Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Jeep - Hardcore Tech
Old 01-09-2006, 10:37 AM   #1
Jkrause
Member # 38620
Homebrew.... rear corners ???
Looking for advise and pictures on fabricating some hombrew'd rear cornerguards for a YJ...... what's the radius on the tub ??? anyone make these.......
Jeff
Jkrause is offline   Reply With Quote
Old 01-09-2006, 11:17 AM   #2
jeepNicK
Member # 7349
Send a message via AIM to jeepNicK Send a message via Yahoo to jeepNicK
do a quick search a guy did it not too long ago using a torch and clamping a piece of metal to his tub
93 yj on 35s
waiting on money to be done right
jeepNicK is offline   Reply With Quote
Old 01-09-2006, 12:12 PM   #3
Brian1
Brian1's Avatar
Member # 2205
Send a message via AIM to Brian1 Send a message via Yahoo to Brian1
That was probably me-
I made mine for my '42 Flatfender. I first made a cardboard template then plasma cut it out of a sheet of 1/8" diamond plate. Then I clamped it to my tub with c-clamps and vise-grips, leveled it to the tub then heated it with a torch to bend it around the tub. This did mess up the paint in the area but I didnt care since the tub was getting a new paintjob later on.
Finished, I used 1/4" buttonhead bolts to secure them to the tub:
Brian
Boogerwelds.com Southwest Rockcrawling
Brian1 is offline   Reply With Quote
Old 01-09-2006, 12:32 PM   #4
bigassedredjeep
Member # 38701
Send a message via AIM to bigassedredjeep Send a message via Yahoo to bigassedredjeep
i think ShellJeep did his corners this same way.
bigassedredjeep is offline   Reply With Quote
Old 01-09-2006, 01:16 PM   #5
erslll
erslll's Avatar
Member # 13518
I used a piece of 5" pipe tacked to the inside of my plate then used a press to bend the plate around the pipe.
73 CJ
erslll is offline   Reply With Quote
Old 01-09-2006, 02:35 PM   #6
rockr
Member # 8665
i used 1/8" diamond plate also cause that's what i had lying around but would recommend 3/16".
rockr is offline   Reply With Quote
Old 01-09-2006, 03:14 PM   #7
kpj
Ridge Runner
Member # 6920
I made mine on my CJ5 by going with the clamp/torch/weld method. Looked great when I was done.
kpj is offline   Reply With Quote
Old 01-09-2006, 07:23 PM   #8
CRO
Member # 7588
tub radius
the radius is the same as a ping pong paddle.
1948 Willys
1952 M37CDN Powag
CRO is offline   Reply With Quote
Old 01-10-2006, 05:36 AM   #9
Keithd2606
Member # 61648
why not just spend 100 bucks and buy some??
Keithd2606 is offline   Reply With Quote
Old 01-10-2006, 06:31 AM   #10
AmigoTJ44
Member # 34294
where are you getting 3/16 corners for $100
TJ stuff
AmigoTJ44 is offline   Reply With Quote
Old 01-10-2006, 06:47 AM   #11
Daltongp
Member # 32810
Send a message via AIM to Daltongp Send a message via Yahoo to Daltongp
Yeah, you're not going to find them for $100 and I bet he spent a lot less than that for some diamond plate and some button head bolts....
Daltongp is offline   Reply With Quote
Old 01-10-2006, 12:46 PM   #12
CB87YJ
Member # 14470
WORD
[COLOR="Yellow"][B]Crawl rocks instead of smokin 'em.[/B][/COLOR]
Rock Rated,4.0,Gears,Lift,Tires,Armor.
[COLOR="Silver"]Hardcore, Old-School and Sexy, TSL-SX[/COLOR]
[QUOTE=Steve N]Thread poster may be hardcore. Post is not. So this is in wrong section.[/QUOTE]
CB87YJ is offline   Reply With Quote
Old 01-11-2006, 05:46 AM   #13
Upper2
Member # 34061
On a TJ the radius is 3.25 inches.
Upper2 is offline   Reply With Quote
Old 01-11-2006, 06:14 AM   #14
guidolyons
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Because we like making our own stuff
1965 Scout 80 7.3PSD/ZF/203/205
Originally Posted by General Dwight D. Eisenhower
History does not long entrust the care of freedom to the weak or the timid.
David H. Petraeus for President 2012
guidolyons is online now   Reply With Quote
Old 01-11-2006, 04:38 PM   #15
rockr
Member # 8665
BTW........... this AIN'T hardcore
Old 01-12-2006, 06:05 AM   #16
chumly2071
chumly2071's Avatar
Member # 8293
Send a message via AIM to chumly2071 Send a message via Yahoo to chumly2071
no, it isn't super hardcore, but it's interesting to see other people's home fabbed versions with their method of bending, and to document the radius for the search function.
I'm an Engineer. Why leave it alone, when I can REALLY screw it up?
There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance.
chumly2071 is offline   Reply With Quote
Forum Jump
