Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 02-25-2005, 05:46 PM   #1
yotafreak81
Member # 40158
8" WELDABLE pipe cap...CA
I live in San Diego, and searched for a week now to find a diff cover. The only thing I can find are CAST pipe caps. I would rather not deal with the popping and spattering...plus they CRACK. I drove to San Marcos and Escondido searching at 5 places. Had 2 differnt places call thier supplier & no one can find it. Any suggestions...
P.S. Next option is to fab it myself, not a problem, but I only have a TIG...it takes a while. Plus no bender...or propane/asetylne to preheat and bend manually.
[QUOTE=hornett22]looks like a loose nut behind the steering wheel. smith & wesson sell the tool for that.[/QUOTE]
yotafreak81 is offline   Reply With Quote
Old 02-25-2005, 05:59 PM   #2
OOP'S
Pirate4x4 Addict!
OOP'S's Avatar
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
The 8" weldable pipe caps I have always used are cast. I have never broken one and they are very easy to weld. They are called 8" Weldable Pipe Caps. I got the last one at Windustral in Rocklin, CA for about $17.00.
David & Theresa, Roseville, CA,
HELLO... WELCOME TO AMERICA ... WE SPEAK ENGLISH!
Excellent Parts Source
http://www.davezoffroadperformance.com/
http://www.marlincrawler.com/
http://www.12voltguy.com/web/
OOP'S is offline   Reply With Quote
Old 02-25-2005, 06:31 PM   #3
sickfab
Member # 20208
Location: Pollock Pines, but dont worry, I decided to keep my full set of teeth, unlike most everyone else up here...
McMaster-Carr
[QUOTE=Myanarchy;6682920] Thanks for the tips, I think I'm gonna stick it between max volume and his boyfriend's pelvis. The force of their love could crush a bowling ball[/QUOTE]
sickfab is offline   Reply With Quote
Old 02-25-2005, 06:36 PM   #4
boltdude
Member # 40676
I got mine from the McMaster Carr catalog. Simple to install. I mig welded mine on. No spatter here. I cut mine in half so I can use one on the rear and one on the front. I guess you could gusset the top if you are worried about breaking yours. Good luck.
boltdude is offline   Reply With Quote
Old 02-25-2005, 06:47 PM   #5
sickfab
Member # 20208
Boltdude, do you have any more pics of your truck??? I'd like to see more of it!
Start a seperate thread on it, so this one doesnt get fully hijacked.
Old 02-25-2005, 06:49 PM   #6
sickfab
Member # 20208
Back on topic, As far as I know, the caps from McMaster arent cast, theyre formed steel.
Old 02-25-2005, 06:59 PM   #7
OOP'S
Pirate4x4 Addict!
OOP'S's Avatar
Member # 30
Mine is not formed steel it is cast, but not like regular cast, I think it is called mallable cast or something like that which is not porous like regular cast. I know that the ends that they make for this kind of pipe 90's, 45's T's, and ect. are cast and they use them for heavy hand rails and stuff. Welder Bilt used them on his Jeep for bumpers and sliders and stuff.
Old 02-25-2005, 07:06 PM   #8
sickfab
Member # 20208
Hmmmm. Could be, but are you sure its not just hot rolled steel? Like when they took a disc of 1/4" thick steel and had it red hot and shoved it into a hobbing die to form the caps? Seems more cost effective to make 'em that way.
Old 02-25-2005, 07:11 PM   #9
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
There is a big difference between Cast Iron and Cast Steel. Most Butt-Weld carbon pipe caps are ASTM A234 WPB or WPC. This is a wrought steel spec. with a max carbon content of 0.30% which is easily welded by all common methods.
jasonmt is offline   Reply With Quote
Old 02-25-2005, 07:14 PM   #10
sickfab
Member # 20208
So it is actually cast?
Old 02-25-2005, 07:17 PM   #11
boltdude
Member # 40676
I believe you are right. Now that you say that when I cut it the shavings were not black like cast shavings would be. HMMMMM... Thanks! I guess that is why the cost so much. (Dont ask me the cost I just remember it was up there)
Old 02-25-2005, 07:19 PM   #12
boltdude
Member # 40676
You'll have to go vist the other side to see my project progression.
http://www.keystonekrawlers.com/foru...pic.php?t=5536
(Sorry about the slight hi-jack)
Old 02-25-2005, 08:39 PM   #13
OOP'S
Pirate4x4 Addict!
OOP'S's Avatar
Member # 30
Try this place same place I got mine, but in S.D.:
San Diego Windustrial Co.
7585 Carroll Rd San Diego , CA 92121 -2401 Phone: 858-684-3111
Fax: 858-684-3089
Old 02-25-2005, 08:47 PM   #14
Wild_yota13
Member # 36639
Send a message via AIM to Wild_yota13
Tires on boltdude's rig
hey boltdude sorry for the cross post but i want to know what kind of tires you got on your rig?
86 toy x-cab Truggy Subaru WRBlue SOLD
Proud owner of Project "JAIL BAIT"
Wild_yota13 is offline   Reply With Quote
Old 02-25-2005, 08:49 PM   #15
sickfab
Member # 20208
They look like Dunlop Mud Rovers.
Old 02-25-2005, 09:54 PM   #16
yotafreak81
Member # 40158
Fax: 858-684-3089
Thank You!!! I will call them tomorrow. Hope they are open....
P.S. Did yours have a ton of galv. on it???
the ones I looked today all were cast and covered in galvy.
Old 02-25-2005, 10:42 PM   #17
OOP'S
Pirate4x4 Addict!
OOP'S's Avatar
Member # 30
Nope, none at all!!!!
Old 07-21-2006, 12:09 PM   #18
Terrys_85_Toy
Try Athlete
Terrys_85_Toy's Avatar
Member # 34022
Send a message via AIM to Terrys_85_Toy Send a message via MSN to Terrys_85_Toy
Bringing back an old topic here.
Does anyone know where I might be able to source one of these now? I can't find anything local (Delaware) bigger than 6" and McMaster/Carr is now charging $40 for one.
Anyone other online sources?
Terry
Originally Posted by rustywagoneersdotcom View Post
Political Correctness is a doctrine that holds forth the proposition that it is possible to pick up a turd by the clean end.
Originally Posted by fullygruntled
PBB is mostly dumb.
Terrys_85_Toy is offline   Reply With Quote
Old 07-21-2006, 12:24 PM   #19
shooter
Member # 32468
this is what your firends will do when you have a pipe cap diff guard...Nice floral arangement huh....
Ford for employment-Toyota for enjoyment
HeavyE Fourdice4x4.com
shooter is offline   Reply With Quote
Old 07-21-2006, 12:38 PM   #20
Chass
Member # 37212
I wouldn't use one anymore now that these are so readily avialable and cheap.
http://www.trail-gear.com/trail-armor.html
I just took a piece of 1/4 steel, cut it to about the shape that would fit the back of the diff and formed it with a torch and hammer on my concrete floor cuz I don't have an anvil. It works GREAT! It cost me all of $0.29.
Plus, why add all that weight and a mud collection basket to your rig?
Chass
ct
Blue Ribbon Coalition Member
Pacific Northwest 4x4 Assoction Member
JV Ralley post
Tellico Ralley post
My pipe EXO flop video [URL="http://www.harryritchies.com/ct/ChassFlopVideo.wmv"]here[/URL] [URL="http://www.pirate4x4.com/forum/showthread.php?t=342992&highlight=sprinkler+pipe+exo"]Build up thread.[/URL]
[URL="http://www.pirate4x4.com/forum/showthread.php?t=520463"]I speared my truck . . . REALLY![/URL]
[url]www.ot4x4.org[/url]
Chass is offline   Reply With Quote
Old 07-21-2006, 01:06 PM   #21
OOP'S
Pirate4x4 Addict!
OOP'S's Avatar
Member # 30
Originally Posted by Chass
I wouldn't use one anymore now that these are so readily avialable and cheap. Plus, why add all that weight and a mud collection basket to your rig?
1. For what you pay for the Trail-Mart one, I can make four of the pipe cap ones.
2. I am willing to bet they do not weigh that much more then the Trail-Mart one. Besides unsprung weight helps you from flopping.
3. Duh, you make a drain slot in the bottom.
I have been running them for about six years and I have never broken one from hitting anything, had it fill up with dirt and mud and they are cheep!!!!
Old 07-21-2006, 01:52 PM   #22
waskillywabbit
WabFab.org
waskillywabbit's Avatar
Member # 32061
Send a message via AIM to waskillywabbit Send a message via Yahoo to waskillywabbit
8 inch Sch 40 pipe cap 0.322 wall 12 lbs
Local supply here 12 bucks
I got some I need gone if anybody wants them. I went another route.
waskillywabbit is offline   Reply With Quote
Old 07-21-2006, 04:46 PM   #23
jasonmt
Mellonhead
jasonmt's Avatar
Member # 3236
Locally I can still get sch 40/std for less than $10 so McMaster is raping someone...
Too many idiots, not enough dead people
Forum Jump
