Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > General Tech > General 4x4 Discussion
Old 02-01-2006, 01:51 PM   #1
RSWORDS
RSWORDS's Avatar
Member # 49595
My Tauras Fan wiring Diagram
Picked up my fan today for $35... Gonna go find som 80 amp relays tonight... Here is how I am planing on wiring it.... What you think?
The way it should work is it should come on at a pre-set temp... unless I over ride it by switching it off or over to High...
RSWORDS is offline   Reply With Quote
Old 02-01-2006, 02:08 PM   #2
RSWORDS
RSWORDS's Avatar
Member # 49595
Thinking of using this relay...
http://www.oznium.com/relay80
Old 02-01-2006, 03:38 PM   #3
1998chevy1500
Member # 38330
http://www.offroad-tech.com/forum/showthread.php?t=2224
Hope that this helps a little
1998chevy1500 is offline   Reply With Quote
Old 02-01-2006, 03:45 PM   #4
rustynuts
Hello Govna
rustynuts's Avatar
Member # 28812
looks good. i need to do the same.
Custom Fiberglass CJ, TJ And X Chassis Hoods Now Available
YJ, JK And FJ40 Hoods Coming Soon
RustynutsFab.com
X-Chassis 007 LS1 42's 4 Wheel Steer HP60's
rustynuts is offline   Reply With Quote
Old 02-01-2006, 08:01 PM   #5
RSWORDS
RSWORDS's Avatar
Member # 49595
I'm thinking of doing a real detailed write-up on it... seems like a whole lot of info on the board about it but nothing that is a step by step walk through... I'll most likly put it in the newbie section...
Old 02-01-2006, 09:02 PM   #6
Evilwhitey
Member # 64230
Send a message via MSN to Evilwhitey
I was just thinking about putting a taurus fan on my yota but haven't got a clue of how to do it. Please do a nice detailed write up on it for all of us stupid newbies that don't know the 1st thing about wiring. Thanks!
Evilwhitey is online now   Reply With Quote
Old 02-01-2006, 10:21 PM   #7
JeepinDoug
JeepinDoug's Avatar
Member # 13028
Looks fine to me, the only thing I would change is your ACC switched power. Run it on 12v continuous, that way if you need to shut down the fan can keep coooling. If you don't want it to run, you over-ride it with the master kill switch.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 02-02-2006, 07:16 AM   #8
RSWORDS
RSWORDS's Avatar
Member # 49595
Well here are my thought's behind that...
  • How often do you NEED to run the fan with the engine off? W/O water flow from a water pump it won't help alot to cool off the engine...
  • How many times would I (because I'm forgetfull as shit) leave the fan on and drain the battery
  • or worse how many times would I (again because I'm forgetfull as shit) forget to trn the fan on and roast the engine
  • I let others drive my truck... The less switches they have to flip the better I feel
  • If I need to run the fan with the truck off all I have to do is tuirn the key on
I was thinking of up-dating my design to be more like this... with the On-Off switch protected so that you can't "accidentaly" turn it off...
Old 02-02-2006, 09:56 AM   #9
RSWORDS
RSWORDS's Avatar
Member # 49595
Started getting the parts together...
Here is the fan... $35 from the junk yard... They pulled it for me.
And a universal temp controled switch from autozone... PN 226203... $18.89 after tax
Just need to figure out which wire goes where on the switch... No instructions with it.
Old 02-02-2006, 10:22 AM   #10
demonranger
Member # 18283
for a cheap relay that will work rather well get the glow plug relay for a 96 F350 7.3L Diesel.
They are in every parts store look roughly like a starter relay but are intended for a longer use and ground through one of the studs as opposed to many of the starter relays that ground through backing plate.
There are no rules. You have to think!
demonranger is offline   Reply With Quote
Old 02-02-2006, 10:22 AM   #11
zx11kllr
zx11kllr's Avatar
Member # 62912
How big is that fan. I am using a setup out of a mustang. It is a two fan system and it sure pulls a lot of air. Unless you just want to spend the money on a blingy relay you can buy an early model Ford starter solenoid. They are pretty much the same thing.
Here's my setup:
zx11kllr is offline   Reply With Quote
Old 02-02-2006, 10:25 AM   #12
RSWORDS
RSWORDS's Avatar
Member # 49595
The relay above is $17 and rated for 100% duty cycle...
Old 02-02-2006, 11:02 AM   #13
RSWORDS
RSWORDS's Avatar
Member # 49595
Just got the override switch... Found it in the ricer section of AutoZone for $10... The only problem with these kind of switches is that when the protective cover is dow (protecting) the switch is off... well I need it on 99.9% of the time so I had to reverse it... easy enough just pull off the cover and flip it around... now when the cover is down protecting the switch my fan will be on...
Old 02-02-2006, 11:28 AM   #14
Urban Wheeler
Early Cuyler
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
The only thing wrong with it is that when you flip it to high the low side will still be powered. From what I gather on the board here, it makes the motor fight itself trying to run on both high and low at the same time.
Fan link
"Kent, you know you're not allowed to park that on campus."
Urban Wheeler is offline   Reply With Quote
Old 02-02-2006, 12:02 PM   #15
ironpig70
ironpig70's Avatar
Member # 6957
also these fans take alot of amps to start up like in the 60-70 amp range. and they spin at 2000rpms and they make 4-5 differnt sized 2 speed taurus fans iirc and this one should be around 22 1/2" wide 16" long and 4" thick shroud and 5" to the top of the motor. most are close to this but some have a notch like this / in the lower right corner. thats how mine is but its so small don't think it will hurt.
ironpig70 is offline   Reply With Quote
Old 02-02-2006, 12:24 PM   #16
RSWORDS
RSWORDS's Avatar
Member # 49595
Fan link
I looked my diagrams over thinking I had drawn something wrong but I don'r see how it would power both... The low speed is only on The Auto setting... when the switch is thrown over to High all the power is removed from the low side of the switch... Unless I am missing something...
Old 02-02-2006, 12:26 PM   #17
RSWORDS
RSWORDS's Avatar
Member # 49595
hense the 80 amp relay in the 2nd post...
Old 02-08-2006, 04:42 PM   #18
plug ugly
Member # 16680
couldnt you just get a adjustable controller and run it off your temp sender you probably already have?
94 Mall Rated Bronco
wt4x4.com
PM me for CPR/First Aid Instruction for you club
plug ugly is offline   Reply With Quote
Old 02-10-2006, 10:26 AM   #19
RSWORDS
RSWORDS's Avatar
Member # 49595
I could... I looked at this {url}http://www.dccontrol.com/index.htm[/url]
but I found some high amp relays for free... and Have all the things I need to do this now. My dad is the service manager at a marina here and he snaged some relays off of a power trim and tilt unit that they replaced in a repower job... HE said that it was working fine when it came off a week ago... I got the whole unit including the electric-hydrolic pump... I'm keeping the pump in my shed to see what he flow rate and Pressures are so it can maybe be retrofitted to some sort of rear steer...
Old 02-10-2006, 10:36 AM   #20
ItsaCJ6
ItsaCJ6's Avatar
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
Something I have toyed with, but never set up is a water level (Jeep in creek water level) shut off for the fan. Something like this could be mounted below the fan near the bottom of the radiator. You would use a relay that is set for {normaly closed on open contacts}. When water shorts your senosr (say two wires close together) it opens your {normaly closed contacts on close} and shuts down your fan. This would elimiate the need for a manual fan switch for creek crossings deep enough to get water up to the fan. Or a small float switch could be mounted under the radiator the same way.
Marc
Originally Posted by JoshTurner View Post
Ill go MUDDING with you
Super conversion calculator website
Maynard the Whore the Pimp the God.
"When the going gets weird, the weird turn pro."
-Hunter S. Thompson
"I wouldn't recommend sex, drugs or insanity for everyone, but they've always worked for me."
-Hunter S. Thompson
ItsaCJ6 is offline   Reply With Quote
Old 02-25-2006, 05:49 PM   #21
resqme
Member # 21815
I know this fan controller is pricey, but a very trick way to control your electric fan. THought you might be interested.
WWDD?
N6YBH
"If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford
Use Goodsearch and support the Rubicon Trail Foundation.
resqme is offline   Reply With Quote
Old 02-25-2006, 07:07 PM   #22
plug ugly
Member # 16680
any idea what kinda amps it can handle?
wt4x4.com
Old 02-25-2006, 07:28 PM   #23
resqme
Member # 21815
Nope, but that would be important, wouldn't it? I am using one of their tach signal interface modules to set my VSS pulses so the computer likes it...works very well, and their support was excellent.
WWDD?
N6YBH
Old 02-27-2006, 12:22 AM   #24
Murfman
Member # 11973
Send a message via ICQ to Murfman Send a message via Yahoo to Murfman
I did the Tarus fan last winter in my YJ. Works great. I discovered that driving down the road, I don't even need the fan on. I run it on low most times and only once, while wheeling a long slow uphill, did it get even close to overheating. I will hook up another relay on the high side so I won't have to worry about those long uphills. This is all switched through a 3 way switch on the dash.
Only in a Jeep
Murfman is offline   Reply With Quote
Old 03-03-2006, 11:05 AM   #25
plug ugly
Member # 16680
for anyone else, I emailed them and here is their response.
Hello,
The pac-2000 will only control relays and the limits or relay
dependant. If you have a 30amp relay the max is 30amps at 14.4 volts.
Thanks for your interest in Dakota Digital products.
Dakota Digital Inc. 1-800 852-6513
Techsupport@dakotadigital.com
Jared VerBeek
Electronic Technician
wt4x4.com
Forum Jump
