Pirate4x4.Com Bulletin Board
Go Back   Pirate4x4.Com Bulletin Board > Brand Specific Tech > Toyota - Truck and 4Runner
Old 04-24-2006, 01:10 PM   #1
desertoy
desertoy's Avatar
Member # 292
Bobby Longs Axle Breaking Machine Results
Hope that everyone at the Jamboree liked the axle breaking demonstration. I really liked it and was really supprised at some of the results.
Here they are:
PRODUCT / ................................................. FT.LB. TORQUE/.... % TWIST
Yukon 4340 Dana 60 35 spline short side axle.........12,000 ..................130
Stock Dana 60 35 spline short side axle .................6,500 ....................35
Yukon 4340 Dana 44 30 spline short side axle ..........5,800 ...................35
Stock dana 44 30 spline........................................5,00 0.....................35
Yukon 4340 Birfield Eliminator kit (ear failure)............5,500......................50
Longfield 4340 30 spline (shaft failure)......................8,500............... ......175
Longfield 4340 27 spline........................................6,50 0.....................75
Stock Toyota Birfield.......................................... ..4,200 .....................45
Stock Toyota Inner Axle.......................................5,000 .....................45
All Pro "Profield"........................................ .......... 3,500 ....................30
Stock toyota Transfer Case Output Shaft.................2,500 ....................65
Longfield treated Transfer case output shaft.............2,500.....................20
Longfield 4340 Transfer Case Output Shaft...............4,000......................25
All Pro Transfer Case Output Shaft..........................2,500 ......................60
Marlin "treated" Transfer Case Output Shaft..............2,500 ......................10
Stock Toyota Hub............................................... .5,800/
Longfield Treated Toy Hub ....................................6,800/
Stock Toyota Flange............................................ .6,000/
Longfield 4340 Flange............................................ Didn't test
John James
Team Marlin Crawler
Formula Toy #028
FOA Shocks
12voltguy.com
High Desert Driveline
Mobile Radio Communications
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup http://www.pirate4x4.com/forum/showthread.php?t=298203
desertoy is offline   Reply With Quote
Old 04-24-2006, 01:20 PM   #2
4RnrRick
Banned
4RnrRick's Avatar
Member # 3933
Its a little easier to read if you use courier font and the correct spacing using 'black' text.
PRODUCT ................................ FT.LB. TORQUE / DEGREE TWIST
Yukon 4340 Dana 60 35 spline short side axle ...12,000 / 130
Stock Dana 60 35 spline short side axle .........6,500 / 35
Yukon 4340 Dana 44 30 spline short side axle ....5,800 / 35
Stock dana 44 30 spline .........................5,000 / 35
Yukon 4340 Birfield Eliminator kit (ear failure) 5,500 / 50
Longfield 4340 30 spline (shaft failure) ........8,500 / 175
Longfield 4340 27 spline ........................6,500 / 75
Stock Toyota Birfield ...........................4,200 / 45
Stock Toyota Inner Axle .........................5,000 / 45
All Pro "Profield" ..............................3,500 / 30
Stock toyota Transfer Case Output Shaft .........2,500 / 65
Longfield treated Transfer case output shaft ....2,500 / 20
Longfield 4340 Transfer Case Output Shaft .......4,000 / 25
All Pro Transfer Case Output Shaft ..............2,500 / 60
Marlin "treated" Transfer Case Output Shaft .....2,500 / 10
Stock Toyota Hub ................................5,800/
Longfield Treated Toy Hub .......................6,800/
Stock Toyota Flange .............................6,000/
Longfield 4340 Flange ...........................Didn't test
But it was already posted here...
http://www.pirate4x4.com/forum/showt...39#post5382339
And here...
http://www.pirate4x4.com/forum/showt...19#post5383119
4RnrRick is offline   Reply With Quote
Old 04-24-2006, 01:29 PM   #3
CTENG
Member # 30371
Any theories why the d60 chromo shaft is nearly 2x the strength of the stocker while the d44 chromo only has the stock shaft by about 800lb-ft??? Possible flaw in the material? Just the shear magnitude of material in the d60 shaft as compared to the 44?
CTENG is offline   Reply With Quote
Old 04-24-2006, 03:53 PM   #4
extremetoy
Member # 21887
Send a message via AIM to extremetoy
the flange was tested but the bolts broke at 6500 ft lbs
Sit down lawn mower
extremetoy is offline   Reply With Quote
Old 04-24-2006, 05:17 PM   #5
yotacowboy
Member # 14627
[QUOTE=4RnrRick]
interesting to say the least...
[QUOTE=Jeepguy74]As a newbie here, I must say..... you guys have some of the bestest topics! I think i'll stick around:D[/QUOTE]
yotacowboy is offline   Reply With Quote
Old 04-24-2006, 05:46 PM   #6
High5
High5's Avatar
Member # 1700
were all of the shafts new or were some used? just curious
High5
IT'S 1TON O' FUN!
High5 is offline   Reply With Quote
Old 04-24-2006, 05:57 PM   #7
DarkEternal
Member # 23853
Send a message via AIM to DarkEternal
makes me feel good about my yukon d60 shafts!
DarkEternal is offline   Reply With Quote
Old 04-24-2006, 06:10 PM   #8
Max Volume
Member # 19077
I was there when the profield broke. Nobody was suprized.
Max Volume is offline   Reply With Quote
Old 04-24-2006, 06:15 PM   #9
Evilwhitey
Member # 64230
Send a message via MSN to Evilwhitey
I guess I'll pick up some longfields and have him treat my hubs but forget about the output. Anyone know if bobby has plan to test gears? I'd love to see the difference between 4.10's and 5.29's both with and without cryo. They should even throw a set of 5.71's in there just for fun to prove that whole debate once and for all. I know that the set-up would effect the strength but just have one of the best out there set up each diff to minimize the effects.
Evilwhitey is online now   Reply With Quote
Old 04-24-2006, 06:22 PM   #10
extremetoy
Member # 21887
some of the output shafts were used and the 30 spline longfields had been used for a year
Sit down lawn mower
Old 04-24-2006, 06:26 PM   #11
Jason M
Member # 5286
Send a message via Yahoo to Jason M
Yeah, That dam china Crap sure does suck
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 05-01-2006, 12:13 PM   #12
Chass
Member # 37212
One theory is that the only chromo shafts tested where Yukons . . . I'll let that speak for itself.
I have been running the shit out of my Alloy USA D44 chromo shafts and havn't had a problem. I winched/drove out of Sun Bonnet in front wheel drive on Saturday putting quite a beating on those suckers with no problems. The mud and roots around here didn't pose any problems either. I know that whats in my truck is WAY strong than the stock shafts I have broken.
Chass
ct
Blue Ribbon Coalition Member
Pacific Northwest 4x4 Assoction Member
JV Ralley post
Tellico Ralley post
My pipe EXO flop video [URL="http://www.harryritchies.com/ct/ChassFlopVideo.wmv"]here[/URL] [URL="http://www.pirate4x4.com/forum/showthread.php?t=342992&highlight=sprinkler+pipe+exo"]Build up thread.[/URL]
[URL="http://www.pirate4x4.com/forum/showthread.php?t=520463"]I speared my truck . . . REALLY![/URL]
[url]www.ot4x4.org[/url]
Chass is offline   Reply With Quote
Old 10-18-2006, 09:10 PM   #13
uselessdub
uselessdub's Avatar
Member # 24536
Before fj80 front axles blow up, i am curious to know what their birfs break at, I already ordered bobbies inners and birfs for mine....
ballpark?
uselessdub is offline   Reply With Quote
Old 10-19-2006, 07:39 AM   #14
Longfield
Longfield's Avatar
Member # 15061
Rick
When we tested the flanges at the jambo. we used 5/16 bolts i guess they were to small. When we retested the 4340 drive flange we used 3/8 grade bolts because they will fit in the holes without the cone washer. I don't think the drive flange will ever fail the shaft will break first. Iam thinking maybe not a good idea for us to build parts stronger than our shafts.
MADE IN THE USA!
WWW.LONGFIELDSUPERAXLES.COM
ORDER LINE TERRA 360-893-0235
24 HOUR TECH LINE 253-847-8254
FREE SHIPPING!
World's Best Customer Service & 24 Hour Tech Line!
Longfield is offline   Reply With Quote
Old 10-19-2006, 09:22 AM   #15
CRAPTACULAR
Member # 34477
[QUOTE=yotacowboy]
Is that machine not set up to do rear axles?
What about CVs?
Bobby, if I sent you a rear axle and cv could/would you break them? I am curious to see some stock numbers for different trucks.
CRAPTACULAR is offline   Reply With Quote
Old 10-19-2006, 04:10 PM   #16
Gawker
Member # 25635
Toyota Rear Axle Shaft, Stock............6,500.....110
Toyota Rear Axle Shaft, Superior 4340....7,600.....160
Toyota Rear Axle Shaft, PIG 4340.........?,???......??
Gawker is offline   Reply With Quote
Old 10-19-2006, 05:15 PM   #17
leorn
Member # 33208
Bobby could settle a lot of debates! I would like to see the 9" and other rear axles. Any teasers of what to expect next bobby?
I need toyota 8" V6 spider gears
leorn is offline   Reply With Quote
Old 10-26-2006, 10:43 AM   #18
Jeffh555
Jeffh555's Avatar
Member # 3775
Here I go, bringin an old thread to the top.
So I'm curious how this machine works, obviously you are applying a torsion load to one end of the shaft and hold the other in place.
How are you developing torques of 12000 ft-lb?
How is the shaft held to the testing machine? especially D44/D60 stuff, are you just connecting two stub shafts with a u-joint in the middle?
Maybe it's been discussed, and I suck at searching, but didn't come up with anything.
1995 S10 SAS/V8
2001 CBR929RR Streetfighter
1999 E250 Van (soon to be 4wd)
Jeffh555 is offline   Reply With Quote
Old 10-29-2006, 05:31 PM   #19
Longfield
Longfield's Avatar
Member # 15061
No, that's ok. Good question. The machine has a hydraulic cylinder, one end is attached to the frame and the other end is fixed to a double 80 chain. When the cylinder pushes out it turns a big sprocket that is fixed to the frame by a shaft and 2 bearings. One end of the axle is fixed to the table of the machine. The other end of the axle is hooked to the sprocket that turns as the cylinder pushes outward. We use side gears welded to a fixture at both ends of the axles. As far as foot pounds we take the hydraulic PSI pressure times the diameter of the cylinder times the sproket diameter and then divide the sprocket in half, that will give you the foot pounds of torque. After we built the machine we took it to a local hydrolic place, they converted PSI pressure to foot pounds of torque for us. We also had the engineers of the company that builds our shafts double check their calculations.
MADE IN THE USA!
FREE SHIPPING!
Old 10-29-2006, 05:38 PM   #20
Longfield
Longfield's Avatar
Member # 15061
We use to test the shafts by using a u-joint and an outer stub shaft and inner shaft combination. But it got to expensive and sometimes the joint would break and not the shafts. So now as you can see we just use 1 shaft with a pin thru the ears. Of course this is only straight not turned at an angle like the birfield.
MADE IN THE USA!
FREE SHIPPING!
Old 10-29-2006, 05:41 PM   #21
Longfield
Longfield's Avatar
Member # 15061
This is the way we test our birf and axle combination. Of course when we break them we put down the 1 1/4 bullet proof glass shield.
MADE IN THE USA!
FREE SHIPPING!
Old 10-29-2006, 05:43 PM   #22
Longfield
Longfield's Avatar
Member # 15061
One gage shows the foot pounds of torque and the other gage shows the twist degrees as the axle twists before it breaks. Hope this helps.
MADE IN THE USA!
FREE SHIPPING!
Old 10-29-2006, 09:02 PM   #23
fj40charles
Member # 1926
Good info.... Too bad you don't have any info on Superior Axle and Alloy USA 35 spline CrMo for Dana 60 axles... I'm curious to see how strong they are compared to the Yukon and the Longfield Dana 60 CV.
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 10-29-2006, 09:58 PM   #24
TatonkaII
TatonkaII's Avatar
Member # 12454
Send a message via AIM to TatonkaII
I'd love to know whats in your "to do list" of sorts Bobby. I think everyone would like to know what you're currently working on.
85 3.4 V6, 38s, Longs, 4.7 Marlins, 5" AP springs.. almost done..www.chucktownlowdown.com
TatonkaII is offline   Reply With Quote
Old 10-29-2006, 11:22 PM   #25
cheap sunglasses
cheap sunglasses's Avatar
Member # 55512
Send a message via AIM to cheap sunglasses
So birfs are tested at an angle and u-joints at no angle? Wouldnt that give the u-joints a big advantage? Or did I just read that wrong..
cheap sunglasses is offline   Reply With Quote
Forum Jump
