Pirate4x4.Com Bulletin Board
Old 03-16-2005, 04:33 PM   #1
Brian Ellinger
Brian Ellinger's Avatar
Member # 1088
##U-bolt Flip Kits at FROR!!##
We set out to build to best U-Bolt Flips ever with these! We get to see all the cute 1/4" formed things fold up, collapse, and u-bolts get loose. This then causes the spring to wallow all over until the center pin breaks, and oh what fun that is to fix on Upper Helldorado!
So, the solution to this pathetic-plate problem, as well as steering interfearing with u-bolt plates was simple. Make 'em compact, make 'em BEEFY!
We are the only company producing LASER CUT 1/2" THICK u-bolt plates, then combined with meaty 9/16" u-bolts! These plates DONT collapse and deform like ALL the other out there. And those nice 9/16" u-bolts dont stretch, and break like others puny 1/2" garbage.
We have kits to fit the following:
Front Toy
Rear Toy
Front D44
Rear D44
Rear 14 bolt
Rear D60
And of course, kits to fit any housing from http://www.diamondaxle.com
There may be others, just ask. Note: We dont make flips to fit spring under rigs.
$69 covers the u-bolts and plates for one axle.
1st place Pro-Mod WEROCK WORLD Champion
Diamond Axle
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
http://www.frontrangeoffroadfab.com
NEW BUILD FTOY #44
http://www.pirate4x4.com/forum/showthread.php?t=562295
Brian Ellinger is offline   Reply With Quote
Old 03-16-2005, 04:39 PM   #2
Brian Ellinger
Member # 1088
Also, we only do u-bolt in 7" and 7.5" lengths. We can have them custom made, but its typically better to have a shop local to you make the bolts, and we can ship just the plates out!
Diamond Axle
NEW BUILD FTOY #44
Old 03-16-2005, 05:36 PM   #3
Booger Weldz
chicken fucker
Booger Weldz's Avatar
Member # 2931
hey brian, i need an ifs toy REAR 'diamond' housing, no spring perches, an ARP hub and knuckle stud kit, and the ball reinforcements shipped to 95361. gimme a price and ill send you a money order imediately
http://www.davezoffroadperformance.com
http://www.12voltguy.com
http://www.addictedoffroad.com
2002 diamond axled coilover/linked tacoma 4door rock taxi
Booger Weldz is offline   Reply With Quote
Old 03-18-2005, 04:41 PM   #4
Booger Weldz
chicken fucker
Member # 2931
ttt
Old 03-25-2005, 02:03 PM   #5
Brian Ellinger
Member # 1088
Booger, everything but the housing was shipped monday as promised, you probably already have it all!
As for flips, still good in stock!
Diamond Axle
NEW BUILD FTOY #44
Old 01-14-2006, 05:43 AM   #6
ubbzy
Member # 36430
PM'd ya
94' GMC K1500 SAS'ified!
Front D60 HP
Rear D60 Locked
Alcans All Around
38 SSR's
High Angle Front Shaft
14" Bilsteins F&R
ubbzy is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
