#1 |
Member # 463
Rock Me Buggy carb set up (no extra shiot)
these are the pics of the carb set up no extra vaccum lines and a bleeder tube to keep it running at angles
#2 |
Member # 463
| Sponsored Links |
#3 |
Member # 463
#4 |
Member # 9821
Gee it even runs at this angle???
I'm pimping ScottFJ40's [URL=http://search.ebay.com/_W0QQfgtpZ1QQfrppZ25QQsassZthemanwithgreatseats]ebay shit[/URL] so he owes me a dollar. [color=orange] Two wrongs don't make a right but three rights make a left.[/color] [color=yellow]I before E except after C except in words like neighbor and Budweiser.[/color] [color=lime]May clinging breasts always come to your aid in the kitchen. [/color] |
#5 |
Member # 463
Yes it does
#6 |
Member # 250
So you did Moon Rocks, I wish I had gone, but was working on my shit for Drew's Bash. Why not EFI? We'll have to get togather on the con or fordyce this summer so I can check out your buggy. Are you going to the Bash, or when are you guy's going to the Con?
Making good decisions comes from experience ....... ...... experience comes from making bad decisions |
#7 | |
so where did you get the idea of blocking all the lines to get it to run at an angle? NICK
someone who has everything has everything to lose. BEN HARPER www.outerlimits4x4.com |
#8 |
please explain!
You knew someone was going to ask you the method behind your maddness. let's hear it! Last edited by Lowtorious; 05-15-2002 at 12:10 AM. |
#9 |
pimping sparks&smoke
Member # 444
Nic-- YOU WERE AT CALROCKS!!!!!!!!!!!!!!!??
Man you were within 100mi. from my place damn we could of saved you shipping. Toy family- I was so bummed that you were not in the finals I showed up for Sunday really hoping to see your rig compete. Well atleast you got out there like you planned (I had my doubts whether or not you would be able to finish the buggy in time atleast at the begining). It looks great , and next time you'll show em' eh! weldpro
DBSONLY |
#10 |
Pirate4x4 Addict!
I told Nick that we were going to ahve to explain all of it. The motor was my responsibility. I started by removing every smog related component and making the appropriate restrictor plates. I'm not sure what everythihng is called, but the best way to start is to remove everythign connected to the smog rails. I capped every vaccum line that I removed. At this point it ran but didn't idle. We got a smog guy to come by and look at the routing(thanks sly4rnnrdrt12), which enabled us to get rid of a lot more stuff and route vaccum to the components that needed it, either manifold or regulated. I'll make a drawing for the line routing and explain the carb mods. We were also able to completley ditch the ECU. The key to running at the angles was routing the bowl vent out of the circuit. Normally in extreme angles, the vent dumps the excess fule down the throat of the carb, which stalls the engine. That is the hose you see on top of the carb. We're going to change it to motorcycle fuel line. We routed this into a small recovery bottle to avoid leaking fuel onto theground. The system worked flawlessly.
ECV 7-11 Serving up a Tsunami of Swagger |
#11 |
That buggy is so cool, I drool everytime I come by and see it I think you guys totally kicked ass considering you never got to test the rig before competing and you built it for a WHOLE LOT less than what your competitors are!
#12 | |
#13 |
Member # 4703
OK I am sure I will get flamed on this on, but I am a complete newbie to a carb. Everything I have owned up untill a month ago has been EFI. Please enlighten me on this breather to keep it runnin at extreme angles.... What is it hooked to? What does it do exactly?
OK so I am alittle slow typing.
sold my sh*t but getting ready to start again Last edited by OffroadRunner; 05-15-2002 at 08:48 AM. |
#14 |
Member # 5963
its still a carb. i hate carbs! they suck! they never work right for me. i love my fuel injection and i'll never give it up!
GETLOST4X4.COM, 2006 Jeep Commander (Chief) 4.7L V8 Limited 1978 Jeep Wagoneer (Tank) 6.6L V8 |
#15 | |
Member # 1246
CARBS SUCK!
#16 |
Member # 11365
Wilson, your carb looked like it ran great. I am the guy who drove the Army green tubed Toyota coiled, w/ rear steer dana 44. I ran a brand new Webber 32/36 that worked great except for #2(Crack). I vapor locked the motor on #4. I am searching for an Injected 22RE. Keep up the good work you guys kicked ass!!! RUN DOG
OUR STABLE OF 4x4's 1) JIMMY's 4x4 KOH Racer 2) 2004 Land Rover DII (hers) 3) 2002 Dodge 2500 Diesel 4x4 (Tow Rig) (mine) 4) 2001 JEEP Grand Cherokee 42" IROKS/4-linked/Atlas (Mine) 5) 1985 FJ 60 landcruiser-Dana 60's, Atlas Ram Jet 350 6) 2005 Full supension BOB Stroller (twins) |
#17 |
Member # 463
ran the carb because it was free (Poor Copllege boys), we had to spend money on more important things
the tube in the top view is the one that helps prevent the hi angle flooding |
#18 |
Member # 5315
The tube is a vent to the float bowl, is that right?
86 22R Weber carbed Toy Truck |
#19 |
Member # 3621
so all i have to do is run a tube from the float bowl to a catch can and my carb won't flood? help us carb idiots out.
#20 | |
Pirate4x4 Addict!
Yes, remember it's not goign to run as perfect as fuel injection. there still is the potential for accelerator pump lag and other possibel stalling/hesitation problems, but moving the vent dump out of the throat of the carb is a big help. It will run at extreme angles, but may not alwasy restart if stalled. Nick is going to have to test it again, the front brakes were locked all day, which made it much easier to stall. A little more seat time and we'll have a better idea of just how well it works. On a regular truck, you will have to run the vent line out of the stock air cleaner assembly which requires some more work, but is easily doable.
#21 |
I've got an efi motor sitting and ready to put in, but not enough time, so I'll make the carb work. Did you guys set the floats way low or leave them stock?
--Radio Controlled Rockcrawling--
Team Carnage Crew 2008 XRRA Western Champions |
#22 |
Member # 463
Hey Wilson and Nick, I was wondering if you'd get the same results if you replace the drain hose with a rubber cap that plugs that tube. That way you can run an air cleaner without having to worry about routing the hose out to a catch bottle.
Jim |
#23 | |
Pirate4x4 Addict!
#24 |
Member # 22539
do you still have some pic of this setup to see the vacum line(the one facing the motor)
thanks
84 runner 4" lift,fender triming,36 tsl 5.29,rebuilt 22r with torquer cam and changed back to stock carb UNDER RECONSTRUCTION [URL=http://www.toyota4x4.net]toyota-4x4.net[/URL] [URL=http://www.toyota-4x4.net/forum/index.php]forum[/URL] |
#25 | |
Member # 22547
HOBIE - OG-13 - F-TOY #10 - Current National W.E.ROCK Champion - 3 Finished KOH races: Desert Valley Towing Racing Team - Hi Desert Driveline - Edelbrock - 4x4him.org - BFG - Jeepswag.com - Hendrix |
| Thread Tools | |
| Display Modes | |
