#1 |
Link's to rockwell question's and info...
Post something here and there and when you find new post put them here and we will keep the rockwell info alive and going...
Shaving my rockwell today... -------------------------------------------------------------------------- Experinced people on rockwell's needed -------------------------------------------------------------------------- military tire wheelbases?? -------------------------------------------------------------------------- Hydro stroke for rockwell's -------------------------------------------------------------------------- How many use the boot's on there Rockwell's? -------------------------------------------------------------------------- 52" on rockwells will they hold up? -------------------------------------------------------------------------- rockwell question? -------------------------------------------------------------------------- Rockwell Tie Rods -------------------------------------------------------------------------- Rockwell outer wheel bearing seal??? -------------------------------------------------------------------------- rockwell bearing help -------------------------------------------------------------------------- Rim's in the making need advice... -------------------------------------------------------------------------- Stock Rockwell Rims -------------------------------------------------------------------------- rockwell clearance question -------------------------------------------------------------------------- welding a rockwell -------------------------------------------------------------------------- Rockwell T-locker -------------------------------------------------------------------------- rockwell tire clearance -------------------------------------------------------------------------- How heavy is the center section of a 2 1/2 ton Rockwell -------------------------------------------------------------------------- What master cylinder with rockwells? -------------------------------------------------------------------------- 2-1/2 Rockwell axle weight's....... -------------------------------------------------------------------------- Rockwell Detroit PN??? -------------------------------------------------------------------------- Rockwell BP? From 6 to 8 lug -------------------------------------------------------------------------- Rockwell questions... -------------------------------------------------------------------------- Rockwell Suspension Setup Questions -------------------------------------------------------------------------- NEW Staz Works Double Beadlocks -------------------------------------------------------------------------- flipping around the front rockwell axle.. -------------------------------------------------------------------------- Has anybody come up with Rockwel boot guard better than the stock flimsy one -------------------------------------------------------------------------- Rockwell Pinion Support Bolt Circle -------------------------------------------------------------------------- Rockwell 4 Link Questions -------------------------------------------------------------------------- Welding rockwell gears -------------------------------------------------------------------------- Inside the 2 1/2-ton Rockwell Axle "JP Magazine article" -------------------------------------------------------------------------- Rockwell Axle Breakdown Drawings -------------------------------------------------------------------------- All Rockwell Bearing and seal part #'s -------------------------------------------------------------------------- Rockwell FAQ -------------------------------------------------------------------------- Rockwell locker installation -------------------------------------------------------------------------- USA 6X6 FOR PART'S -------------------------------------------------------------------------- Oversoonengineering for cooler part's -------------------------------------------------------------------------- Stazwork's for your rim need's -------------------------------------------------------------------------- Boyce for your high dollar hard to [URLfind item's -------------------------------------------------------------------------- PinionBrakes - How Good? -------------------------------------------------------------------------- NOW this is Clean -------------------------------------------------------------------------- damn leaky rockwells! WTF is wrong? -------------------------------------------------------------------------- Rockwell pinion brake - cadillac ebrake caliper -------------------------------------------------------------------------- ROCKWELL AXLE project has begun.... -------------------------------------------------------------------------- Rockwell rear steer question -------------------------------------------------------------------------- bolt on brakes 4 rockwells -------------------------------------------------------------------------- iroks or Michelins -------------------------------------------------------------------------- rockwell bendix VS u-joint front or rear -------------------------------------------------------------------------- Size of Pinion brake -------------------------------------------------------------------------- yet another rockwell pinion brake -------------------------------------------------------------------------- Rockwell Boots -------------------------------------------------------------------------- rockwell pinion brakes? -------------------------------------------------------------------------- 8 Lug Rockwell -------------------------------------------------------------------------- "BEST" rockwells? -------------------------------------------------------------------------- Rockwell detroit - anyone have to mill down the side gears? -------------------------------------------------------------------------- 5-ton vs. 2.5-ton Rockwells -------------------------------------------------------------------------- Rockwell hub flip -------------------------------------------------------------------------- Rockwell Guru's -------------------------------------------------------------------------- Rockwell brake chatter -------------------------------------------------------------------------- 2-1/2" Rockwell Breakage Survey -------------------------------------------------------------------------- would 130-3" wheelbase be too long for 53" tires -------------------------------------------------------------------------- 2 1/2 rockwell? -------------------------------------------------------------------------- Alloy shafts for Rockwells -------------------------------------------------------------------------- Rockwell steering problem -------------------------------------------------------------------------- Just how dangerous are pinion brakes? -------------------------------------------------------------------------- Ok I went back almost a year searching for everything and past that time most of the stuff was the same question's over and over again so I will end this here.If you find link's off other board's please do not post them if you haft to register to see the post and also if anyone addes link's here please use the same format I used by putting the name of the post so that way people can just read it before they click on it.It will help in researching for everyone.I just put 2 hour's into this post and hopefully it is apperciated...I will try to keep adding new rockwell's post to it to keep it fresh so people can find it easily..
[SIZE="5"][COLOR="Blue"]www.rockjunkie.net[/COLOR][/SIZE] [URL="http://www.crackslinger.com/login.php"]http://www.crackslinger.com/login.php[/URL] [URL=http://www.pirate4x4.com/forum/showthread.php?t=313836]Link's to rockwell question's and info...[/URL] [URL="http://www.ouversonengineering.com/"][SIZE="5"]http://www.ouversonengineering.com/[/SIZE][/URL] Last edited by TheRipper; 12-25-2004 at 11:21 AM. |
#2 |
Member # 13810
Very nice.
Alan Hatcher www.swfwda.org president@swfwda.org |
| Sponsored Links |
#3 | |
Member # 13609
#4 |
Member # 12695
Nice job.
Dan
"We live in the Land of the Free because of the brave." Please remember our Troops! |
#5 |
Member # 25803
A+ thanks much for the great list
www.proformanceengineering.com www.wsorr.com |
#6 |
nice job RIPPER>>>>>>>>
SLick
They call me SLICK RICK with a big ............... TRUCK !!!!!!! 1997 Ford F-450 PSD 4 door, No more rockwells. dana 60/80...15.5/80/20 Mich XL's 92 Chevy S10 4dr Blazer with Rockwells and 48's If it ain't big enough, play with it more!!! |
#7 |
Member # 38173
rocks
you still dont know as much as i do ripp. lolololol
#8 |
I surpassed you many moon's ago so when you need to barrow my shop...
[SIZE="5"][COLOR="Blue"]www.rockjunkie.net[/COLOR][/SIZE] [URL="http://www.crackslinger.com/login.php"]http://www.crackslinger.com/login.php[/URL] [URL=http://www.pirate4x4.com/forum/showthread.php?t=313836]Link's to rockwell question's and info...[/URL] [URL="http://www.ouversonengineering.com/"][SIZE="5"]http://www.ouversonengineering.com/[/SIZE][/URL] |
#9 |
Member # 15689
very cool rip!
not bad for home grown it's a little more than that sonny |
#10 |
Member # 12755
should have rockwell forum with all those posts transfered to there.. quite lots of rockwell people around here
#11 |
poo sandwich
Member # 30297
thanks this kicks a$$.
any one have any more? |
#12 |
Member # 15959
#13 |
Every one is welcome and thank's for putting it in the proper way for people to see it Bigjeepguy...
#14 |
Here a couple more...
strength of rockwell 2 1/2 ton axle shafts....for those breaking them -------------------------------------------------------------------------- tool for rockwell center needed I will try to keep this updated everytime there is a new rockwell post added..
[SIZE="5"][COLOR="Blue"]www.rockjunkie.net[/COLOR][/SIZE] [URL="http://www.crackslinger.com/login.php"]http://www.crackslinger.com/login.php[/URL] [URL=http://www.pirate4x4.com/forum/showthread.php?t=313836]Link's to rockwell question's and info...[/URL] [URL="http://www.ouversonengineering.com/"][SIZE="5"]http://www.ouversonengineering.com/[/SIZE][/URL] Last edited by TheRipper; 12-25-2004 at 11:17 AM. |
#15 |
Member # 16737
Nice work Ripper.
I have some measurements and hardware sizes that may be usefull. But its probly covered in there somewhere. I'll check and see if I can add anything once im done checking all the links.
72 Rockwelled yeah whatever... All my shits heavy. |
#16 |
I sent you a pm it would be cool if we could start putting info about it here also.Just make it the best rockwell info thread ever..I will add what ever people send me if they do not want to take the time to organize it and post.
#17 |
wheeler
Member # 33155
Wow, great job/idea/effort......
73 CJ5 @ 136" wb, 502/th400/WMS 3:1 203/205, f&r narrowed, clearanced, steering Rockwells, f&r 3-link w/ coils, 49" Iroks, full hyd. |
#18 |
Member # 18233
this was excellent reading,
to you ripper.. to the top
84 GMC k5 jimmy pontiac 455 60/14b. detroit/spooled 5.13's 44 in.boggers R.I.P |
#19 |
Noob Desert Racer
Member # 3196
LOL...Hey Rip, when I first checked out this thread, about half of those links are green from my past searches!! This is an awesome thread and is def. the "Best Rockwell" thread ever.
Awesome job..... Rob
USNICK MOTORSPORTS Our 2009 Sponsors! www.heiseroil.com www.finaltouchpowdercoating.com www.performanceoffroad4x4online.com www.trailtough.com KOH '09 #406 V2R '09 #4406 KOH '10 #4406 Parker '10 #4406 |
#20 |
Here 1 more I found when looking to see if SlickRick had a build up on his blazer on rock's..
Rockwell Axle ----------------------------------------------------------------------------- Here are some more I found from Bansheeman1.. rockwell wheel brakes? ----------------------------------------------------------------------------- rockwell question ----------------------------------------------------------------------------- I wonder how many there are that say rockwell question..lol..I am responsible for atleast one.I will do my best to to repost any of the link's.
#21 |
#22 |
And another..I am serious about adding every rockwell post to this everytime.So if you catch me slipping and miss one let me know...
A few Rockwell build pic's (spiders, rims, brakes)
#23 |
Don't know if this helps but here is the buildup of slipscomb's Scout on Rockwells.\
Capt. Sean Lipscomb RMS Titanic
You never know when you might need to know how to jump out of a perfectly good airplane! |
#24 |
A few more...
pinon brake's for rockwell's.... ------------------------------------------------------------------------- Pinion Brake ? Rotor runout tolerence
#25 |
Jason@Bluetorch
Member # 14529
nice job. that had to take some time.
we offer a rockwell skid if anyone needs one. here is a link. RockWell Skid Thanks Dan
Blue Torch FabWorks, Inc. 205-521-7333 http://www.bluetorchfab.com MYSPACE http://www.myspace.com/bluetorchfab Superior Axle www.superioraxle.com |
| Thread Tools | |
| Display Modes | |
