Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Approved Vendor's Marketplace > Axles/Tires/Wheels
Thread Tools Display Modes
Old 12-16-2004, 04:57 PM   #1
Independent4x
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
building your steering or links? Independent4x offer's 4' D.O.M. and inserts
This is my 1st offering here on the PBB vendor section.
Building your own steering or suspension links this winter? here's the junk you need.
So you've seen the price of steel way too expensive to waste. If your local place looks at you retardedly when you say D.O.M. or will only sell you a 22' stick.......well we gotcha covered
we have short lengths of D.O.M. (4' and 5'):
1.25" o.d. x .120 wall x 1.01 i.d.
or
1.5" o.d. x .250 wall x 1.00 i.d.
need more or less than 4'? let me know.......
AND i have 2 different inserts for either Heims or TRE's in both LEFT and RIGHT hand thread:
7/8" x 18 tpi for TRE's
or
3/4" x 16 tpi for Sphereical Rod Ends (heims)
i also have botth LEFT and Right thread Jam nuts for 7/8" x 18 or 3/4" x 16, as well as Heims and most all popular TRE part numbers for GM taper.
please PM me or post up and i'll quote you on what you need. include your Zip.
here's an example of a complete kit w/ TRE's.......you can buy any individual part or a complete kit :
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 12-21-2004, 09:30 AM   #2
Judd
Member # 16838
I'm looking for (1) 4' stick and (1) 5' stick of the 1.5"-.25" wall DOM. I also need (4) weld in inserts. I'm also gonna need (4) 3/4" Heims, what brand do you carry? Aurora, FK, etc... thanks, Judd
79 cj 7, lift, 360, and 33's for now... yeah hardcore...
Judd is offline   Reply With Quote
Old 12-21-2004, 07:18 PM   #3
Independent4x
technical expert
Member # 8755
got all of it in stock.....
i carry QA1, on the Heims. I have 2 different ones I keep in stock..both 3/4 x 16 tpi in both 3/4 bolt and 5/8 bolt.
one is a cheaper non teflon SRE called the "PCM" specs:
4130 chromo, heat treated and black oxide coated
static load on the 3/4" is 25K #
mis-alignment of 24*
the other is the "XM" w/ teflon/kevlar race
4130 heat treated chromate plate body
52100 bearing steel ball
mis-alignment angle of 14*
3/4 has a sttatic load of 28,081 #
i have left and right thread, 3/4 x 16 jam nuts & weld in inserts, and aluminum mis-alignment spacers
PM me with your list and i'll give you a quote.
not the best image, but this will give you an idea:
Old 12-22-2004, 10:53 PM   #4
RollinDeuces
Member # 25142
What kind of steel is this? I need a stick NOW!
RollinDeuces is offline   Reply With Quote
Old 12-23-2004, 09:03 AM   #5
Independent4x
technical expert
Member # 8755
D.O.M. is carbon mechanical tubing...............A513 TYPE 5 TUBE
pm'd you
Old 12-23-2004, 09:08 AM   #6
TheTonka
Member # 8294
PM me a price shipped to 91741 for a 2 5' sticks of 1.5" .25 wall 2 left hand thread inserts and 2 right hand inserts all for TREs.
Thanks.
2001 F350 Superduty Crew Cab, long Bed, 4x4 PSD, 6-Speed, DP-Tuner, TN turbo, ITP stuff, Magnaflow 4"
[URL="http://www.pirate4x4.com/forum/showthread.php?t=443323"]Big ToyHauler[/URL]
2005 Suzuki DL1000 V-Strom The commuter.
2006 Yamaha Rhino - the super golfcart.
[B][COLOR=RED]You are a pawn of my evil intent![/B][/COLOR]
[COLOR="Yellow"]If life gives you lemons, throw them at the stupid people![/COLOR]
TheTonka is offline   Reply With Quote
Old 12-23-2004, 08:20 PM   #7
ubbzy
Member # 36430
What is the life expectancy on Heim joints on a daily driver?
94' GMC K1500 SAS'ified!
Front D60 HP
Rear D60 Locked
Alcans All Around
38 SSR's
High Angle Front Shaft
14" Bilsteins F&R
ubbzy is online now   Reply With Quote
Old 12-23-2004, 08:45 PM   #8
TRed
Member # 12100
Can I see those inserts up close please? They look different and longer than the ones pictured with the heims.
Originally Posted by randii
if you're a Pickle, rolling down the trail in a Smurf, dispensing bowls of dicks. FWIW, I don't want to see pictures of that, either!
Randii
TRed is offline   Reply With Quote
Old 12-23-2004, 09:21 PM   #9
mudddog91
Member # 8815
Hey can you give me a price for 32 of your aluminum 3/4 heim spacers shipped to 27265?Also can you give me the specs as far as width?Thanks.
2009 Single seater rear engine buggy on rockwells.Well thats when I should finish........
mudddog91 is offline   Reply With Quote
Old 12-24-2004, 07:23 AM   #10
Independent4x
technical expert
Member # 8755
i know guys do use them, but i never reccomend heims on a DD. you should really use TRE's...............but, that is my opinion.
this topic has certianly been discussed endlessly in General tech............give it a seach
Old 12-24-2004, 07:31 AM   #11
Independent4x
technical expert
Member # 8755
yep, correct. they are 2 different designs. the 7/8" x 18 are much longer. here is a comparison shot. hope this helps.
Old 12-24-2004, 08:08 PM   #12
VENOMOUS
Member # 16534
How much for a 4' and 2' stick of 1.5"x.25" wall DOM with 2 Left and 2 Right hand jam nuts in 7/8"x18 as well as 2 Left and 2 Right 7/8"x18 threaded inserts to use with TRE's. I see you have a complete kit pictured so if you sell the TRE's then you might as well shoot me a price for the whole shabang. I live in VA at 22657 or if you're not too far away I could come pick them up.
Jeremiah Lucas
2004 Jeep TJ Sport
1989 Ford Mustang LX 5.0+
VENOMOUS is offline   Reply With Quote
Old 12-24-2004, 08:51 PM   #13
TRed
Member # 12100
Let me get a price shipped to 90631 for 2 right and two left of the long style inserts, and jamb nuts for 1.5x .250 tube.
Randii
Old 12-27-2004, 02:39 PM   #14
Independent4x
technical expert
Member # 8755
pretty sure i got everyone on PM.............if i missed you PM me
Old 12-27-2004, 05:48 PM   #15
95geo
Member # 15461
can you pm me a price for (4) 7/8 inserts (one left hand), (2) 5foot pieces of whatever tube you use to put the inserts into
thanks
95geo is offline   Reply With Quote
Old 12-28-2004, 07:30 AM   #16
Capt. Nemo
Member # 11777
Pm'ed ya.
Capt. Nemo is offline   Reply With Quote
Old 12-29-2004, 05:42 PM   #17
93sky4x
Member # 32735
Send a message via AIM to 93sky4x
i need 2 sticks. a tre set, and 4 inserts for tre's
93sky4x is offline   Reply With Quote
Old 12-30-2004, 10:39 AM   #18
4x401cj
Fal`s Forever
4x401cj's Avatar
Member # 37244
price
Price for complete kit with .250 tube and 7/8" tre`s. Tube length`s should be 5 ft. and I don`t wan`t to use the long tre with the drag link mount. All shipped to 97030. Thanks, Rich.
4x401cj is offline   Reply With Quote
Old 12-31-2004, 02:04 PM   #19
Independent4x
technical expert
Member # 8755
i think i got everyone................if i missed you PM me directly. thanks
oh, and thanks again to the guys that have ordered!
Old 01-03-2005, 02:03 PM   #20
95geo
Member # 15461
i didnt get a reply
Old 01-03-2005, 02:42 PM   #21
Independent4x
technical expert
Member # 8755
PM sent...sorry 'bout that.
Old 01-04-2005, 08:03 PM   #22
axaviere
Member # 7780
Send a message via ICQ to axaviere Send a message via AIM to axaviere
hey do the TRE inserts fit all the way in the tube or just part way like the heim ones do?
may as well PM me with a quote on 2-5' 1.5" sticklets and two right and two left inserts for TREs with jamb nuts also. thanks, AXE
also tell me the difference between the 5 and 4 foot lengths. i may not need 5' but there is an ice storm blowing and i am not going to measure right now
they call it[URL=http://www.supermotors.org/vehicles/registry/detail.php?id=1445&s=8699] TRUCK [/URL]79 custom 4" lift, 460 4.10 D44 8lug/D60 the front D60 is in my yard & almost ready!! 36s are on, f350 brake upgrade, i just got my rear disc kit now ... 10.25 in the future possibly
axaviere is offline   Reply With Quote
Old 01-05-2005, 06:57 PM   #23
hotwheelsYJ
hotwheelsYJ's Avatar
Member # 32401
Send a message via Yahoo to hotwheelsYJ
Can you PM me a price for everything in the picture, maybe a Price break for purchasing the whole kit?
TIA
hotwheelsYJ is offline   Reply With Quote
Old 01-05-2005, 11:18 PM   #24
TxScout
Member # 10416
TIA
ditto that, 78758 please
Thanks.
[URL=http://www.longhornoffroad.com/]Longhorn Offroad[/URL]
76/79 scout II, one ton axles on the way!!!
"Some people spend thousands on psychiatrists, I beat shit with a hammer" --Jesse James' Monster Garage
[QUOTE][i]Originally posted by Overbear [/i]
[B]2) I think we can all say doug is clearly a darwin award canadate. Let us all hope he gets his place in them soon before he reproduces.[/B][/QUOTE]
TxScout is offline   Reply With Quote
Old 01-06-2005, 09:02 AM   #25
sw99
Member # 15049
Can you give me a price on the 7/8 18 TPI Inserts for 1" ID - 1.5" OD DOM? I would need 2 lefthand & 2 righthand inserts, shipped to 80602. Thanks!
Do you have the shorter inserts? I have never seen the longer type, what's the skinny on them? Pros/cons?
sw99 is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
