Pirate4x4.Com Bulletin Board
Old 02-10-2005, 01:58 PM   #1
Brian Ellinger
Brian Ellinger's Avatar
Member # 1088
~~TOYOTA, Knuckle/Steering Arm Studs are HERE!!~~
Fresh off the UPS Truck!
Each kit includes 8 ARP custom made studs, 8 Class 10 all metal locking nuts. Just because we want to make sure everything is included, we're tossing in a tube of red loctite to get those studs staying in the knuckle where they belong! Just remove the stock studs, clean out the holes in you knuckles (brake clean works best here) And install the new studs with the loctite on each one.
Note: DO NOT loctite the fine threads that the locknut goes on too, or youll remove the whole stud when it comes time for disassembly.
EDIT: Whoops, you probably want a price! $89 a set, add 8 for shipping in the 48 states.
1st place Pro-Mod WEROCK WORLD Champion
Diamond Axle
http://www.diamondaxle.com
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
http://www.frontrangeoffroadfab.com
NEW BUILD FTOY #44
http://www.pirate4x4.com/forum/showthread.php?t=562295
Brian Ellinger is offline   Reply With Quote
Old 02-10-2005, 02:01 PM   #2
Brian Ellinger
Member # 1088
Comparison of stock and new ARP stud. Notice the New studs are about 1/8" longer. Just for those arms that run a bit close on thread engagement.
Diamond Axle
NEW BUILD FTOY #44
Old 02-10-2005, 02:21 PM   #3
drnut
Member # 855
how much for a complete front axle??
The worst day of rockcrawling is better than the best day at work!
drnut is offline   Reply With Quote
Old 02-10-2005, 02:31 PM   #4
Brian Ellinger
Member # 1088
Give me a call here, and we can sort out exactly what you want, and get you quote.
Diamond Axle
NEW BUILD FTOY #44
Old 02-19-2005, 10:01 PM   #5
Brian Ellinger
Member # 1088
Still in stock, we've got a pile of these!
Diamond Axle
NEW BUILD FTOY #44
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
