Pirate4x4.Com Bulletin Board
Old 11-18-2004, 05:44 PM   #1
Longfield
Longfield's Avatar
Member # 15061
Yukon Ring +pinions On Sale
YUKON RING+ PINION
now available
We give them with our successful heat treating process and cryogenically freeze them. This makes them stroner than stock to withstand taller tires, extremely low gear ratios and provides good wearability. This treatment also helps prevent chipping and cracking under extreme shock loads.
4 CYL. 5.29 - $175.00 ea.
4 CYL. 4.88 - $175.00 ea.
TO YOUR DOOR
MADE IN THE USA!
WWW.LONGFIELDSUPERAXLES.COM
ORDER LINE TERRA 360-893-0235
24 HOUR TECH LINE 253-847-8254
FREE SHIPPING!
Longfield is offline   Reply With Quote
Old 11-18-2004, 05:57 PM   #2
01tacoboy
Member # 22010
How much stronger than stock do you estimate them to be?
01tacoboy is offline   Reply With Quote
Old 11-19-2004, 10:16 AM   #3
Longfield
Longfield's Avatar
Member # 15061
Good question
We have no way of testing ft. lb. difference between treated an none treated yet. Like our testing our birfs an u-joints in numbers, but we know this treatment works good on others produsts.
If your not sure about the treated ones we can sale you the stock none treated ones
MADE IN THE USA!
FREE SHIPPING!
Old 11-20-2004, 08:10 PM   #4
Longfield
Longfield's Avatar
Member # 15061
Jim thanks for the gears and the birf kit you purchased. Tried to call you about the seals. We will send them to you right away. Thanks again.
Bobby
MADE IN THE USA!
FREE SHIPPING!
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
