#1 |
Moderating Midget
Sunray Engineering's 2005 2 Seat Buggy
LS1, 4L60E, Atlas 3.8
Nolen Grogan CottonLand Cruisers www.rockmidgetphotography.com blacksheep4x4.com USAF Veteran 1988-1998 GOD Bless America |
#2 |
Moderating Midget
| Sponsored Links |
#3 |
Moderating Midget
#4 |
Moderating Midget
#5 |
Moderating Midget
..............Frame clearance for the front tires to turn into.......
#6 |
Moderating Midget
front....
#7 |
Moderating Midget
...front axle housing
#8 |
Moderating Midget
......stuffed with this. Check out the turned down ring gear for weight.
#9 |
Moderating Midget
nutha
#10 |
4xdork
Member # 3263
mog-9's?
Team Tank old junk, new junk, unfinished junk Live Large-RIP Jason Payne ARMY TRUCK STOLEN! |
#11 |
Moderating Midget
mo....
#12 | |
Moderating Midget
#13 |
Member # 24434
Nice very clean
#14 |
some nice hardware and welds. I'm not all that keen on teh appearance, but function before form is where it's at
#15 |
Hmm what is wrong with the apperance it look's strong as hell...
..they do the best work in Texas I feel and most of the country.Who is going to belong to Nolan?Or is going to be a comp buggy for there shop if so I wonder if Lance will be the lucky one to drive it...lol..
[SIZE="5"][COLOR="Blue"]www.rockjunkie.net[/COLOR][/SIZE] [URL="http://www.crackslinger.com/login.php"]http://www.crackslinger.com/login.php[/URL] [URL=http://www.pirate4x4.com/forum/showthread.php?t=313836]Link's to rockwell question's and info...[/URL] [URL="http://www.ouversonengineering.com/"][SIZE="5"]http://www.ouversonengineering.com/[/SIZE][/URL] |
#16 | |
Moderating Midget
#17 |
Member # 13028
What's the deal on those link and engine mount bushings? They don't look like poly inserts. And the center of the OD is eccentrically relieved? Is the relief just for weight savings? Does the bushing have a soft coupler inside or bearing?
Sometimes the small details fire me up.
I may lack much in way of integrety but I make up for it with pure denial. [URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL] |
#18 | |
Moderating Midget
The designer is a mechanical engineer and a ton of thought has gone into this rig. Here is a picture of the link ends. I run similar ends without the weight shavings. They use XJ lower buchings and twist 360*
#19 |
Moderating Midget
Here is a complete "twisty"
#20 |
Member # 2587
Location: 38*45.859N 120*34.534W (N. Ca) Future location of beachfront property.
I'm ok with the engine selection. Is it from a firehawk or camaro?
Highly UnStAbLe with nothing to lose. |
#21 |
tits or gtfo
Member # 17904
I'm in, send that sucka my way. Oh, wait, this isn't a red star thing is it?
Love the gun drilled parts. But has your engineer figured out that more weight could be saved by the addition of fluting the straight round parts? It's still just as strong, but with a little more weight saving. Could pull you down a couple more pounds over the whole buggy. IIRC, 7 pounds reduced equals 1 horse power freed up. |
#22 |
4xdork
Member # 3263
no mog 9's?
then i'm guessing custom portals or some planetary design, that ring gear looks like a freeway ratio to my uneducated eye
#23 |
Member # 13028
I would have guessed at some 609s but the tubes are cut pretty narrow for that.
I'm a little surprised at the use of course threads for the 360* link ends. Maybe it's another weight issue. I also like the use of gun-drilled parts but thinking of the procedure gives me nightmares. I worked with an old Eldorado gun-driller for 10 years and always hated it. The drill's point is offset 50% of radius and hi-nickle alloys make the drill scream.
#24 | |
Member # 13028
EDIT - Maybe the spool is throwing me off.
I may lack much in way of integrety but I make up for it with pure denial. [URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL] Last edited by JeepinDoug; 12-15-2004 at 09:27 PM. |
#25 | |
Member # 25521
| Thread Tools | |
| Display Modes | |
