#1 |
Pirate4x4 Addict!
Member # 940
Price cut on Hummer wheel centers and Rock Rings
Price slash on rock rings and centers!
I have wheels now so I am taking orders on complete wheel packages again. Wheel, recentered, bead blasted, primered, with a plastic runflat, and new hardware starts at $245. Add $20 for rebar ring installed Add $60 for 3/8" thick rock ring installed Bad news is I don't have enough wheels to just sell the wheels. Wheel centers are once again $50 and Rock Rings will also be $50.(for the snowflake pattern) Runflats are $65 assembled. Rebar rings are $7ea. If you have wheels and want them recentered 8 lug then that is $100ea wheel and covers the cost of a new center, me cutting out the old center on the milling machine, jig welding in the new center, countersinking the holes, bead blasting the wheel, and primering it. $10 more ea for other bolt patterns Here is the snowflake ![]() 3/8" thick Rock Rings
WWW.PCRYO.COM Deep Cryogenic Tempering Service Find all my products at www.KICKASSOFFROAD.COM 916-434-6978 Custom Axles built to order. 4340, TorMax, or 300M Custom Hummer wheels and centers Axle Resplining |
#2 |
Member # 13214
I am assuming the rebar ring is a cheaper alternative to the rock ring?
Does the bar come bent to shape and is just welded in? Do you have any pics of the rebar ring installed? Thanks, Chris
1987 YJ-Supercharged 350 TBI/NV4500/homeade KLUNE/flipped 300/Mog 9s/3 link front/four link rear/37 IROKS |
| Sponsored Links |
#3 |
Pirate4x4 Addict!
Member # 940
There is a pic of Freds40 wheels with the rebar ring welded in on my older post so look back a few days in this forum and you will find it. They do come pre bent, just trim to fit, and yes it is a cheaper way to go but very effective.
#4 |
Member # 26393
I'd be interested in a set of 5 star centers and rebar rings. How much to countersink the holes and ship all to zip 23608 residential?.. thanks
#5 |
for the rock rings, is that 50 for a set or 50 each? if it is 50 for a set, ill get a set.
If your not breaking stuff, then you arent trying hard enough.....smash the skinny pedal |
#6 |
Pirate4x4 Addict!
Member # 940
Sorry they are $50ea. They are also cut out od 3/8" so they are pretty spendy but do look cool.
#7 | |
Pirate4x4 Addict!
Member # 940
#8 |
Pirate4x4 Addict!
Member # 940
Btt
#9 |
Member # 26393
Got my centers like 5 days after ordering (in Virginia). Nice!!! Fit lugs and wheel perfect! Thanks!
#10 | |
Pirate4x4 Addict!
Member # 940
Dean
#11 |
Member # 26393
Got one of the rims done today (minus the rebar ring). Had to mount up a 42" TSL and mock it up on the CJ.. I just swapped in a D60 using my old SOA setup but outboarding the springs. I'll probably remove the fender and hack up the body. The rear is getting the 14 bolt via a 4 ink coilover setup... It was really easy to recenter. I set runout at about .010" (the stock rim was actually closer to .025").
#12 |
Pirate4x4 Addict!
Member # 940
I would drill a new center pin hole 1" back in the spring pad to move the front ahead 1". If you can. On my CJ5 I cut out the triangle piece there in the tub so the tires had enough room and so i stopped hitting it. Looks good.
#13 |
Member # 40654
I would like a price on 4 rock rings shipped to 37398.
Also can you make the rock rings out of 1/4 inch instead of 3/8? |
#14 |
Pirate4x4 Addict!
Member # 940
I can check into it but since they would only be a run of 4 the cost would end up more than just going with the 3/8" ones.
4-3/8" ones shipped to 37398 would be $227.71 though if you go 3/8"
#15 |
Do You Forsee Any Wheels Coming Your Way? I Would Like To Get A Set From You If I Can't Find Any In The Mean Time. Please Keep Me Posted And I Will Do The Same.--james.
TOP O' THE MUFFIN GOODNESS! |
#16 |
Pirate4x4 Addict!
Member # 940
Not really. There was a post on here about finding who wants hummer wheels there on the general board and allot of people chimed in so we will see if any surface.
#17 |
Member # 41678
hummer centers question
I need 4- 8 on 6.5 bc on the snow flake pattern, are your dual pattern sloted holes or two separate patterns? How much shipped to 80817? Depending of course of the quality of my welding and installation have you ever tried to balanced a set of like 37x14R16.5 Iroks or similiar.
TunePortTOY |
#18 |
Member # 18705
Dean,
I'm trying to finagle 5 of the 12 bolt wheels right now. Do you have the rock rings for them as well? What are your runflats made from? PVC? I read on another post the the civilian hummers ran some sort of a rubber part. Any difference in the performance or durability? I like the snowflake pattern and would be interested in sending you all 5 wheels for complete setup. What would the cost be for center, rockring, runflat, labor & shipping to 92592?
'83 CJ7, LS1, TH400, Atlas 3.8, Dana 60F, 2001 14Bolt, 4.56's on ARB's, 39.5x16.5 TSL's, Four link rear with 16" Fox coilovers, High Angle shafts, Hydroboost, Novak aluminum radiator. Getting closer! |
#19 |
Member # 8294
Is this a sale price or will the price be good thru the summer. I may be passing thru your area this summer on my way to Oregon and would love to drop off a set of rims that I could then pick up on the way home maybe a week later. I would want them recentered with rock rings. How much for that?
Thanks
2001 F350 Superduty Crew Cab, long Bed, 4x4 PSD, 6-Speed, DP-Tuner, TN turbo, ITP stuff, Magnaflow 4" [URL="http://www.pirate4x4.com/forum/showthread.php?t=443323"]Big ToyHauler[/URL] 2005 Suzuki DL1000 V-Strom The commuter. 2006 Yamaha Rhino - the super golfcart. [B][COLOR=RED]You are a pawn of my evil intent![/B][/COLOR] [COLOR="Yellow"]If life gives you lemons, throw them at the stupid people![/COLOR] |
#20 |
Pirate4x4 Addict!
Member # 940
Tonka
It would be $165 ea for recenter and the rock rings installed. I don't expect the steel prices to go up much more so this price should be in effect at that time. At this time I do not have a rock ring for the 12 bolt wheel but have enough interest in them to make some. I will need your wheels to make the print from to get them done so the delay in getting your wheels done will be an extra week or two. My runflats are 3/4" wall PVC. I have done close to 200 of them with no problems to date that I know of. They are cut and them milled to match the angle of the wheel. I also make them a little smaller than the stock runflats because the bead on the tires we run are thicker than what the stock runflats were designed for. Standard recenter of wheels is $100. That covers milling out the old center, jig welding in the new center, bead blasting the whole wheel, and primering it. If you want rock rings they are $50ea + $15ea to weld them on. If you want the rebar rings they are $6ea + $10ea to weld on. Runflats are an extra $55ea. Hope that covers it.
#21 |
Member # 8294
Thanks. I may have to do it myself, as the trip may be cancelled, but I am definately interested.
EDIT: What type of payment do you take?
#22 |
Pirate4x4 Addict!
Member # 940
Paypal or send me a check for 1/2 up front.
My paypal is 66cjdean@pirate4x4.com. The wheels are not that bad of a DIY job as long as you have a way to cut out the old center. Thanks Dean
#23 |
Member # 18705
Okay thanks Dean.
#24 |
Member # 37497
do u make any snow flake pattern for toyota.
#25 |
Pirate4x4 Addict!
Member # 940
I can. I am about to have some done for a guy so I can do 8 then. I stopped making them because they didn't sell well but can have some done. One thing to note is that you need to run the IFS hubs or run a 1/2" or larger spacer to get them to clear the calipers.
| Thread Tools | |
| Display Modes | |
