#1 |
Member # 66914
GA86yota's buildup
I deleted the old thread cause i wasnt getting anything done.
august 10th--- took my front drivers hub off (still IFS) to figure out why my wheel was wobbling when i went around a left turn (only did it on left turns)...bad bearings...lots of metal in the grease etc etc...and im doing this for my senior project (early )..So i got the balls up to start cutting my truck up... plans: to get it driving again soon Front : 79' toyota front axle $175 custom trusses bottom and top (2.5x2.5x.25'' square tubing) (going to cut top off and redo) $$free 5.29s open for now...E-locker about to go in $IDK bought a deal F&R & Master kits $450rears/ pro comp mixed pack $50 TG u-bolt flip kit $50 box moved 2'' forward $free homebrew relocation brace (.25 thick steel plate, welded to frame and grade 8 bolts) $free Trail-gear hanger $150 TG shackles Trail-Gear high steer $340 IFS calipers $free TG 26'' lines $69 82' LC rotors $50 Trail-gear longtravel driveshaft kit Rear : 86' toyota 8'' rear $free 5.29 gears $$$see front Yukon full spool $142 52.5'' ford f150 springs $40 homeade shackles (3/8 steel plate made to copy TG shackle) $frree homeade hangers $free Trail-gear longtravel driveshaft kit Tires / Wheels : 35x12.5x15 mickey thompson baja claw radial $150 15x8 chevy rallye painted black $free New AISIN slave cyl..$30 Pulling motor, redoing some wiring and maybe rebuild it..replace water pump, alternator, starter, and battery...a few gaskets..reseal oil pan front / rear bumpers all in all i def. should have purchased the SAS kit instead of putting it together myself, but shit happens
James. 94' Cherokee Country Abused daily Tera LCAs, RCX UCAs, 5'' of lift, 4.10s LS rear, 35'' MTZs Last edited by GA86yota; 11-03-2006 at 04:48 PM. |
#2 |
pretty big difference in those gears..
85 3.4 V6, 38s, Longs, 4.7 Marlins, 5" AP springs.. almost done..www.chucktownlowdown.com |
| Sponsored Links |
#3 |
Member # 21138
id start collecting everything i needed before i cut my truck up.
go rears up front with chevies, and definately match the diffs up. good luck.
post 272 85 4runner/detroits f&r/doubler/5.29s/35s |
#4 |
Member # 66914
i have lots of steel..and lots of parts to do this with
im not planning any wheeling when its finished until i get the front geared...just wanna get it driving again soon i've been thinking of rears up front but im gonna read more about it..i just dont want to have to move my steering box
James. 94' Cherokee Country Abused daily Tera LCAs, RCX UCAs, 5'' of lift, 4.10s LS rear, 35'' MTZs |
#5 |
in that case, i feel youre pain. I havnt been on the trail in nearly 4 years due to collecting parts slowly. I rolled mine shortly after getting it so now its no-op on the highway... so, its a farm truck till i finish collecting parts. No sense in doing things twice, ya know
#6 |
Member # 66914
i still have to buy some parts...but in the end i think i should have probaly bought a kit but i want the experience...for some odd reason..maybe because after high school im moving to riverside, ca to go to www.thefabschool.com
#7 |
Member # 66914
tear down
![]() ![]() your basic IFS pile ![]() Now i gotta start cutting and grinding and rebuild the motor and get it in soon... Engine : before ![]() During : ![]() ![]() and after ![]() and i got some funny videos of this stuff but i gotta figure out how to do it first
James. 94' Cherokee Country Abused daily Tera LCAs, RCX UCAs, 5'' of lift, 4.10s LS rear, 35'' MTZs Last edited by GA86yota; 08-14-2006 at 03:10 PM. |
#8 |
Member # 19325
you know the engine is a lot lighter if you take the intake heads and accessories off, you probably could get the block out with two guys by hand, your rebuilding it anyway, might as well make it easy on yourself.
#9 |
Member # 66914
yea i know but i wanted to take it out as a whole engine and do all the work on it at once, but now i have an engine hoist to put it back it shoulda got it sooner...wanna come sling some wrenches with me ?? ill help ya some on your runner..
side shot ![]() new bed supports since i dont have a tailgate ![]() stuff happens when your dumb friend sits on the windshield
#10 |
No shit when you just showed us the size of them!!
#11 | |
Jay King is my hero!
Member # 71495
http://yotamasters.com/ The only jeep in my family is pink and my 2 year old drives it
#12 |
Member # 21138
...you kinda missed removing a couple things there.
and it looks like your railroad tie is gonna split-stick you big buddy under there instead.
#13 |
www.12voltguy.com
Member # 40
funny shit
TTC 2010 #1 truck pick,I'm in! 12voltguy.com / ![]() Click here to email me New # 530.532.4529![]() http://www.davezoffroadperformance.com/ OFN Fab BB -89 1 ton bronco on 46" MT's-![]() 03 crf450 Hard work often pays off after time, but laziness always pays off right now. |
#14 | |
Member # 66914
#15 |
Member # 66914
as of now im trying to find some highsteer arms or a complete kit kinda cheap...looking for springs...then place an order for brake lines, hanger, backing plate eliminators, and some other little things...do what i gotta do to the motor and put front axle back together...
#16 |
Member # 66914
now im thinking about running rears up front but im concerned about having to move my ps box, is it required to move the box ?? i looked in the rears up front FAQ nothing there about having to move it forward
#17 |
Member # 66914
figued it out....drill a new hole in each spring perch 1.25 forward of the original...then i aint gotta move the box...
#18 |
Member # 34101
Where do you go to school at? Just wondering. I live in Gainesville and graduated from North Hall. You have prob seen my white '92 SAS'd on 37's around. Good luck with your build. Let me know if you need any help.
#19 |
Cool project, I built my nissan for my senior project. I would adivse you to buy all of your parts now, nothing sucks more than missing dead lines with school because of a back-order. Plus, you will not get as carried away with it. I had a budget of $4,500 for my nissan and I ended up trying alot of new things and spending $14k before I knew it.
Obama - Just another black man living in government housing |
#20 |
Member # 66914
actually im a junior now so im just getting it done now and taking lots of pictures and then i just have to write a 5 page paper on this stuff
so ill have less to do when next year comes around
#21 |
Member # 66914
got springs today..just gotta figure out where to move my hangers..52 1/2'' f 150 springs : http://www.pirate4x4.com/forum/showthread.php?t=501537 : thread on spring hanger placement....also got shackles and some u-bolts and plates
But i sure as hell wish i had a torch or plasma right now...its a major PITA to cut all that with a grinder and cut off wheel
#22 |
Member # 66914
PROBLEM ::: measured my rear springs today...they're like 44 1/2'' eye to eye WTF arent they supposed to be 48'' e 2 e ?? either im wrong or my springs arent right ??
#23 |
Member # 19325
are you just measuring from eye to eye? or are you measuring eye to eye along the spring? you can get a piece of string and run it along to get an accurate length, then measure the length of the string
#24 |
Member # 66914
measuring eye to eye across the spring and they measured 44 1/2''
#25 |
Member # 66914
BTW i even measured from the hanger to the shackle in the rear (with a spring still mounted and it was like 45''
| Thread Tools | |
| Display Modes | |
