Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 02-12-2002, 06:05 PM   #1
3/4tonYJ
back from otherside
3/4tonYJ's Avatar
Member # 1375
how bout a "watts link" instead of a track bar? ideas?
anyone using a "watts link" instead of a track bar? or have any experience with it? or any thoughts at all.....?
i'm thinking this setup looks good, maybe wouldn't limit droop like a regular track bar does. just thinking about a future project
www.52 Ford F-3.com
3/4tonYJ is offline   Reply With Quote
Old 02-12-2002, 06:58 PM   #2
evilfij
Member # 7755
In front you will have a hard (impossible) time keeping the axle located latterally.
In the rear, well, there are a ton of better options but it can be made to work ok. discovery II has a watts linkage in the rear stock. You are just much better off with a four link for flex.
Ron
:evil:
evilfij is offline   Reply With Quote
Old 02-12-2002, 07:33 PM   #3
cmk
I Wanna' Go FAST !
cmk's Avatar
Member # 987
Like Evil eluded to, it will work fine in the rear, although the complexity of it as compared to a triangulated 3 or 4 link is unnecessary.
As far as the front goes, unless you plan on going full hydraulic steering or you develop a "watts linkage drag link," it won't work ... well.
cmk
Driver ......... TREC #318
Passenger ... To Be Announced KOH-Qualifier
cmk is offline   Reply With Quote
Old 02-13-2002, 04:04 AM   #4
3/4tonYJ
back from otherside
3/4tonYJ's Avatar
Member # 1375
i'm thinking about using this in conjuction with a 4-link, to help control the axle laterally. (in place of a trac bar)
i also have ideas about using this type of lateral link with a Quarter Eliptical setup, with one "axle wrap control ladder bar (shackle at front)" and then just two "lower control arms".....
www.52 Ford F-3.com
Old 02-13-2002, 07:00 AM   #5
dirtrod
Member # 4224
If you angle 2 of the 4 links you won't need it.
dirtrod is offline   Reply With Quote
Old 02-13-2002, 07:49 AM   #6
JEEP_TJ_FREAK
Member # 4099
Send a message via AIM to JEEP_TJ_FREAK Send a message via Yahoo to JEEP_TJ_FREAK
Don't do it man!
The only watts linkage I have ever seen was busted, but is was some awsome carnage to watch.
HTH, sorry the images kinda suck, if you cannot tell the guy has a truss across the top and put a trailer spindle in it. He then used the hub to mount the links. I was a single heim failure that cause all that mess.
JEEP_TJ_FREAK is offline   Reply With Quote
Old 02-13-2002, 09:16 AM   #7
mj
Member # 1919
the steering would be EASY to make work.
same as any link suspension you make the steering linkage near parallel to a link
mj is offline   Reply With Quote
Old 02-13-2002, 12:13 PM   #8
cmk
I Wanna' Go FAST !
cmk's Avatar
Member # 987
A Watts linkage causes the axle to stay perfectly centered as it transposes in the vertical plane. A standard drag link is going to incur some bump steer as the suspension cycles in conjunction with a Watts linkage.
Sure you can minimize the bump steer by going with a long, flat link, but you can't get rid of it.
cmk
Forum Jump
