Pirate4x4.Com Bulletin Board
Old 02-01-2005, 09:02 PM   #1
PIG
2InDaPink&1InDaStink
PIG's Avatar
Member # 4502
Attn: Fj80 Front Axle Owners---->
The BADDEST FJ-80 Front Inner Axles Ever Made-
THE LOW DOWN-
-CNC machined from high quality 4340 material.
-Induction heat treated.
-Total elimination of stock spline void (serious stress riser).
-The od of the shaft (on the area between the seal and the diff side) splineis machined to match the minor diameter of the BIG 24 spline side of the axle.
-The od of the shaft between the seal and the birf side ramps up to the seal OD to localize the load to the largest area of the shaft.
-BITCHIN FACTOR................................. = 9.99
PRICING:
$300.00 per pair....(quantities are limited)
Call to order....805-783-2060
www.POLYPERFORMANCE.com
Click the sig for everything you need to build a tube car... 805-783-2060
NEW PRODUCTS ADDED DAILY !!!
PIG is offline   Reply With Quote
Old 08-28-2005, 10:20 AM   #2
PIG
PIG's Avatar
Member # 4502
Btt
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
