#1 |
Pirate4x4 Addict!
Member # 30
Location: Roseville, CA,To many Yuppies, Not enough Hippies
Hi-amp alternator for 3.0 V-6
I have been thinking about installing a Hi-Amp alternator for a few years now. A couple of years ago I added a second battery and moved them to the back underneath the flatbed. With all the accessories I have added over the years the stock Toyota 60-amp alternator had a hard time keeping up, especially when night wheeling. The thing that stopped me was I know little about electrics, and all I had seen in my research was high-dollar alternators A couple weeks ago, Erik B said something about it, and he was going to research it. He came up with the solution, a Powermaster alternator for GM vehicles (figure 1) from Summit Racing. I asked Erik to help me wire it .He said no problem. The alternator that I bought was a Powermaster #47802 that puts out 80 amps at idle and 160 amps at highway speeds (figure 2). The install of this unit on the 3.0 is almost bolt in. I had to do some minor mods to the stock tensioning bracket (figure 3-4) and to the stock Toyota mount bracket (figure 5) and I bought a belt that was about one inch longer. The wiring had me stumped; Erik came over with a paper with how to wire it up. I did not take any pictures of the wiring. I went to NAPA, bought a pigtail for the alternator and misc. wire ends then to a stereo shop, and bought fifteen feet of number 4-gage thumper wire. The GM unit has 4-pins while the Toyota plug only has three. The GM pig-tail wires are stator-brown (not used), gray-alt. light (next to brown) goes to yellow on the Toyota plug, 2nd gray-ignition goes to red on the Toyota plug, and red-sense goes to white on the Toyota plug. The Toyota plug has female spade connectors so I crimped male spade connectors and color-coded the pigtail wires as to which place it went in the Toyota plug. The charging wire (4-gage) I ran to a Bussman hi-amp fuse holder (figure 7) with a 175-amp fuse. From there I ran the 4-gage wire back to the dual battery solenoid set-up (figure 8) and hooked it up per instructions from Painless wiring. Figures 9-10 are the finished product. I started it up today and it is putting out 13.9 volts at the battery and if I knew how to use my meter to test amps I would see what amps it is putting out at idle. Anything has to be better then what the stock one was putting out. Here is another thread about doing the same thing but a little different. http://pirate4x4.com/forum/showthrea...hreadid=207958 List of parts: Alternator-Summit Racing –PN # 47802 http://www.summitracing.com/ GM pigtail PN 385118 – NAPA Hi-amp fuse and holder – Waytek Wire - http://www.waytekwire.com/index.htm Dual Battery set-up – Painless Wiring - http://www.painlesswiring.com/ 250-AMP DUAL BATTERY CURRENT CONTROL SYSTEMS #40103 - 250 Amp Weatherproof Dual Battery controller 12-Volt Guy also has these but was not around when I put my dual batteries in - http://www.12voltguy.com/ Support PBB Vendors Misc. wire and connectors. ![]() ![]() ![]() ![]()
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ Last edited by OOP'S; 04-05-2009 at 08:46 PM. |
#2 |
Pirate4x4 Addict!
Member # 30
The rest of the pictures
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ Last edited by OOP'S; 04-05-2009 at 08:52 PM. |
| Sponsored Links |
#3 |
Member # 39727
I was thinking about the gm alternator one or the MR2 one http://www.off-road.com/toyota/tech/100alt/index.html
Can't Duct it, Fuct it! |
#4 |
MASTER OF NONE
Member # 42148
3.0
Hey OOP'S, Its good to see other folks running a 3.0. I hear lots of people bagging on them, and it makes me feel bad about mine. Whats your take on the motor? Mine runs fine! 22500 on an '88!
#5 |
Member # 2093
Cool David, now I know who to call when its time to upgrade mine.
89 4runner with lots of goodies. |
#6 |
Cranky B.F.U.M. Mod
Nice David, I'll get the info in the FAQ. Would the one you bought also work on a 22R/RE?
85 Toy Xtracab "I DON'T want to understand !!" Click here to donate to the Rubicon Trail Foundation Rubicon Trail Foundation Rubicon Trail Patrol Rock-N-Roll 4X4 Club "Wow this is unbelievable" |
#7 | |
Pirate4x4 Addict!
Member # 30
David & Theresa, Roseville, CA, Excellent Parts Source http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/web/ |
#8 | |
Cranky B.F.U.M. Mod
I also have a bone stock '88 DD, did have to do the HG's, at 148K, has 160k now, and runs fine. I like mine, runs great.
#9 | ||
Pirate4x4 Addict!
Member # 30
They have them chromed to go with the rest of your "BLING, BLING"!!!!!!!!!!!!!!!!!!!!!!!! No problem Ryan, if we can ever get together, got the Monster Valves installed yet!!!!!!!!!!Quote:
#10 |
Grocery Getter
Member # 59
Basically we copied this writeup, but I had to do a little research to figure out which alternator to buy from Powermaster.
http://pirate4x4.com/forum/showthrea...hreadid=207958 And here is a little improvement to the wiring diagram in that writeup: |
#11 | |
Grocery Getter
Member # 59
http://www.pirate4x4.com/forum/showthread.php?t=451359 ![]() I was playing with it last night w/ the rock lights and it works awesome.
#12 |
Cranky B.F.U.M. Mod
Thanks Erik, it's definitely on my list as a must do. If your not busy tonight we are having our club meeting at BJ's in Folsom, come by! 6-6:30ish
#13 |
Grocery Getter
Member # 59
I was just thinking last night that today was going to be the last Tuesday and I was going to check your guys site for the meeting! I'll try to bring the red runner this time too.
#14 |
Grocery Getter
Member # 59
This alternator bolts right onto a 3.4L V6. NO bracket mods needed, just a 1/4" spacer behind the alternator. The wiring is the same too.
I spliced in both connectors so I can use my old alt as a spare or whatever. |
#15 |
Member # 2798
the only issue you might have is the gm alt falure rate is alot higher then the nippindenso units. although power master and mean green do use high quaility parts in there products, my buddy uses them in his high end car audio installs. also, why not just use the cs144 out of the buick??? im not sure if the idle amp output is as high in the stock unit?? and you need to make room for the welder!!!!!!!! ill make you another one??
cliff
go marlin and dont support the china. dont trust unhonest vendors that lie to you and play games |
#16 |
Member # 37026
awesome. thanks for this thread. when the time comes im sure ill be doing this to my truck.
ECV 7-11 RIP troy & daniel, KYOTA Forever. |
| Thread Tools | |
| Display Modes | |
