Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Approved Vendor's Marketplace > Axles/Tires/Wheels
Old 01-13-2006, 08:30 PM   #1
MUCHADO
MUCHADO's Avatar
Member # 21752
Send a message via AIM to MUCHADO
TOYOTA brake upgrade (disc & 1 ton master conv.)
$145 shipped within continental US.
**EDIT: the R&D was done for Toyota Mini trucks, but the booster adapter should work on FJ's and other that have the same mounting pattern. I am not sure about the disc brackets on an FJ though.
These are parts you need to do your very own Toyota brake upgrade. We supply the brackets and THAT'S IT!
This is a no-nonsense kit that allows you to use parts you either have around the shop or can find for cheap elseware. It saves you money for us not to ship heavy brake parts. Our kit is designed to use stock front calipers from your toyota. The calipers will bolt mate up directly onto the factory hard-line. You will use toyota rotors and they can either be ground down aproximatly 1/16" or machined in order for the axle to rest flush against the rotor. You will need to purchase longer studs also. The master cylinder adapter plate is for a chevy 1-ton master cylinder.
Benefits of our kit versus the ones that use chevy calipers:
* 4 piston calipers VS the 1 piston that the chevies have
* solid mount VS the floating mount style that the chevies have
* uses toyota parts
* no custom brake lines needed - mounts right up to factory
* caliper bracket uses stock bolts to flange
* master cylinder used is much cheaper and works better than the FJ80 upgrade others offer
This combo results in strong, predictable braking.
Here are some pictures of them installed on TECHTAFAB's rig:
disc brackets:
1-ton master adapter
$12 Off-Road DVD's
MUCHADO is offline   Reply With Quote
Old 01-15-2006, 09:29 PM   #2
blacktoy
blacktoy's Avatar
Member # 22837
How much just for the caliper brackets?
highvibesoffroad.com
blacktoy is offline   Reply With Quote
Old 01-16-2006, 04:01 AM   #3
MUCHADO
MUCHADO's Avatar
Member # 21752
PM sent
$12 Off-Road DVD's
Old 01-16-2006, 09:39 AM   #4
91blaze
Member # 21282
do the factory lines go into the MC? or what adapter is used? got a part # by chance?
91blaze is offline   Reply With Quote
Old 01-16-2006, 07:38 PM   #5
Hendo
Hendo's Avatar
Member # 20295
Send a message via MSN to Hendo
i have a 76 fj40, how much for the adapter plate and break line adapters ,also the master ,if you have em
Hendo is offline   Reply With Quote
Old 01-16-2006, 10:41 PM   #6
MUCHADO
MUCHADO's Avatar
Member # 21752
You will need to either cut off the end and put a new nut on and re-flare since the MC is not metric, or you can use an adapter. I am not sure what nuts are used on the line. I would bring the MC into the parts store to make sure you get the right one.
Originally Posted by Hendo
i have a 76 fj40, how much for the adapter plate and break line adapters if you have em
Right now we're only doing the mini trucks, we don't have a jig set up for the FJ40's yet. Sorry.
$12 Off-Road DVD's
Old 01-17-2006, 10:16 PM   #7
uda
Member # 34713
master cyl. bracket, price?Pm me back.
uda is offline   Reply With Quote
Old 01-18-2006, 11:05 AM   #8
jeaton
Member # 26098
Send a message via Yahoo to jeaton
price on the disk brackets to 99336
82 long box 115" wheel base 4.3, th 350, dual case, longs, e-locked, 42 irocs, full cooler of frosty adult beverages for wheeling!
jeaton is online now   Reply With Quote
Old 01-18-2006, 01:36 PM   #9
MUCHADO
MUCHADO's Avatar
Member # 21752
PM's sent
$12 Off-Road DVD's
Old 01-22-2006, 08:24 PM   #10
LCOwner
Member # 181
Ditto
If you’re not part of an organized volunteer group working on the trails, YOU are the problem.
LCOwner is offline   Reply With Quote
Old 02-09-2006, 06:54 AM   #11
toywelder
toyed up
toywelder's Avatar
Member # 38130
bump
toywelder is offline   Reply With Quote
Old 02-09-2006, 09:21 PM   #12
2stroke
Lawn Boy
2stroke's Avatar
Member # 8981
price on master bracket? please.
2stroke is offline   Reply With Quote
Old 02-11-2006, 11:00 AM   #13
MUCHADO
MUCHADO's Avatar
Member # 21752
PM's sent.
Thanks for all the orders
$12 Off-Road DVD's
Old 02-17-2006, 01:33 PM   #14
toywelder
toyed up
toywelder's Avatar
Member # 38130
bump for ya
Old 02-21-2006, 05:40 PM   #15
cheaprides
junkyard recycler
cheaprides's Avatar
Member # 40933
Send a message via AIM to cheaprides Send a message via Yahoo to cheaprides
i wanted to build this myself but i tried to use 88 4x4 ifs rotors. they bolt to the, hub? well anyway they are not the same as a chevy rotor and dont carry the studs. so they wont just slide on due to the different bolt pattern (rotor is 6 bolt but is smaller bolt circle).
i would like see more pics
if im wrong correct me but this is what i remember seeing
84 toyota on junkyard 31s and dual cases. still building
cheaprides is offline   Reply With Quote
Old 02-22-2006, 07:59 AM   #16
toywelder
toyed up
toywelder's Avatar
Member # 38130
ok i realy dont understand your ??
are u saying the bolt holes are to small ??
or the 6 lug pat. is wrong ??
if its the bolt holes are to small just Drill them out !!!!
and if its the 6 lug well 6 lugs should be all the same (i think)
or do u mean the ID of the rotor is to small ? just open it up!!
did that help ????
Old 02-22-2006, 08:24 AM   #17
MUCHADO
MUCHADO's Avatar
Member # 21752
Did you grind out or have the center turned? The hole on the inside is too small from the factory if that is what you mean. You need to have 1/8 turned out of the ID of the rotor.
This weekend we're doin an install on a friend's truck and I will have a full writeup. I've never done this with IFS rotors but have been told by customers that it will work. If you are talking about the bolt pattern for the hub/wheel that won't match up, then I am confused as to why that is. They should mate up perfectly since the wheels for all 6-lug toyotas all mate up regardless whether they are IFS or not.
I will keep you posted in this thread with a link to the install. Thanks for bringing up the question. But like it has been said before, these were designed for use with the solid axle rotors and calipers-anything else you wanna try them on is fine, but I'm not going to guarantee that they work as we have not first hand tried to install them with these parts.
$12 Off-Road DVD's
Old 02-24-2006, 03:34 PM   #18
kbud
Member # 3374
You've got a pm.
kbud is offline   Reply With Quote
Old 03-02-2006, 12:24 PM   #19
MUCHADO
MUCHADO's Avatar
Member # 21752
I will be doing a writeup on this since my inbox has been flooded with detailed questions about the install. I took pics last Sunday and will have time to sit down and do an in-depth writeup this weekend. Thanks for all the inquirys!
$12 Off-Road DVD's
Old 03-05-2006, 01:52 AM   #20
dakotaparts.com
Member # 56125
price to 97527, cliper hangers only, running yota's in a sami so m/c wont work
dakotaparts.com is offline   Reply With Quote
Old 03-11-2006, 12:10 AM   #21
MUCHADO
MUCHADO's Avatar
Member # 21752
http://www.pirate4x4.com/forum/showthread.php?t=452546
Did a writeup on the install to help you guys out a bit if you haven't done disks on a yota before.
$12 Off-Road DVD's
Old 03-11-2006, 12:37 AM   #22
82yotacrawler
82yotacrawler's Avatar
Member # 26872
price on brackets shipped to 95757
85 ex cab injected...
sittin on 60s and an empty wallet...
82yotacrawler is offline   Reply With Quote
Old 03-11-2006, 01:48 AM   #23
MUCHADO
MUCHADO's Avatar
Member # 21752
http://www.muchadoproductions.com/parts.html
for pricing and ordering
Caliper brackets $95 shipped
M/C Adapter $50 shipped
Package $145 shipped
$12 Off-Road DVD's
Old 03-13-2006, 08:46 AM   #24
toycrf
Member # 52182
do you know if these bracket/kit will work on a tacoma? if so would I still need to upgrade my M/C? I know the taco M/C is bigger then the older mini's but ....
toycrf is offline   Reply With Quote
Old 03-13-2006, 01:59 PM   #25
MUCHADO
MUCHADO's Avatar
Member # 21752
Honestly I can't answer that question. I've got a friend with a Taco and may be able to link up with him late next week. I'll PM you when I find out a definite answer for you!
-Rob
$12 Off-Road DVD's
Forum Jump
