stub shaft one. It will fit all.
#4 |
Comparison in strength to the mini truck birfs?
#5 | |
Member # 15061
Same size stub shaft 30 spline much bigger bell an race i would think much stronger.
#6 |
Member # 8672
I have 2 fj-80 birfs w/ abs ring if you're looking for cores. I could use a couple things you sell.........so how 'bout a trade?
Gotta try. I have the inners too
Nothing on ebay Don't you hate it when you're getting a bj and just as you cum - she sneezes and it comes out her nose..... Quote: Originally Posted by ScottFJ40 V2.0 This country is so full of pussies, it smells like a tuna boat crashed into a codfishcake factory. |
#7 |
I have the ones without the ABS ring (a 91 axle). These will work right?
Or do I need to go out an find an ABS ring? You da man Bobby. Expect my $$$ in 6 weeks.
[b]"Just flail around a bit and drive up.[/b] Rollin' deep in the 24 karat krawler. |
#8 | |
Member # 6292
You only need the ABS ring if you have, and want to keep the ABS. The longer birf will work in an earlier axle. You can get the thicker, '93-up drive flanges to work with them. You can still use lockouts too, but without the c-clip inside the lockout. --Dan
SC Amigo |
#9 |
Member # 15061
[quote=houlster]You only need the ABS ring if you have, and want to keep the ABS. The longer birf will work in an earlier axle. You can get the thicker, '93-up drive flanges to work with them. You can still use lockouts too, but without the c-clip inside the lockout.
Thanks Houlster the FJ80 s are about 2 weeks away
#10 |
What is the inner star and cage made from? 300M or 4340?
Sean ---------- '87 FJ60 33" TSL's and cable lockers '94 FZJ80 stock - the wifes "someday" wheeler TLCA# 13587 [url]http://alaska4x4network.com/[/url] |
#11 | |
Member # 15061
Yes 300M.
#12 |
Member # 30566
Are these ready yet?
Shawn Jackson http://www.actionjackson.com/buggy |
#13 |
Member # 8565
Is this Birf only or inner axle as well? You dont seam to have mentioned the inner axles. And if they are inner axle as well will it have the 30 spline star?
www.outerlimits4x4.com www.werockaustralia.com SAVE THE HAMMERS Post #749 Do illiterate people get the full effect of Alphabet Soup? If electricity comes from electrons, does morality come from morons? |
#14 |
Member # 15061
Chromoly birf only it will fit your inner axle. Sorry for the delay will be here the 1-17-05.
#15 |
Member # 30566
ttt. You guys gotta make the inners too
#16 | |
Member # 30566
#17 |
Member # 15061
They will hopeful be here 1-28-05 This is what we were told by our supplyer again. SORRY FOR THE DELAY.
| Thread Tools | |
| Display Modes | |
