Pirate4x4.Com Bulletin Board
Old 03-29-2005, 03:42 PM   #1
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
MOG High Steer Arms
We are proud to offer high steer arms for MOG 404 axles. They are fully welded when you recieve them. They are made from cnc laser cut plate from 1/2 inch to 5/16 inch thick. I personally have them on my rig. I am running a PSC double ended ram with them. Due to the nature of this part and all of the lawyers out there this part is for offroad use only... I am sure you understand.
I will post a picture of the arm assembly in a few minutes.
Thanks
Dan
Blue Torch FabWorks, Inc.
205-521-7333
http://www.bluetorchfab.com
MYSPACE
http://www.myspace.com/bluetorchfab
Superior Axle
www.superioraxle.com
BlueTorch is offline   Reply With Quote
Old 03-29-2005, 04:21 PM   #2
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
This is a 3d solid model of the part. i thought i had a pic of the part.
let me know if you have any questions
-Dan
205-521-7333
MYSPACE
Superior Axle
Old 04-03-2005, 01:42 AM   #3
Blazr77400
Blazr77400's Avatar
Member # 7228
That arm actually looks strong. Most of the arms built that way seem weak.
Could you lower the attachment point for people running the out of date leaf springs like me.
(I dont need any)(I just have yet to see anyone else make an arm thats worth using).
How much?
Good Job, all your products are top notch.
PICTURE LINK
84 K30 Crew Cab short bed
HP Tuned and Cammed LS 6.0, 4l80e
NP208 range box and divorce mounted 205,
Dana 60, 14 bolt, Hydrualic Assist
4 inch 52s, 3 inch 64s with 4" shackle flip
20x12 Forged Centerlines on 41x14.50 irok radials
Blazr77400 is offline   Reply With Quote
Old 04-06-2005, 09:56 AM   #4
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
How much?
you would loose some of the strenght in the arm lowering the mounting point. If someone was interested I would look into it in more detail.
Thanks for the idea.
Dan
205-521-7333
MYSPACE
Superior Axle
Old 04-12-2005, 10:04 AM   #5
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
ttt
205-521-7333
MYSPACE
Superior Axle
Old 04-12-2005, 05:28 PM   #6
orangefj45
orangefj45's Avatar
Member # 6816
how much for a set of 4?
looking for Advance Adapter parts? send me a pm!
orangefj45 is offline   Reply With Quote
Old 04-13-2005, 06:50 PM   #7
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
pm sent. let me know if you have any questions
Thanks
Dan
205-521-7333
MYSPACE
Superior Axle
Old 04-14-2005, 01:59 PM   #8
Blazr77400
Blazr77400's Avatar
Member # 7228
Dan
I think you could lower them some and still have, or even gain some strength. My reasoning is there is so much leverage at the top of the portal to turn the tires. It seams like the closer to the center of the wheel you are, the less stress you would put on the knuckles and the bolts holding the arm on.
PICTURE LINK
Old 04-15-2005, 09:43 AM   #9
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
the way that the arm is design in my opinion you will loose strenght by lowering the arm. The way we have the arm designed it transfers load to the rear of the portal box as well as the front. By lowering the arm you will be attaching the the portal box off of the front three bolts with some type of wrap around to brace it. The problem there is the leverage created from the short distance from the rod end to the front of the portal box. As we have it we have a longer leverage point to make the portal box turn. If you will notice we are not just turning from the top of the portal box. The arm wraps all the way around the box and transfer load to the lower section of the portal box. I agree if we only had it attaching to the top of the portal box it would create too much stress.
Dan
205-521-7333
MYSPACE
Superior Axle
Old 04-17-2005, 10:42 AM   #10
EnergyForce
Member # 25468
How much for a set of 2? - Washington State. energyforce@shaw.ca please. Thanks.
EnergyForce is offline   Reply With Quote
Old 04-17-2005, 02:47 PM   #11
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
pm sent
Thanks
Dan
205-521-7333
MYSPACE
Superior Axle
Old 04-24-2005, 06:33 PM   #12
Richard w
Member # 19795
D44 arm
need price for high steering arm pass side reamed for large chevy.
Oregon 97411 buisness.
Richard w is offline   Reply With Quote
Old 05-05-2005, 07:39 AM   #13
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
Sorry these arms only use rod ends in double shear. Sorry no tre's on these. Let me know if you think it will work for you.
Thanks
Dan
205-521-7333
MYSPACE
Superior Axle
Old 05-12-2005, 12:56 PM   #14
The Fleckster
Scout Maniac
The Fleckster's Avatar
Member # 3178
Please post prices in your ad so we know how much they are. Thanks
1 pair = $ ???
2 Pair = $???
The Fleckster
SUPPORT YOUR IH VENDORS, WE'RE HERE FOR YOU
Its not overbuilt, Its excessivley engineered
Back Country Binders 4x4 LLC.
.......Defy Ordinary!!........
ORDINARY IS LAME, SEEK OUT ADVENTURE!
The Fleckster is offline   Reply With Quote
Old 05-12-2005, 07:32 PM   #15
91blaze
Member # 21282
Yep how much? 2 pair?
91blaze is offline   Reply With Quote
Old 05-15-2005, 09:08 AM   #16
BlueTorch
Jason@Bluetorch
BlueTorch's Avatar
Member # 14529
Pm's sent
-Dan
205-521-7333
MYSPACE
Superior Axle
Old 11-18-2005, 10:53 AM   #17
jchio
jchio's Avatar
Member # 34
Send a message via MSN to jchio
Dan do you have these on stock??? pm me price and details please...
Jeeperos.com
Oh Ed!
jchio is offline   Reply With Quote
Old 11-18-2005, 12:57 PM   #18
Run dog
Run dog's Avatar
Member # 11365
How much for (2) sets?
OUR STABLE OF 4x4's
1) JIMMY's 4x4 KOH Racer
2) 2004 Land Rover DII (hers)
3) 2002 Dodge 2500 Diesel 4x4 (Tow Rig) (mine)
4) 2001 JEEP Grand Cherokee 42" IROKS/4-linked/Atlas (Mine)
5) 1985 FJ 60 landcruiser-Dana 60's, Atlas Ram Jet 350
6) 2005 Full supension BOB Stroller (twins)
Run dog is offline   Reply With Quote
Old 12-07-2005, 10:29 PM   #19
mountianlivin
Member # 43177
How much for 1 set? Thanks
mountianlivin is offline   Reply With Quote
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©1998 - 2009 Pirate Media Group
